重要提示:PCB作品文件展下载说明
板子有以下主要元件
Name | Value | PCB Decal | Part Type | D1 | STPS0540Z | SOD123 | SOD123 | D2 | MAZ80330HL | DIO_SMINI2F1_PAN | DIO_SMINI2F1_PAN | D3 | | 0603LED | 0603LED | D4 | DIODE_SCHOTTKY | SOD_123 | SOD_123 | D5 | DIODE_SCHOTTKY | SOD_123 | SOD_123 | D6 | | 0603LED | 0603LED | DN1 | BAT54SW | SOT323AVX | SOT323AVX | DN2 | BAT54SW | SOT323AVX | SOT323AVX | FB1 | 68 OHM | FLTR_0603 | FLTR_0603 | FB2 | FERRITE | IND_0805 | IND_0805 | FB3 | 68 OHM | FLTR_0603 | FLTR_0603 | FB4 | 68 OHM | FLTR_0603 | FLTR_0603 | FB5 | 68 OHM | FLTR_0603 | FLTR_0603 | FB6 | 68 OHM | FLTR_0603 | FLTR_0603 | FB7 | 68 OHM | FLTR_0603 | FLTR_0603 | FB8 | 68 OHM | FLTR_0603 | FLTR_0603 | FB9 | 68 OHM | FLTR_0603 | FLTR_0603 | J1 | AXK5S40047YG | P5KS_40PIN_0_5MM | P5KS_40PIN_0_5MM | J2 | 50044-06001-002 | CONN-PLUG-60PIN-0_5MM | CONN-PLUG-60PIN-0_5MM | J3 | SM06B-SRSS-TB | SM06B-1_0MM-6PIN | SM06B-1_0MM-6PIN | J4 | SM03B-SRSS-TB | SM03B-1_0MM-3PIN | SM03B-1_0MM-3PIN | J5 | SM03B-SRSS-TB | SM03B-1_0MM-3PIN | SM03B-1_0MM-3PIN | J6 | SM03B-SRSS-TB | SM03B-1_0MM-3PIN | SM03B-1_0MM-3PIN | J7 | SM03B-SRSS-TB | SM03B-1_0MM-3PIN | SM03B-1_0MM-3PIN | J8 | SM03B-SRSS-TB | SM03B-1_0MM-3PIN | SM03B-1_0MM-3PIN | J9 | JMP_2X1 | CONN2-SMT-TSM-102 | CONN2-SMT-TSM-102-SV_SAMTEC | J10 | SM14B-SRSS-TB | SM14B-1_0MM-14PIN | SM14B-1_0MM-14PIN | J11 | AXK5S20047YG | P5KS_20PIN_0_5MM | P5KS_20PIN_0_5MM | J12 | Mini USB | MINIUSB_CONN | MINIUSB_CONN | L1 | 22 uH | DT1608A | DT1608A | L2 | 4.7 uH | IND_SRR1005 | IND_SRR1005 | L3 | 4.7 uH | IND_SRR1005 | IND_SRR1005 | L4 | 4.7 uH | IND_SRR1005 | IND_SRR1005 | MT1 | MOUNTING HOLE | MH276-157GND | MH276-157GND | MT2 | MOUNTING HOLE | MH276-157GND | MH276-157GND | MT3 | MOUNTING HOLE | MH276-157GND | MH276-157GND | MT4 | MOUNTING HOLE | MH276-157GND | MH276-157GND | Q1 | BCP68 | SOT223 | SOT223 | Q2 | 2N2907A | SOT23-3_FC | SOT23-3_FC | Q3 | 2N2907A | SOT23-3_FC | SOT23-3_FC | Q4 | 2N2222A | SOT23AVXD | SOT23AVXD | Q5 | 2N2907A | SOT23-3_FC | SOT23-3_FC | Q6 | 2N2222A | SOT23AVXD | SOT23AVXD | Q7 | 2N2222A | SOT23AVXD | SOT23AVXD | Q8 | 2N2222A | SOT23AVXD | SOT23AVXD | Q9 | 2N2222A | SOT23AVXD | SOT23AVXD | Q10 | 2N2222A | SOT23AVXD | SOT23AVXD | Q11 | 2N2222A | SOT23AVXD | SOT23AVXD | Q12 | 2N2222A | SOT23AVXD | SOT23AVXD | Q13 | 2N2222A | SOT23AVXD | SOT23AVXD | Q14 | 2N2222A | SOT23AVXD | SOT23AVXD | Q15 | 2N2222A | SOT23AVXD | SOT23AVXD | Q16 | 2N2222A | SOT23AVXD | SOT23AVXD | Q17 | FDV303N | SOT-23 | SOT-23 | Q18 | DMP2160UW | SOT-323 | SOT-323 | U1 | DPP6401 | PBGA_419 | PBGA_419 | U2 | TPS65145 | SOIC24-PWP_TI | SOIC24-PWP_TI | U3 | TPS73025 | TI_DBV | TI_DBV | U4 | TPS65251 | QFN_40 | QFN_40 | U5 | TPS79718 | TI_DCK | TI_DCK | U6 | TL7712A | 8-SOIC | 8-SOIC | U7 | SN74AHC1G08 | TI_DRLR | TI_DRLR | U8 | SN74AHC1G08 | TI_DRLR | TI_DRLR | U9 | LM393 | SOIC8-PW_TI | SOIC8-PW_TI | U10 | AT24C32C | SOIC-8 | SOIC-8 | U11 | TPD2E001 | SOP_4 | SOP_4 | U12 | S29JL032H | TSOP48 | TSOP48 | U13 | SN65220 | SOIC6-DBV_TI | SOIC6-DBV_TI | U14 | TILT | LCC8-MXD2125_MEMSIC | LCC8-MXD2125_MEMSIC | U17 | MAX3232 | SOIC16-PW_TI | SOIC16-PW_TI | U18 | 74LVC1G125 | SOT23-DBV_TI | SOT23-DBV_TI | U19 | SN65220 | SOIC6-DBV_TI | SOIC6-DBV_TI | X1 | 32.0 MHZ | 3_2MM_2_5MM | 3_2MM_2_5MM |
重要提示:PCB作品文件展下载说明
