重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | ANT-PAD-1 | ANT | ANT-PAD-1 | | AVDD(+10V) | TESTPOINT-1 | TESTP-1.0N | CCFL_EN | CON1 | CON-20 | CON-20PIN-2.2MM | | CON2 | CON-24 | CON-24PIN-2.2MM | | CON3 | CON-PWR | CON-16-PWR-V | | CON4 | CON-SMT-2PIN | CON-2PIN-SOJ-1.25 | | CON5 | CON-SMT-8PIN | CON-8PIN-SOJ-1.25 | | CON6 | CON-SMT-8PIN | CON-8PIN-SOJ-1.25 | | CON8 | CON-SMT-2PIN | CON-2PIN-SOJ-1.25 | | CON9 | CON-5PIN-1.25 | CON-5PIN-SOJ-1.25 | | CON11 | CON-SMT-4PIN | FPC-4P-1.0 | | CON12 | NAVI_CONN_B_TO_B_80PIN_0.8MM | B_TO_B_HEADER_80_0.8MM-YF | | CON13 | CON-SMT-10PIN | CON-10PIN-SOJ-1.25-CL | | CON14 | CON-5PIN-1.25 | CON-5PIN-SOJ-1.25 | | CON15 | CON-SMT-12PIN | FPC-12PIN-0.5MM | | CON17 | CON-SMT-50PIN | FPC-50PIN-0.5MM | | CON18 | CON-SMT-42PIN | FPC-42PIN-0.5MM | | D1 | DIODE | SOD-106 | SS16 | D2 | DIODE | SOD-323 | 1N4148 | D3 | D3 | SM-C-DO-SS33 | | D11 | DIODE | SOD-323 | 1N4148 | D14 | DIODE | SOD-106 | 1N4004 | D15 | DIODE | SOD-323 | 4148 | D16 | DIODE | SOD-323 | 4148 | D17 | DIODE | SOD-323 | 4148 | D18 | DIODE | SK28 | SK34 | D19 | DIODE | SOD-323 | 1N4148 | D20 | DIODE | SOD-323 | 4148 | D23 | DIODE | SOD-323 | SOD106 | D24 | TVS_DIODE | TVS_DIODE_DIP | TVS_DIODE | D51 | D51 | SM-C-DO-SS33 | SK34 | D54 | DIODE | SOD-323 | 1N4148 | D55 | DIODE | SOD-323 | 1N4148 | DIM | TESTPOINT-1 | TESTP-1.0N | CCFL_EN | FB1 | FB | FB0603 | 1K8 | FB3 | FB | FB0603 | 600R | FB5 | FB | FB0603 | 33R | FB7 | FB | FB0603 | 1K8 | FB9 | FB | FB0603 | 1K8 | FB13 | FB | IND-SMT-1206 | 300R | FU1 | FUSE | FUSE-1210 | 0.75A | FU4 | FUSE | FUSE-1210 | 0.75A | IC1 | 74HC4052 | TSSOP-16 | | IC2 | NJM2794 | TSSOP-14 | | IC3 | 74HC4052 | TSSOP-16 | | IC6 | BA3121F | SOP-8 | | IC9 | USB2512 | QFN36 | | IC12 | MP1542 | MSOP-8 | MPS1542 | IC13 | BLUETOOTH-2 | BLUETOOTH_2 | | IC14 | LDO_78DXX | TO-252 | 78D08/78D09 | IC15 | RT9293 | SOT-23-6 | | IC16 | LD1117 | TO-252 | LD1117(3V3) | IC17 | NJM2794 | TSSOP-14 | | IC18 | MPS2841 | MSOP-8 | | IC31 | IRF7205 | SOP-8 | | IC40 | AMPLIFIER | SOP-8 | | IC41 | NJM2505 | SOT-23-5 | | IC45 | FMS6502 | TSSOP-24 | | IC61 | STM8-80 | STM8_SSOP80 | STM8-80 | IC63 | LP2950 | SOP-8 | | IC80 | NJW1222 | SSOP32 | | J1 | CON-SMT-7PIN | FPC-7PIN-0.5MM | | J4 | CON-2PIN-SOJ-1.25 | CON-2PIN-SOJ-1.25 | | JP1 | JUMP | JUMP-2.0 | | L1 | L | IND-SMT-1210 | 470uH | L2 | L | FB0603 | 0R | L3 | DL | DU_INDUCTOR | 3.3uH | L4 | CDH8B28 | CDH-125 | 15uH | L5 | L | IND-SMT-0805 | 600R | L6 | FB | FB0805 | 0R 0805 | L7 | L | FB0805 | 0805 26R ′??é0.5A | L8 | L | FB0805 | 0805 26R ′??é0.5A | L9 | L | IND-SMT-1210 | 470uH | L15 | L | FB0603 | 0R | L17 | L | CDH3B16B | 22UH CDH3B16B | L29 | FB | FB0805 | 0R 0805 | L31 | L | CDH4B28 | 100UH CDH4B28B | L62 | L62 | FB0603 | | L63 | L63 | FB0603 | | MPS1 | MPS4461 | MP4461 | | NR1 | NR | NR0603 | | P12V | TESTPOINT-1 | TESTP-1.5-A | | P_CTL | TESTPOINT-1 | TESTP-1.5-A | | Q1 | TRANS-NPN | SOT-23 | 2N3904 | Q2 | TRANS-NPN | SOT-23 | 2N3904 | Q3 | TRANS-NPN | SOT-23 | 2N3904 | Q4 | KRC402 | USM | KRC402 | Q5 | 6402 | SOT-23-MOSFET | | Q6 | KRC402 | USM | KRC402 | Q7 | KRC402 | USM | KRC402 | Q8 | KRC402 | USM | KRC402 | Q9 | TRANS-NPN | SOT-89 | 2SC4375 | Q10 | TRANS-PNP | SOT-23 | 2N3906 | Q11 | TRANS-PNP | SOT-89 | 2N3906 | Q12 | TRANS-NPN | SOT-23 | 2N3904 | Q14 | TRANS-NPN | SOT-23 | 2N3904 | Q15 | TRANS-NPN | SOT-23 | 2SC4375 | Q19 | IRLML6402 | SOT-23-MOSFET | | Q20 | TRANS-NPN | SOT-23 | 2N3904 | Q24 | TRANS-PNP | SOT-23 | 2N3906 | Q25 | TRANS-NPN | SOT-23 | 2N3904 | Q26 | TRANS-NPN | SOT-23 | 2N3904 | Q29 | KRC402 | USM | KRC402 | Q31 | TRANS-PNP | SOT-23 | 2N3906 | Q32 | KRC402 | USM | KRC402 | Q33 | IRLML6402 | SOT-23-MOSFET | | Q35 | TRANS-NPN | SOT-23 | 2N3904 | Q36 | TRANS-NPN-EP | USM | KRC402 | Q42 | KRC402 | USM | KRC402 | Q45 | KRC402 | USM | KRC402 | Q52 | TRANS-PNP | SOT-23 | 2N3906 | Q56 | KRC402 | USM | KRC402 | Q59 | DTC314-NPN | SC-59 | SC3265 | Q60 | DTC314-NPN | SC-59 | SC3265 | Q64 | DTC314-NPN | SC-59 | SC3265 | Q65 | TRANS-NPN | SOT-23 | 2N3904 | Q66 | DTC314-NPN | SC-59 | SC3265 | Q68 | TRANS-PNP | SOT-23 | 2N3906 | Q70 | TRANS-NPN | SOT-23 | 2N3904 | TP22 | TESTPOINT-1 | TESTP-1.5-A | | U1 | KIA7029 | SOT-89 | KIA7035AF | U2 | USB_L | USB_L | | U4 | RT9167-3.3 | SOT-25 | | U5 | LM4853 | MSOP10 | LM4853 | U7 | USB_L | USB_L | | U12 | USB_L | USB_L | | VCOM | TESTPOINT-1 | TESTP-1.0N | CCFL_EN | VGH | TESTPOINT-1 | TESTP-1.0N | CCFL_EN | VGL | TESTPOINT-1 | TESTP-1.0N | CCFL_EN | Y1 | XTAL | HC49US-SMT | 24M 50ppm | Y6 | XTAL | HC49US-SMT | 8M | ZD46 | BAS70-04_1 | SOT23 | | ZD47 | BAS70-04_1 | SOT23 | | ZD48 | SOD-323A | SOD-323A | 9V1 | ZR1 | TL431 | SOT-23 | TL431 | ZR2 | TL431 | SOT-23 | TL431 |
重要提示:PCB作品文件展下载说明
