[PADS9.5以下] 高端智能手机PCB和原理图
查看6052 | 回复42 | 2016-10-21 18:02:12 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
游客,如果您要查看本帖隐藏内容请回复
****************以下信息由管理员 @老吴     整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
NamePart TypePCB DecalValueANT702TP-RF005-001-03-81520367-001RBEAD404FB_/_BK1005HS121-TBEAD0402BEAD405FB_/_BLM18BD252SN1603CON401CXJC-PJ2_2CXJC-PJ2CON703CAR_KIT_/_MM8130-2600MM8130-2600CON901TPO_LPJ032L001B_2FH26-39S-0.3SHWPanasonic AYF332535BPCON902FX12B-60P-0_3.4SVFX12B-60P-0.4SVCON903OV7645FB_3Molex52745-2090Hirose FX12B-40P-0.4SVCON1001CAR_KIT_/_MM8130-2600MM8130-2600CON1101MINI_10PIN_3CON2001CON_/_40_/_AXT440124__CON20x2/AXT440124D302D_/_MMSZ5231BT1GD303D_/_RB521CS-30DIODE/RB521CS-30D403ESD_/_ESD9L5_0.0ST5GSOD923/SMD/ESD9B5D901D_/_RB160M-60__0RB160M-30-EVBD1101D_/_RB551V-30_1RB551V-30(UMD2)D1102DIODE/ZENERD1610LED_1CM3652EMI1104EMI_/_DLP11RN450UL2DLP11S0504EMI1105RCLAMP0524PRCLAMP0524PRCLAMP0524PF1001BL1608-05K2450BL1608BL1608-05K2450FB1304FB_/_BLM18PG471SN1DL0603GB301XC414HB414 IV01EJ90133PIN_133PINAXT340124L308MDMK2020T2R2MM_SMD2520L/IND/SMD/2520L402BEADL403FB_/_BLM18PG221SH1603FB / BLM18PG221SH1L442L_/_100_/_NH_/_0402L0402L821INDUCTORA2.2uH / LQM2MPN2R2NG0LL901INDUCTORBLQH3NPN220MJ0L(22UH)L1002INDUCTORBLQM2HPN2R2MG0LED302LED_4EHP-69/GT01C-P01/TRMIC401MIC_/_SPM0410HR5H-PBSPM0410HR5H-PBREC401REC_/_2403_260_00031RECEIVE/SMD/NXPSPK401MICDMSP1115KJ-10-F1-GSW901SL1104_0U201MT6588E1_LPDDR2U301MT6320E1MT6320E1U302Q_/_SSM3K35MFV2-1L1B/SSM3K35MFVU303FDG6303_2SC70-6U304Q_/_SSM3K35MFV2-1L1B/SSM3K35MFVU401NJG1649HB6NJG1649GB6/SMDU402FSA8049NJG1649GB6/SMDU501LP_DDR2(JEDEC_162B)_6U601TCVCXO_12TCVCXO_5X3MT6167U602SAW_1BSAFEA1G84FA0F00R14U605SAW-DPX-RX-BALSAYFH836MCA0F00U611SAW_1BSAFEA2G14FF0F00U612XM0860SH-DL0601_0SKY13380U613XM0860SH-DL0601_3U614TCVCXO_3TCVCXO_5X3U616SAW-DPX-RX-BALU701RF3145_0U702PA_/_SKY77590_0SKY77590U709SKY77701_1U710XM0860SH-DL0601XM0860SH-DL0601U713SKY77701_0U801EN1G84CW0F00R14_0SAWEN1G84CW0F00R14SAW / EN1G84CW0F00R14U804RF9802_0U805MT6168_0U806TCVCXO_0TCVCXO_5X37M26000028U808CAR/MM8130-2600MM8130-2600U810RFMD_RF6285_1BRF1131U811RFMD_RF6285_1ASKY77709U812SAW_0U813SAW_1ASAFEA2G34FA1F00(P)U814RFMD_RF6285_1AU815SAW_0U901APL5151_6SOT23-5U902GT800_4U903RP109Q12SC-88AU1001MT6628_E1_WLCSPMT6628MT6628_E1_WLCSPU1002NJG1107HB3_0MSOIC10/SMDU1005TCXO_RAKON_SMD_4POSC/SMD/D1.3X2.1RAKON/IT2205BE/26MHzU1006FB_/_BLM15AX221SN1L0402FB / BLM15AX221SN1U1007DGLT36M07_0SAW/DGLT36M07/SU1101SII_8338_0SiI 8338U1201MT3301-140BGA388/SMDU1301IF258_QFNQFN32/SMD/IF258/SU1401MS110-C10B-C13-A_2U1501TP-SS011-014-05-815U1601BMC050LGA-16U160274ALVC74PW_1MPU-3050U1603CM3623U1801YDA145_0U1901TMP103AYFFTTMP103AYFFTVIB301GH-4135_2X301CRYSTAL_132K (MS3V-T1R)X601TCVCXO_2TCVCXO_5X3X / 26MHz / TZ1689AX1201QUARTZ_IQX0_1QUARTZ 27.12 MhzY1301TCXO_0OSC5035
评分
参与人数 1威望 -5 收起 理由
ymyuki -5 没有按版规截图。请认真阅读版规发帖。下不为例
查看全部评分
重要提示:PCB作品文件展下载说明
miaomiao | 2016-10-22 07:45:37 | 显示全部楼层
xidgli | 2016-10-22 08:31:35 | 显示全部楼层
zhoujian198909 | 2016-10-22 08:58:39 | 显示全部楼层
wangdanq | 2016-10-22 10:24:37 | 显示全部楼层
谢谢楼主分享   学习一下
木子清风 | 2016-10-22 10:25:39 | 显示全部楼层
木子清风 | 2016-10-22 10:26:46 | 显示全部楼层
xzcxnihd | 2016-10-22 16:17:59 | 显示全部楼层
一直觉得画手机的人好牛逼
shuai1979 | 2016-10-23 15:48:19 | 显示全部楼层
fairy0212 | 2016-10-25 09:27:27 | 显示全部楼层
