BMA250驱动
查看626 | 回复1 | 2016-10-21 22:34:48 | 显示全部楼层 |阅读模式
#include "bma250.h"
//#define USE_SPI_SIMULATION
* DEFINES
// Accelerometer connected at (names in brackets are BMA250 names)
// P2_0 = VDD (VDD/VDDIO)
// P1_2 = CS_N (CSB)
// P1_3 = SCK (SCx)
// P1_4 = MISO (SDO)
// P1_5 = MOSI (SDx)
// P1_7 = (INT1)
#ifndef  USE_SPI_SIMULATION
#define CS              P1_2
#define SCK             P1_3
#define MISO            P1_4
#define MOSI            P1_5
#else
//#define CS              P1_5
//#define SCK             P1_4
//#define MISO            P1_3
//#define MOSI            P1_2
#define CS              P1_2
#define SCK             P1_3
#define MISO            P1_4
#define MOSI            P1_5
#endif
#define CS_DISABLED     1
#define CS_ENABLED      0
// OR bitmask into reg (read, modify, write)
#define ACC_INT_ENABLE(reg, bm)     { uint8 val; accReadReg((reg),&val); \
                                      val |= (bm); accWriteReg((reg),val); }
// AND inverted bitmask into reg (read, modify write)
#define ACC_INT_DISABLE(reg, bm)    { uint8 val; accReadReg((reg),&val); \
                                      val &= ~(bm); accWriteReg((reg),val); }
* FUNCTION PROTOTYPES
void spiWriteByte(uint8 write);
void spiReadByte(uint8 *read, uint8 write);
* LOCAL VARIABLES
extern  uint8 acc_initialized = FALSE;
* FUNCTIONS
* @fn       accInit(void)
* @brief    Initialize SPI interface and BMA250 accelerometer.
* @return   void
void accInit(void)
    //*** Enable Accelerometer power ***
    P2DIR |=  0x01;     // Set P2_0 as output high
    P2SEL &= ~0x01;
    P2    |=  0x01;
    //*** Setup USART 0 SPI at alternate location 2 ***
    // USART 0 at alternate location 2
    PERCFG |= 0x01;
    // Peripheral function on SCK, MISO and MOSI (P1_3-5)
    P1SEL |= 0x38;
    // Configure CS (P1_2) as output
    P1DIR |= 0x04;
    CS = CS_DISABLED;
    //*** Setup the SPI interface ***
    // SPI master mode
    U0CSR = 0x00;
    // Negative clock polarity, Phase: data out on CPOL -> CPOL-inv
    //                                 data in on CPOL-inv -> CPOL
    // MSB first
    U0GCR = 0x20;
    // SCK frequency = 3MHz (MBA250 max=10MHz, CC254x max = 4MHz)
    U0GCR |= 0x10;
    U0BAUD = 0x80;
#else
    //P1SEL &= ~0x3C; //P1_2,P1_3,P1_4,P1_5 作为普通IO口
    //P1DIR |= 0x34;  //P1_2,P1_4,P1_5 输出
    //P1DIR &= ~0x08; //P1_3 输入
    //P1INP &= ~0x3C; //使用上拉功能
    //P2INP &= ~0x40;
    //CS = CS_DISABLED;
    //SCK = 1;
    //MOSI = 1;
    P1SEL &= ~0x3C;
    P1DIR |= 0x2C;
    P1DIR &= ~0x10;
    CS = CS_DISABLED;
    SCK = 1;
    MOSI = 1;
#endif
    // *** Configure accelerometer ***
    // Wait 2ms for accelerometer to power up and settle
    WAIT_MS(2);
    // Disable all interrupts
    ACC_INT_DISABLE(ACC_INT_ENABLE0, 0xFF);
    ACC_INT_DISABLE(ACC_INT_ENABLE1, 0xFF);
    // Set 2G range
    accWriteReg(ACC_RANGE, ACC_RANGE_2G);
    // Filter detection bandwidth (Time between samples = 1/(2*filter_bw))
    accWriteReg(ACC_BW, ACC_BW_31_25HZ);
#ifdef ENABLE_BMA250_INTERRUPT
    // *** New data interrupt on INT1, active high ***
    // INT1 as push-pull, active high
    accWriteReg(ACC_INT_PIN_BEHAVIOR, ACC_INT1_LVL);
    // Map New data interrupt to INT1
    accWriteReg(ACC_INT_MAPPING1, ACC_INT1_MAP_DATA);
    // Enable new data interrupts
    ACC_INT_ENABLE(ACC_INT_ENABLE1, ACC_INT_DATA_EN);
#endif
    acc_initialized = TRUE;
} // accInit
* @fn       accStop(void)
* @brief    Sets the BMA250 accelerometer in low-power mode.
* @return   void
void accStop(void)
  if (acc_initialized) {
    // We cheat and simply turn off power to the accelerometer
    P2_0  =  0x00;  // If init has been run this pin is already output.
* @fn       accWriteReg(uint8 reg, uint8 val)
* @brief    Write one byte to a sensor register
* @param    reg     Register address
* @param    val     Value to write
* @return   void
void accWriteReg(uint8 reg, uint8 val)
    CS = CS_ENABLED;
    spiWriteByte(reg);      // Write address
    spiWriteByte(val);      // Write value
    CS = CS_DISABLED;
* @fn       accReadReg(uint8 reg, uint8 *pVal)
* @brief    Read one byte from a sensor register
* @param    val     Pointer to destination of read value
* @return   void
void accReadReg(uint8 reg, uint8 *pVal)
    CS = CS_ENABLED;
    spiWriteByte(0x80|reg);     // Write address
    spiReadByte(pVal, 0xFF);    // Write dummy data and read returned value
    CS = CS_DISABLED;
* @fn       accReadAcc(int16 *pXVal, int16 *pYVal, int16 *pZVal)
* @brief    Read x, y and z acceleration data in one operation.
* @param    pXVal   Pointer to destination of read out X acceleration
* @param    pYVal   Pointer to destination of read out Y acceleration
* @param    pZVal   Pointer to destination of read out Z acceleration
* @return   void
void accReadAcc(int8 *pXVal, int8 *pYVal, int8 *pZVal)
    int8 readout[6] = {0,0,0,0,0,0};
    // Read all data from accelerometer
    CS = CS_ENABLED;
    spiWriteByte(0x80|ACC_X_LSB);     // Write start address
    for(uint8 i = 0; i<6; i++)
        spiReadByte((uint8 *)&readout, 0xFF); // Read byte
    CS = CS_DISABLED;
    // Use only most significant byte of each channel.
    *pXVal = readout[1];
    *pYVal = readout[3];
    *pZVal = readout[5];
} // accReadAcc
* @return   void
void accReadAcc16(int16 *pXVal, int16 *pYVal, int16 *pZVal)
    CS = CS_ENABLED;
    CS = CS_DISABLED;
    // Merge high byte (8b) and low bits (2b) into 16b signed destination
    *pXVal = ( (((uint8)readout[0]) >> 6) | ((int16)(readout[1]) << 2) );
    *pYVal = ( (((uint8)readout[2]) >> 6) | ((int16)(readout[3]) << 2) );
    *pZVal = ( (((uint8)readout[4]) >> 6) | ((int16)(readout[5]) << 2) );
} // accReadAcc16
* @fn       spiWriteByte(uint8 write)
* @brief    Write one byte to SPI interface
* @param    write   Value to write
        U0CSR &= ~0x02;                 // Clear TX_BYTE
        U0DBUF = write;
        while (!(U0CSR & 0x02));        // Wait for TX_BYTE to be set
#else
     uint8 i = 0;
     SCK = 1;
     asm("NOP");
     asm("NOP");
     for(i = 0;i<8;i++)
        if(write&0x80)
            MOSI = 1;
        else
            MOSI = 0;
        SCK = 0;
        asm("NOP");
        asm("NOP");
        asm("NOP");
        asm("NOP");
        SCK = 1;
        asm("NOP");
        asm("NOP");
        asm("NOP");
        asm("NOP");
        write <<=1;
#endif
* @fn       spiReadByte(uint8 *read, uint8 write)
* @brief    Read one byte from SPI interface
* @param    read    Read out value
        U0DBUF = write;                 // Write address to accelerometer
        *read = U0DBUF;                 // Save returned value
#else
        uint8 i = 0;
        uint8 tempValue = 0;
        uint8 portValue = 0;
        SCK = 1;
        asm("NOP");
        for(i = 0;i<8;i++)
            if(write&0x80)
              MOSI = 1;
            else
              MOSI = 0;
            SCK = 0;
            write <<= 1;
            asm("NOP");
            asm("NOP");
            asm("NOP");
            asm("NOP");
            SCK = 1;
            asm("NOP");
            tempValue <<= 1;
            portValue = MISO;
            if(portValue&0x01)
                tempValue += 0x01;
            else
                tempValue += 0;
            asm("NOP");
            asm("NOP");
            asm("NOP");
        *read = tempValue;
#endif
xfzc | 2016-10-22 09:23:07 | 显示全部楼层
