Altium Designer 16 已经发布了!!!
请大家看看如下的这些新特征:
Offline Design System
Alwaysremain in complete control of what network data you share with theoutside world with the Offline Design System. Easily specifyconnectivity for specific applications within Altium Designer includingpreferences sharing, licensing servers, part supplier connections, andmore.
Advanced Component Search
Easilyfind the exact components you need for your designs with advancedsearch options in the Vault Explorer. Tailor your search to yourspecific needs with customizable query fields, and even save yoursearches as favorites for future reuse.
Enhanced Pin Length Definitions
Accuratelyand efficiently route your high-speed design layouts with enhanced pinlength definitions in the component pin properties. Enhancedcalculations for pin lengths include the length of the internal bondwire without requiring time-consuming manual calculations.
3D STEP Model Generation Wizard
Easilygenerate the most realistic, accurate, and data-rich 3D models with the3D STEP Model Generation Wizard. With realistic 3D STEP models you’llget an exact representation of your physical board in real-time Native3D PCB.
Streamlined Design Rule Editor
Easilycreate and manage your advanced design rule queries with the new DesignRule Editor. Understand exactly how your queries interact together andavoid any conflicting rules with an organized query validationinterface.
PADS® Logic Exporter
Savetime exporting your design files from Altium Designer to PADS® with thePADS® Logic Exporter. Design the most advanced board layouts in AltiumDesigner, then instantly translate your schematics and board layouts toyour workspace in PADS® Logic.
Net Color Synchronization
Ensuredocumentation accuracy and visual color notifications with net colorsynchronization between schematic design and the PCB layout. Instantlysync net colors to your board layout through a managed EngineeringChange Order.
Component Placement System Designthe most organized and efficient board layouts with a new componentplacement system. Dynamically place and drag components that push,avoid, and snap-to alignment with other components on your boardlayout.
Hole Tolerance Definitions
Guaranteereliability when manufacturing your PCB by defining specific holetolerance values for pads and vias. Specify precise hole tolerances aspart of your manufacturing documentation to ensure you get it right thefirst time, everytime.
Integrated TASKING Pin Mapper
Sharedesign data instantly between your PCB and embedded software projectwith the integrated TASKING Pin Mapper. Seamlessly share pinassignments, processor chip identifiers, and symbol names between AltiumDesigner and your TASKING toolset.
Technology-Aware xSignals Wizard
EasilyDesign accurate high-speed board layouts with technology-awareconfigurations in the xSignals Wizard. Automatically create xSignalsclasses and match length rules for DDR3, with other advanced high-speedtechnologies being added in the future!
Visual Clearance Boundaries
Clearlyunderstand the impact of your routing decisions in real-time withvisual clearance boundaries. See clearance boundaries between traces andcomponents visually as you route and design the most accurate boardwith ease.
