重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | 1V8 | TP-1.5 | T(L) | TP | 3V3 | TP-1.5 | T(L) | TP | BT-ANT3 | TESTP-1.5-A | | TP | BT_3V3 | TP-1.5 | T(L) | TP | CLK | TESTP-1.0 | | TP | CON1 | FPC-4P-1.0 | 4PIN_1.0mm | CON_4PIN_B | CON2 | CON4P-SMD | | CON4P-SMD | CON3 | CON-2PIN-SOJ-1.25 | | CON-SMT-2PIN | CON4 | CON-4PIN-SOJ-1.25 | | CON-SMT-4PIN | CON5 | CON-2PIN-SOJ-1.25 | | CON-SMT-2PIN | CON6 | FPC-60PIN-0.5MM | | CON_SMT_60PIN | CON7 | FPC-22PIN-0.5MM | | FPC-22PIN-0.5MM | CON8 | CON-4PIN-SOJ-1.25 | | CON-SMT-4PIN | CON11 | DEBUD4 | SOCKET,4P,1.25mm,HORIZONTAL | CON-4P | CON15 | FPC-20PIN-0.5MM | | CON-SMT-20PIN | CON16 | FPC-20PIN-0.5MM | | CON-SMT-20PIN | CSB | TESTP-1.0 | | TP | D1 | FY/D-SMD5P-AA | | FY/ESD-5P-PG05GBUSV | D2 | SOD-106 | SS16 | DIODE | D3 | SOD-323A | 1N4148 | DIODE | D4 | BAV99 | BAV99 | BAV99 | D5 | BAV99 | BAV99 | BAV99 | D6 | SOD-323A | 1N4148 | DIODE | D7 | SOD-323A | 1N4148 | DIODE | D8 | SOD-106 | IN4001 | 1SR154-400 | D9 | SOD-106 | IN4001 | 1SR154-400 | D10 | SOD-106 | IN4001 | 1SR154-400 | D13 | SOD-106 | SS16 | DIODE | D20 | SOD-106 | IN4001 | 1SR154-400 | EC1 | CAP0805 | 10uF | ECAP | EC2 | ECAP-SMT-5.0 | 100uF/6V3 | CAP-E | EC3 | ECAP-SMT-6.5 | 220U/6V3 | CAP-E | EC6 | ECAP-SMT-5.0 | | FY/CAP107-6.3X5.5SMT-AA | EC10 | ECAP-SMT-6.5 | 100uF/16V | CAP-E | EC11 | ECAP-SMT-6.5 | 220uF/6.3V | CAP-E | EC14 | ECAP-SMT-6.5 | 220U/6V3 | CAP-E | EC806 | ECAP-SMT-6.5 | 220uF/6.3V | CAP-E | FB14 | FB0603 | CBG120R | FB | FU1 | FUSE-1210 | 0.75A 1210 | FUSE | FU2 | FUSE-1210 | 0.75A 1210 | FUSE | J4 | FPC-52PIN-0.5MM | | CON-SMT-52PIN | L1 | IND-SMT-CD32 | 10uH | FY/IND-100UH-CD32 | L3 | IND-SMT-CD32 | 100uH/CD32 | IN-L | L4 | IND-SMT-CD32 | 10uH/CD32 | IN-L | L5 | CD32 | 10uH/CD32 | L-SMD | L6 | IND-SMT-0805 | 10uH/0805 | L-SMD | L8 | IND-SMT-0805 | 10uH/0805 | L-SMD | L9 | IND-SMT-0805 | 100uH | L | L10 | IND-SMT-CD43 | 100uH/CDH6B38 | 100UH | L11 | IND-SMT-0805 | 100uH | L | L804 | IND-SMT-CD32 | 10uH/CD32 | IN-L | L806 | CDH4B28 | 4.7uH/4B28/700mA | IN-L1 | L810 | IND-CD43 | 10uH/CD43 | L | LED+ | TP-1.5 | TP | TEST_POINT_1 | LED- | TP-1.5 | TP | TEST_POINT_1 | M105 | SOT-23 | AO3401 | PCHANNEL | MIC+ | TP-1.5 | T(L) | TP | MIC+1 | TP-1.5 | T(L) | TP | MIC- | TP-1.5 | T(L) | TP | MIC-1 | TP-1.5 | T(L) | TP | MISO | TESTP-1.0 | | TP | MOSI | TESTP-1.0 | | TP | PG | TP-1.0 | D+ | TP1 | Q5 | SOT-89 | 1132 | TRANS-PNP | Q8 | SOT-23 | 3904 | TRANS-NPN | Q7101 | SOT-23 | 3904 | TRANS-NPN | TX1 | TP-1.2 | TP | TEST_POINT_1 | U1 | TO-252 | LD1117-1.8(S0T-252) | RT9164 | U2 | TSSOP16 | FST3257MTCXNL | FST3257M | U3 | MX25L6405 | MX25L12805 | M24CXX_0A | U5 | IC-216P-LQFP-24X24 | MST776-I | MST-7702 | U6 | SOT-25 | | MP3302DJ | U7 | SOIC08 | AT24C16 | 24C08_0 | U10 | IC-54P-TSOP2 | SDRAM_8MX16-6 | SDRAM_64M_TSOP54_1 | U11 | SOT23-5 | | FSP3304 | U13 | BC03MMCAAAAOOO | | BC03_MM_MODULE | U21 | TSSOP-16 | 74HCT4052 | 4052 | VDD10V | TP-1.5 | T(L) | TP | VGH15V | TP-1.5 | T(L) | TP | VGL-7V | TP-1.5 | T(L) | TP | VIN | TP-1.0 | D+ | TP1 | VR2 | CAP0603 | 5V5 | VR | Y1 | XTAL-SMD-5X4 | 14.318MHz | XTAL_SHIELD |
重要提示:PCB作品文件展下载说明
