[IC] MT7688_Datasheet
查看1189 | 回复6 | 2016-6-6 10:10:34 |阅读模式
MT7688_Datasheet
Features
Embedded MIPS24KEc (575/580 MHz) with 64 KB I
Cache and 32 KB D-Cache
1T1R 2.4 GHz with 150 Mbps PHY data rate
Legacy 802.11b/g and HT 802.11n modes
20/40 MHz channel bandwidth
802.11v
Space Time Block Coding (STBC)
16-bit DDR1/2 up to 128/256 Mbytes
x1 USB 2.0 Host, x1 PCIe Root Complex
1-port 10/100 FE PHY
SD-XC, eMMC, I2C, PCM, I2S(192K/24bits), PWM, SPI
master/slave, UART lite, JTAG, GPIO
Internet Of Thing
Embedded PMU
Green AP/STA
− Intelligent Clock Scaling (exclusive)
− DDRII: ODT off, Self-refresh mode
QoS: WMM, WMM-PS
16 Multiple BSSID
iPA/iLNA and ePA/eLNA
24 STA-Proxy
AES128/256-CBC
WEP64/128, TKIP, AES, WPA, WPA2, WAPI
WPS: PBC, PIN
MT7688_Datasheet.pdf (3.82 MB, 下载次数: 0)
zhoujian198909 | 2016-8-9 11:00:52 | 显示全部楼层
zxw74 | 2016-8-10 12:38:29 | 显示全部楼层
beast0007 | 2016-8-13 16:33:09 | 显示全部楼层
我只能说你要努力
whywhyq1w2e3 | 2017-1-3 10:16:38 | 显示全部楼层
qq1868811 | 2017-6-14 16:52:42 | 显示全部楼层
liouxianshu | 2019-3-23 09:54:40 | 显示全部楼层
