重要提示:PCB作品文件展下载说明
请输入描述
Name | Part Type | PCB Decal | Value | CON1 | CON-SMT-40PIN | SFPC-40PIN-0.5MM | | CON2 | CON-SMT-2PIN | SCON-2PIN-1.25MM-V | | CON3 | CON-SMT-4PIN | SCON-4PIN-1.25MM-V | | CON4 | CON-SMT-40PIN | SFPC-40PIN-0.5MM | | CON5 | CON-SMT-4PIN | SCON-4PIN-1.25MM-V | | CON6 | CON_SMT_60PIN | SFPC-60PIN-0.5MM | | CON7 | CON4P-SMD | SCON-2PIN-6.5MM | | CON8 | CON-SMT-50PIN | SFPC-50PIN-0.5MM | | CON15 | CON-SMT-4PIN | SCON-4PIN-1.25MM-V | | CON17 | CON-SMT-2PIN | SCON-2PIN-1.25MM-V | | CON18 | CON-SMT-20PIN | SFPC-20PIN-0.5MM | CON-SMT-20PIN | CON19 | CON-SMT-20PIN | SFPC-20PIN-0.5MM | CON-SMT-20PIN | CON21 | FPC4-1.0 | SFPC-4PIN-1.0MM | | D1 | DIODE | SD-SOD106 | SK34 | D36 | DIODE | SD-SOD106 | 4148 | ESD81 | ESD0603 | SD-ESD0603 | PJSD05TS | IC1 | AIC1896 | SOT23-6A | AT9293 | IC3 | AIC1896 | SOT23-6A | AT9293 | IC4 | LD117 | SOT223 | LD117-3.3V | L1 | L | SL0805 | BEAD/600 | L2 | INDUCTANCE | SPL040418 | 22UH CDH3B16B | L3 | L | SL0805 | BEAD/600 | L4 | L | SL0805 | BEAD/600 | L50 | L | SPL040418 | 22UH CDH3B16B | L51 | L | SL0805 | 600R | L52 | FB | SL0805 | FB600 | L53 | FB | SL0805 | FB600 | L56 | L | SL0805 | BEAD/600 | L57 | L | SL0805 | BEAD/600 | L59 | L | SL0805 | 100uH | L60 | L | SL0805 | 100uH | LED+1 | TEST_POINT_1 | TESTP-1.0-A | TP | LED+2 | TEST_POINT_1 | TESTP-1.0-A | TP | LED+3 | TEST_POINT_1 | TESTP-1.0-A | TP | LED+4 | TEST_POINT_1 | TESTP-1.0-A | TP | LED-1 | TEST_POINT_1 | TESTP-1.0-A | TP | MIC+ | TP | TP-R1.5 | TP | MIC- | TP | TP-R1.5 | TP | Q1 | TRANS-NPN-8050 | SOT23-A | 8050 | Q2 | EP | SOT23-B | KRC402 | Q3 | TRANS-NPN-8050 | SOT23-A | 8050 | Q4 | TRANS-NPN-8050 | SOT23-A | 8050 | Q5 | TRANS-NPN_1 | SOT23-A | 3904 | Q6 | TRANS-NPN_1 | SOT23-A | 3904 | Q10 | TRANS-NPN | SOT89 | 2SC4375 | Q33 | MOSFET | SOT23-A | IRLML6402 | Q44 | TRANS-NPN | SOT89 | 2SC4375 | Q45 | TRANS-PNP | SOT89 | 2SB1132 | T5V | TESTPOINT-1 | TESTP-1.0-A | T_+5V | TC14 | C | SC1206 | 22uF/6V3 | TC17 | ECAP | SC1206 | 47uF/16V | TC19 | ECAP | SC1206 | 47uF/16V | TP1 | TESTP-1.0 | TESTP-1.0-A | | TP2 | TESTP-1.0 | TESTP-1.0-A | | TP29 | TEST_POINT_SMD0.6_2 | TESTP-1.0-A | TEST POINT SMD0.6 | TP193 | TEST_POINT_SMD0.6_2 | TESTP-1.0-A | TEST POINT SMD0.6 | U1 | LPD6803 | SOP16-50-150 | | U2 | LPD6803 | SOP16-50-150 | | VCOM | TESTPOINT-1 | TESTP-1.5-A | CCFL_EN | VDD3V3 | TESTPOINT-1 | TESTP-1.0-A | T1 | VGH(+15V)1 | TESTPOINT-1 | TESTP-1.5-A | CCFL_EN | VGL(-7V)1 | TESTPOINT-1 | TESTP-1.5-A | CCFL_EN | ZD1 | ZDIODE | SD-SOD523 | 7v5 | ZD2 | ZDIODE | SD-SOD523 | 7v5 | ZD3 | ZDIODE | SD-SOD523 | 7v5 | ZD4 | ZDIODE | SD-SOD523 | 7v5 | ZD22 | SOT23_BAS70_1 | SOT23-A | | ZD23 | ZDIODE | SD-SOD323 | 7v5 | ZD24 | SOT23_BAS70_1 | SOT23-A | | ZR1 | TL431_1 | SOT23-A | TL431 | ZR2 | TL431_1 | SOT23-A | TL431 |
7寸.7z
(457 KB, 下载次数: 25)
重要提示:PCB作品文件展下载说明
