[IC] lm2596 SIMPLE SWITCHER® Power Converter 150 kHz 3A Step-Down Voltage Regulat
查看557 | 回复1 | 2016-6-6 09:26:23 | 显示全部楼层 |阅读模式
lm2596 SIMPLE SWITCHER® Power Converter 150 kHz 3A Step-Down Voltage Regulator
FEATURES
23• 3.3V, 5V, 12V, and Adjustable Output Versions
• Adjustable Version Output Voltage Range,
1.2V to 37V ±4% Max Over Line and Load Conditions
• Available in TO-220 and TO-263 Packages
• Ensured 3A Output Load Current
• Input Voltage Range Up to 40V
• Requires Only 4 External Components
• Excellent Line and Load Regulation Specifications
• 150 kHz Fixed Frequency Internal Oscillator
• TTL Shutdown Capability
• Low Power Standby Mode, IQ Typically 80 μA
• High Efficiency
• Uses Readily Available Standard Inductors
• Thermal Shutdown and Current Limit
Protection
lm2596 SIMPLE SWITCHER® Power Converter 150 kHz 3A Step-Down Voltage Regulator.pdf (4.62 MB, 下载次数: 0)
wcjcn | 2017-11-16 10:11:44 | 显示全部楼层
