[sell=20,2]
RK3288-MAIN - .pcb
(6.52 MB, 下载次数: 12)
[free]
RK3228PCB
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Value | PCB Decal | Part Type | CN3 | CON6 | CON6_DIP | CON6_DIP | CN12 | MF210/MI800-X8QB | MINI_PCIE_52 | MINI_PCIE_52 | CN13 | SOPP-20006-01G | SIM_9 | SIM_9 | D3 | SS24 | DO214AC | DO214AC | D4 | SS34 | DO214AC | DO214AC | D5 | SS34 | DO214AC | DO214AC | D6 | SS34 | DO214AC | DO214AC | D8 | 1N5819 | SOD123 | SOD123 | D9 | NC | SOD123 | SOD123 | D10 | 1N5819 | SOD123 | SOD123 | D11 | SS34 | DO214AC | DO214AC | D12 | SS24 | DO214AC | DO214AC | D13 | 1N5819 | SOD123 | SOD123 | D14 | BAT54C | SOT23 | SOT23 | D20 | BAT54C | SOT23 | SOT23 | D21 | SS14 | DO214AC | DO214AC | D24 | LED | R0805 | R0805 | D25 | LED | R0805 | R0805 | D31 | BAT54S | SOT23 | SOT23 | D32 | NC | SOT23 | SOT23 | ED43 | ESD9B5V | E0402N | E0402N | F1 | R30-250 | FUSE_DIP | FUSE_DIP | J2 | CON4_SIP_2.54MM | CON4_2.0 | CON4_2.0 | J6 | SD_MMC_UP_BOARD | SD_MMC_UP_BOARD | SD_MMC_UP_BOARD | J7 | CON2 | BATT_Y | BATT_Y | J8 | BAT | CON3_2.54 | CON3_2.54 | J9 | USB-HOSTX1 | USB_Y | USB_Y | J10 | USB-HOSTX1 | USB_Y | USB_Y | J11 | HDMI | HDMI | HDMI | J12 | USB-HOSTX1 | USB_Y | USB_Y | J13 | CON2 | CON2_2.0A | CON2_2.0A | J15 | CON6 | CON6_2.0 | CON6_2.0 | J16 | CON6 | CON6_2.0 | CON6_2.0 | J18 | CON6_2X2 | CON6_2X2 | CON6_2X2 | J23 | DC-IN | DC-013A | DC-013A | J8204 | NC | CON4_2.0 | CON4_2.0 | J8205 | CON5 | CON5_2.0 | CON5_2.0 | J8206 | EAR-PHONE-4 | ST-3066-6R | ST-3066-6R | JP4 | RJ45S | RJ45_L | RJ45_L | L8 | 3.3UH/2.8A | SMD6X6 | SMD6X6 | L15 | 3.3UH/2A | IND-4X4 | IND-4X4 | L22 | 3.3UH/2.8A | SMD6X6 | SMD6X6 | L2203 | 2.2UH/1.5A | IND-3X3 | IND-3X3 | L2204 | 2.2UH/1.5A | IND-3X3 | IND-3X3 | L2205 | 0.22UH/5A | IND-4X4 | IND-4X4 | L2206 | 2.2UH/1.5A | IND-3X3 | IND-3X3 | L2207 | 2.2UH/1.5A | IND-3X3 | IND-3X3 | L2208 | 0.22UH/5A | IND-4X4 | IND-4X4 | L6000 | 2.2UH | IND-3X3 | IND-3X3 | MIC7000 | NC | CON2_2.0A | CON2_2.0A | Q4 | SS8050LD | SOT23 | SOT23 | Q5 | FDS9435A | SOP8 | SOP8 | Q6 | SI2035 | SOT23 | SOT23 | Q7 | SI2305 | SOT23 | SOT23 | Q8 | 8050 | SOT23 | SOT23 | Q11 | SI2305 | SOT23 | SOT23 | Q12 | 8050 | SOT23 | SOT23 | Q13 | SI2305 | SOT23 | SOT23 | Q14 | 8050 | SOT23 | SOT23 | Q15 | 8050 | SOT23 | SOT23 | Q16 | 8050 | SOT23 | SOT23 | Q17 | SI2305 | SOT23 | SOT23 | Q18 | 8050 | SOT23 | SOT23 | Q22 | WPM2341 | SOT23 | SOT23 | Q27 | WNM2021/2SK3018 | SOT23 | SOT23 | Q29 | WNM2021/2SK3018 | SOT23 | SOT23 | Q30 | WNM2021/2SK3018 | SOT23 | SOT23 | Q31 | WNM2021/2SK3018 | SOT23 | SOT23 | Q32 | WNM2021/2SK3018 | SOT23 | SOT23 | Q33 | WNM2021/2SK3018 | SOT23 | SOT23 | Q34 | WNM2021/2SK3018 | SOT23 | SOT23 | Q35 | 8050 | SOT23 | SOT23 | Q36 | SI2305 | SOT23 | SOT23 | Q37 | WNM2021/2SK3018 | SOT23 | SOT23 | Q38 | WNM2021/2SK3018 | SOT23 | SOT23 | Q39 | WNM2021/2SK3018 | SOT23 | SOT23 | Q40 | WNM2021/2SK3018 | SOT23 | SOT23 | Q41 | WNM2021/2SK3018 | SOT23 | SOT23 | Q42 | SS8050LD | SOT23 | SOT23 | Q2205 | NC | SOT23 | SOT23 | Q2206 | SI2305 | SOT23 | SOT23 | Q2208 | 8050 | SOT23 | SOT23 | Q2210 | NC | SOT23 | SOT23 | Q3000 | SI2305 | SOT23 | SOT23 | Q8200 | WNM2021/2SK3018 | SOT23 | SOT23 | Q8201 | WNM2021/2SK3018 | SOT23 | SOT23 | RP4000 | NC | R0402S4 | R0402S4 | RP4001 | NC | R0402S4 | R0402S4 | S2 | SK-12D07 | SK-12D07 | SK-12D07 | S3 | KFC-26-L4 | IT_1207SMD | IT_1207SMD | S4 | KFC-26-L4 | IT_1207SMD | IT_1207SMD | U17 | NC | TSSOP8 | TSSOP8 | U18 | TCS9507 | SOT25 | SOT25 | U19 | TCS9507 | SOT25 | SOT25 | U20 | TCS9507 | SOT25 | SOT25 | U23 | RTL8152B | QFN24-4X4MM | QFN24-4X4MM | U31 | HYM8563/TCS9563 | MSOP8 | MSOP8 | U51 | LA8533PG | SOP8E | SOP8E | U52 | CE8808N33M | SOT23 | SOT23 | U53 | LA8533PG | SOP8E | SOP8E | U54 | TT8514 | TDFN10-3X3 | TDFN10-3X3 | U55 | PIC16F1824 | SOP14 | SOP14 | U61 | RFANT5220 | I-PEX | I-PEX | U62 | TRS3232CDR | RS232 | RS232 | U63 | TRS3232CDR | RS232 | RS232 | U65 | CON34 | CON34_2.0A | CON34_2.0A | U66 | CON34 | CON28_2.0A | CON28_2.0A | U68 | CON20 | CON22_2.0A | CON22_2.0A | U74 | TRC41604NL | H1102 | H1102 | U79 | TCS4201 | SOT26 | SOT26 | U85 | IR | TO92ECB | TO92ECB | U98 | NC | SOT25 | SOT25 | U1000 | MCU_RK3288 | BGA636_19X19 | BGA636_19X19 | U2204 | ACT8846QM490-T | QFN48-6X6 | QFN48-6X6 | U2205 | SYR827 | BGA20-5X4 | BGA20-5X4 | U2206 | SYR828 | BGA20-5X4 | BGA20-5X4 | U2207 | CE8809C263MA | SOT23 | SOT23 | U2209 | HYM8563 | MSOP8 | MSOP8 | U3000 | DDR3-512MB | FBGA96-10X14 | FBGA96-10X14 | U3001 | DDR3-512MB | FBGA96-10X14 | FBGA96-10X14 | U3002 | DDR3-512MB | FBGA96-10X14 | FBGA96-10X14 | U3003 | DDR3-512MB | FBGA96-10X14 | FBGA96-10X14 | U4000 | NC | INAND_1 | INAND_1 | U4001 | TCS2105-1.8V | SOT25 | SOT25 | U4101 | H27UCG8T2AFR | TSOP1-48 | TSOP1-48 | U6000 | AP6210 | AP6XXX | AP6XXX | U6001 | NL27WZU04 | SOT26 | SOT26 | U7000 | ES8323 | QFN28_8323 | QFN28_8323 | U8200 | RCLAMP0524J/ESDA6V8UD | SLP2510P8 | SLP2510P8 | U8201 | RCLAMP0524J/ESDA6V8UD | SLP2510P8 | SLP2510P8 | U8202 | RCLAMP0524J/ESDA6V8UD | SLP2510P8 | SLP2510P8 | U8400 | NC | SOT25 | SOT25 | U8405 | MIX3601 | SSOP28_MIX3601 | SSOP28_MIX3601 | Y4 | 12M | CRY-D3225 | CRY-D3225 | Y5 | 12M | CRY-D3225 | CRY-D3225 | Y7 | 32.768K | CRY-MC146 | CRY-MC146 | Y8 | 32.768K | CRY-MC146 | CRY-MC146 | Y9 | 25M-20PPM | CRY-D3225 | CRY-D3225 | Y1100 | 24M-30PPM | CRY-D3225 | CRY-D3225 | Y6000 | 26MHZ-10PPM | CRY-D3225 | CRY-D3225 |
评分
查看全部评分
