[技术讨论] Pads/power pcb输出smt坐标文件步骤
查看1077 | 回复1 | 2016-9-6 23:55:07 | 显示全部楼层 |阅读模式
   首先声明:pads自带的宏命令输出smt贴片坐标是不好的,因为这个宏命令输出的坐标中心点是以 元件库建立时设置的原点 为准的,而每个人在建立自己的元件库时设置的标准没有统一,因此用那个宏命令输出的贴片坐标会给生产造成比较大的麻烦,不建议使用,请按照以下步骤进行smt坐标输出:
1. 设置单位      (设置为公制MM
2. 设置坐标原点  (设置为板件左下角)
3. filecam plus菜单转出smt坐标文件(如果有两层贴片则应该转出两个文件)
具体步骤截图如下:
设置单位
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB5FD.tmp783c8a6c-45fa-42d8-b5a5-ed551dada7df.jpg
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB60D.tmpc5daf444-358c-44d9-8a93-99dddcea7715.jpg
设置原点:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB60E.tmp5e7b18bf-5351-42f9-97ee-bded98d4d44a.jpg
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB61F.tmp97aeb603-ee30-4fbd-bca7-8fd84b5282f0.jpg
进行smt坐标文件输出:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB620.tmp204d9381-7027-412c-8a94-b1314c4d0890.jpg
输出顶层:请一定按方框中选项进行设置,设置完 run
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB631.tmpf1fb1890-9158-494f-bfb2-1d99ab53fc81.jpg
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB632.tmp1507a26c-365b-489b-b403-6ccc492f7e93.jpg
顶层文件输出到指定目录:  文件名为 DynproaT.318
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB633.tmpf5aa55e5-ec38-48d8-900e-aea20412d988.jpg
然后如果底层也有贴片文件:则同样输出:注意把side选为bottom:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB634.tmp0cfd990c-d756-406d-91a1-3746ab9ad288.jpg
输出文件名为:DynproaB.318
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB644.tmp3ebe491d-90a3-4f78-a1db-bcf8ad3f053d.jpg
到相应的文件夹查看坐标文件:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB645.tmpe3d91918-d1c4-4392-99b5-69bfc9a136c9.jpg
顶层坐标文件:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB646.tmp7968d51a-486b-427b-8a2b-53f6ce5fcccc.jpg
底层坐标文件
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wpsB647.tmpc2ad7a6b-9d0e-4746-8c24-1d108c18edcd.jpg
请继续看:
PADS输出的坐标文件转换为模板格式步骤
PADS输出的坐标文件:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps882F.tmp564dca76-e255-4a7e-b7fd-1189d72a96cd.jpg
打开excel,用导入数据功能将生成的坐标文件导入
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8830.tmpa506f1c1-ba5b-499b-86bc-ff2d55f70908.jpg
先导入Top面,注意文件类型选  所有文件:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8831.tmp2cc04a5e-388b-4729-b8ed-83ba4ab6d53f.jpg
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8841.tmp903c55d1-8a46-41fc-b92f-57fcb6ee853f.jpg
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8842.tmpd3ab8274-a1d5-4cb1-826e-f1c098a312fb.jpg
完成后就导入到excel中了,在最后一行加上面,顶层就加T,底层就加B:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8843.tmpea48c87c-b13f-4cdc-a0c0-7975fe9352dd.jpg
继续导入底层:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8844.tmp42ffee6e-f155-4b76-8dfb-7cc2c8ae8c17.jpg
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8845.tmp5d88081b-cbe1-4970-8808-1ead6c5f853e.jpg
导入后加上面数信息B
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8846.tmp1f0f1782-5d81-4c1c-b8f7-e39e5d4b7bef.jpg
打开坐标模板,将第一行copy后插入到文件中,并调整位置如下:
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8857.tmpc8d45f63-9a3d-4341-b32c-9c21b07ace79.jpg
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8858.tmpce677fec-318d-46e9-a6f6-1f223acc67aa.jpg
另存为csv文件
file:///C:/Users/von81/Documents/My%20Knowledge/temp/3e324f2e-a96e-4970-890f-62df5ebf117b/4/index_files/wps8859.tmp6330cb8b-2d0b-41e9-a70e-adcb6c8ee78c.jpg
bidinghong | 2016-9-7 06:21:17 | 显示全部楼层
