重要提示:PCB作品文件展下载说明
绝对经典
六层PCB经典 DSP+原理图.rar
(1.52 MB, 下载次数: 6)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Part Type | PCB Decal | Value | D2 | 1N1201A | DI1808 | UF1001 | D3 | LED_2 | DI1206 | LED | D4 | 1N1184A | DI1206 | 1N1184A | D14 | NPN | SOT-23 | 9002(NU) | DJ1 | SW_PUSHBUTTON-SPST | PJACK | SW PUSHBUTTON-SPST | J1 | CON14AP | IDC16_G | CON14AP | J2 | BNC | RCA | CVBS | J3 | CON3 | IDCD3 | CON3 | J4 | CON6A | IDC-8D | CON6A | J5 | PHONEJACK_STEREO_SW | PHJCK | PHONEJACK STEREO SW | J6 | CON3 | IDCD3 | CON3 | J7 | PHONEJACK_STEREO_SW | PHJCK | PHONEJACK STEREO SW | J8 | CON14 | IDCD14 | LCD | J13 | CON10AP | IDC10 | JTAG | J15 | CON7 | IDCD7 | CON7 | J16 | CON14AP | IDC6_G | CON14AP | JS1 | M-DIN_4-R | XVIDEO | S_VIDEO | P4 | CONNECTOR_DB9 | DB9/M | DB9 | SW5 | SW_PUSHBUTTON | PUSHSW | SW PUSHBUTTON | SW6 | SW_DIP-4 | DIP8-SWP | SW DIP-4 | SW7 | SW_DIP-4 | DIP8-SWP | SW DIP-4 | U1 | TMS320C6202B | BGA352PP | TMS320C6202B | U2 | ACF451832-153 | ACF3-SMD | ACF451832 | U3 | CY2308-2 | SO16 | CY2308-2 | U11 | MAX708S | SOP8-UMAX | Max708S | U12 | QSE158 | TO220H | LM1117-33 | U49 | HY57V641620HG | TSOP54 | IS42S16400 | U50 | HY57V641620HG | TSOP54 | IS42S16400 | U51 | ST29LE010 | PLCC32 | ST29LE010 | U52 | AL440B | SOP44-P | AL440B | U53 | AL440B | SOP44-P | AL440B | U54 | SN74ALB16244 | TSSOP48-DGG | SN74ALB16244 | U55 | SN74ALB16244 | TSSOP48-DGG | SN74ALB16244 | U63 | CRYSTALLOID | OSC4-SMD | OSC50MHz | U64 | FERRITE_BEAD_2 | 1206 | F.B | U65 | 7414 | SO-14 | 7414 | U68 | SST28F040A | PGA32 | HY29F040 TSOP | U69 | SST39VF160 | TTSOP48 | SST39VF160 | U70 | HY57V641620HG | TSOP54 | HY57V641620HG | U73 | RTL8201 | SQFP48P | RTL8201BL | U76 | FERRITE_BEAD | | F.B | U77 | CONNECTOR | IDC20 | BOOTMOD | U78 | SN74ALB16245 | TSSOP48-DGG | SN74ALB162245 | U79 | SAA7114H | SQFP100P | SAA7114H | U80 | MAX4332B | SO8 | MAX4332 | U86 | MAX232 | SO16 | MAX232 | U93 | EPLD7128S-100 | SQFP100P | EPLD7128S-100 | U95 | TLC320AD50C | SOP28 | TLC320AD50C | U96 | CRYSTALLOID | OSC4-SMD | EPSON 8.192MHz | U105 | LM386/SO | SO8 | LM386/SO | U109 | LT1086 | | LM1117-33 | U110 | ARM-S3C4510B | SQFP208PP | ARM-S3C4510B(CLOCK) | U111 | LT1086 | | LM1117-15 | U113 | SJ45_TRAN | BBSOP16 | S45_TRAN | U114 | RJ45 | RJ45P | RJ45 | U116 | USB | USBJACK | USB | U153 | PDIUSBD12 | SOL-28 | PDIUSBD12 | Y1 | ZTB | OSCTT25 | 24.576MHz | Y2 | ZTA_2 | OSCTT25 | ZTA | Y4 | ZTA | | 6M |
评分
查看全部评分
重要提示:PCB作品文件展下载说明
