重要提示:PCB作品文件展下载说明
板子有以下主要元件。
Name | PCB Decal | Value | Part Type | B1 | BUZZER | BZ | BZ | D1 | SD1710A | DZ3 | DZ3 | D5 | HSOD882 | DZ3 | DZ3 | D7 | HSOD882 | DZ3 | DZ3 | D15 | SD0805-LED | LED | LED | D22 | D_5MM | BS0080M | DIODE_ZENER1_0 | D25 | HSOD323A | D_A | D_A | D26 | HSOD323A | D_A | D_A | D29 | D_5MM | SS34 | 1N4148_1 | D43 | D_5MM | BS0080M | DIODE_ZENER1_0 | DA1 | D_5MM | 1N4004 | DIODE_0 | EC8 | CAPR_1_2 | 100uF,25V | 100UF_10V_20%_D_CASE | EC54 | DIP_C_10 | 1000uF/25V | CAP/B_CASS | EC62 | DIP_C_10 | 1000uF/25V | CAP/B_CASS | F1 | SF6127 | FUSE2 | FUSE2 | F2 | L0805 | 2A,SMD_4532 | 2A_POLY_SWITCH_SMD4532 | J12 | PWC0103-M-C | PWC3_A | PWC3_A_1 | J13 | TCON-67491_MOLEX_SATA | SIP7M2 | SIP7M2 | J14 | TCON-67491_MOLEX_SATA | SIP7M2 | SIP7M2 | J15 | TCON-67491_MOLEX_SATA | SIP7M2 | SIP7M2 | J16 | TCON-67491_MOLEX_SATA | SIP7M2 | SIP7M2 | J17 | MJ8-SRLFY | MJ8-SL | MJ8-SL_0 | J18 | VGA_FM | DB15-3M2 | DB15-3M2_0 | J19 | USB-4 | USB_UP | USB_UP_0 | J20 | CON2_9 | SIP10 | CON4_2_2 | J21 | HDMI_RX_CON_DIP | 51U019S-332N-C4 | HDMI_RX_CON_SMD_0 | J22 | USB-4 | USB_UP | USB_UP_0 | J23 | CMD6-125 | SIP4 | CON4_0 | J24 | CMD9-125 | 10PIN | J30_1 | J25 | CMD4-254 | CONN PCB 2_NC | CONN_PCB_2 | J26 | CMD6-125 | SIP4 | CON4_0 | J42 | CON4-9090-4V-H10.2 | CONN RCPT 4 | CONN_RCPT_4 | J43 | CMD4-254 | CONN PCB 2_NC | CONN_PCB_2 | J44 | CMD4-254 | CONN PCB 2_NC | CONN_PCB_2 | J52 | CON8-9090-4V-H10.2 | SIP4 | CON4_1_2 | J53 | CON8-9090-4V-H10.2 | SIP4 | CON4_2 | J55 | AV-01 | AUDIO | BNC_3 | JA14 | BNC2 | 6PIN_BNC_AA | 6PIN_BNC_AA_0 | K3 | CN2PIN-75CM | FUSE2 | FUSE2_0 | L1 | SPL0705A | 2.2UH | L | L3 | SPL0707G | 2.2UH | L | L4 | HSL1008 | 2.2UH | L | L8 | SPL0707G | 2.2UH | L | L17 | SPL0807D | 1UH | L_E | L18 | SPL0807D | 1UH | L_E | LB1 | SL0402 | LB | LB | LB2 | SL0402 | LB | LB | LB28 | SL0402 | LB | LB | LB29 | SL0402 | LB | LB | Q11 | SOT23 | 2N3904 | 2N3904_0 | T2 | STFM24-40-280 | G2401CE | G2401CE | U7 | BAT-10MM | PWR1-2 | PWR1-2 | U8 | BGA735-32-3232 | HI3536V100_PWR | HI3536V100_PWR_11 | U9 | WSON8-MX25L12835ZN | MX25L25635/NC | SPI_NAND_FLASH_8PIN | U10 | SOT23B | ADM809 | ADM809_2 | U11 | QFN12-050-0302A | MP2145 | MP2145 | U12 | QFN12-050-0302A | MP2145 | MP2145 | U13 | QFN16-8765 | MP8765 | MP8765_1 | U16 | TSOT23-6 | MP1470 | MP1470 | U17 | QFN16-8765 | MP8765 | MP8765_0 | U19 | SOT23-6L | AZC199-04S | AZC199-04S | U28 | MLF48A-040-0606L | RTL8211D | RTL8211D_0 | U31 | SOP16-50-300A | MX25L25635EMI-12G | MX25L25635EMI-12G_1 | U32 | DFN2510P10E_AZ1045 | AZ1045-04F | AZ1045-04F | U33 | DFN2510P10E_AZ1045 | AZ1045-04F | AZ1045-04F | U34 | SO8-P | FMS6363 | NCS2553 | U36 | BGA96-32-1609M | MT41J256M16RE-15E-D | MT41J256M16RE-15E-D_0 | U37 | BGA96-32-1609M | MT41J256M16RE-15E-D | MT41J256M16RE-15E-D_0 | U38 | BGA96-32-1609M | MT41J256M16RE-15E-D | MT41J256M16RE-15E-D_0 | U39 | BGA96-32-1609M | MT41J256M16RE-15E-D | MT41J256M16RE-15E-D_0 | U2014 | SO8-P | NJM4558E | LM833_1 | U2015 | SOT23-6L | CLAMP0504DT | AZC199-04S_2 | X1 | HSX2-0302 | 0.032768MHZ | X_2 | X2 | HSX4-0302B | 24MHZ | X_B | X3 | SX2-1205 | 25MHZ | X |
有需要的下载,没需要的就别乱点了,要RMB。
HI3536_V7_DSN.7z
(174 KB, 下载次数: 41)
重要提示:PCB作品文件展下载说明
