重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | ANT101 | CON2A20TA | 2PIN | ANT12 | BT | 10P_2.0MM2?×ù(2???.?y?ò) | BLUETOOTH | 10P | CD13 | CAP/4.3/SMT | 10uF/10V | DCAPE_1 | CN1 | CON24SMD_1MM | CON24SMD_1MM | CON24P_SMD_1 | CN5 | 8P_2.0MM2?×ù(2???.·′?ò) | 8P | 8P | CN8 | CON24SMD_1MM | CON24SMD_1MM | HEADER_24_1 | CN9 | 11P_2.0MM2?×ù(2???.·′?ò) | 11P | 11P | CON1 | DIP32P2.0 | 32P-2.0MM | GPS607 | CON2 | 40P_2G_0.5MM2?×ù(SMD.·′?ò) | | 40P | CON3 | CON-2P-2MM-V | CON2/2.0 | CON2 | CON4 | CON10-SMD/1.0 | 10P*1.0MM SMD | CON10-SMD/1.0 | CON5 | 13P/2.0 | | 13P | CON6 | 2P | | 2P | CON7 | CON10-SMD/1.0 | 10P*1.0MM SMD | CON10-SMD/1.0 | CON23 | 4P_2.0MM2?×ù(2???.·′?ò) | XR | 4P | D1 | D-SMT-4148 | 4148 | DIO | D2 | SMD-1N4001A | 5822 | DIO | D3 | SMD-1N4001A | 5822 | DIO | D4 | D-SMT-4148 | IN4148 | DIO | D6 | D-SMT-4148 | 4148 | DIO | D7 | D-SMT-4148 | IN4148 | DIO | D8 | D-SMT-4148 | IN4148 | DIO | D9 | D-SMT-4148 | 4148 | DIO | D11 | D-SMT-4148 | 4148 | DIO | D14 | D-SMT-4148 | 4148 | DIO | D16 | D-SMT-4148 | IN4001 | DIO | D601 | D-SMT-4148 | 5822 | DIO | D602 | D6V/DO-201AD | IN5404 | D | E1 | E-4.4MM | 10UF/16V | E | E2 | E-4.4MM | 10uF/16V | EC2 | E3 | CAP+6A | 100uF/16V | EC2 | E4 | CAP+6A | 100uF/16V | EC2 | E5 | E-6.4MM | 47UF/16V | E | E6 | CAP+6A | 100uF/16V | EC2 | E7 | CAP+6A | 100uF/16V | EC2 | E8 | E-4.4MM | 10uF/16V | EC2 | E9 | E-6.4MM | 100UF/16V | E | E10 | CAP+6A | 100uF/16V | EC2 | E11 | E-4.4MM | 22UF/16V | E | E12 | E-4.4MM | 100uF/16V | EC2 | E13 | E-6.4MM | 100UF/6V | E | E15 | CAP+6A | 100uF/16V | EC2 | E16 | E-6.4MM | 100UF/16V | E | E18 | E-6.4MM | 100UF/16V | E | E43 | E-4.4MM | 47uF/16V | EC2 | E45 | E-6.4MM | 100UF/16V | E | E142 | E-4.4MM | 47UF/16V | E | E153 | E-4.4MM | 47UF/16V | E | E165 | E-6.4MM | 100UF/47UF | E | E168 | E-4.4MM | 22UF/16V | E | E169 | E-6.4MM | 100UF/16V | E | E612 | E-13MM | 3300UF/25V | E | E616 | E-5MM | 47UF/16V | E | E629 | E-4.4MM | 47uF/16V | EC2 | E631 | E-6.4MM | 100UF/16V | E | E701 | E-6.4MM | 100UF/6V | E | E702 | E-6.4MM | 100UF/16V | E | E713 | E-4.4MM | 10UF/16V | E | E740 | E-6.4MM | 100uf/16V | E | EC2 | E-6.4MM | 100UF/25V | E | IC1 | PQICZ41 | AP1507 | AP1507 | IC2 | TUNER | CDT-6GPL22 | TUNER | IC3 | PQICZ41 | AP1507 | AP1507 | IC5 | 780X-TO-220AA | 78M05 | 780X | IC6 | TO-92(78?μáD.DC?è?1?ˉ3é?é.2???) | LA78L05 | 78L05 | IC8 | SOP32 | PT2312 | PT2312-32P | IC9 | TC4052 | TC4052 | TC4052 | IC10 | SO-14 | BA7649A | BA7649A | IC305 | SO8 | 4558 | KIA4558 | IC603 | TDA7386A | TDA7384 | TDA7381B | J3 | DIP-16P | μ??′ê?3?×ù | DIP-16P | L1 | 805 | 47UH | L | L2 | HCOIL-A | 47UH | L | L3 | L1206 | 47UH | L | L6 | L1206 | 47UH | L | L7 | HCOIL-A | 47UH | L | L8 | L1210 | 22UH/1.5A | L11 | L9 | L1206 | 22UH/1.5A | L11 | L10 | L1206 | 22UH/1.5A | L11 | L607 | 100MHA | 47UH | L | L703 | 805 | 47UH | L | PAD1 | 660X | | 660X | Q1 | SOT-23 | 3904 | NPN | Q2 | SOT23 | 9014 | NPN | Q3 | TO-92/A | C8550 | PNP | Q4 | SOT-23 | 3904 | NPN | Q5 | SOT23 | 3904 | NPN | Q6 | SOT23 | 9014 | NPN | Q7 | SOT-23 | 3904 | NPN | Q9 | TO/BD435/UP | D772 | PNP | Q11 | 3205 | 3205 | NPN | Q13 | SOT23M1 | 3904 | NPN | Q20 | SOT23 | 3904 | NPN | Q21 | SOT23M1 | C8550 | PNP | Q22 | SOT-23 | 3904 | NPN | Q110 | SOT23M1 | 9014 | NPN | Q603 | SOT23M1 | 3904 | NPN | Q608 | SOT-23 | C3875 | NPN | Q701 | TO-92/A | C8550 | PNP | Q705 | SOT-23 | C8550 | PNP | TU1 | SI4730(êy×?ê?ò?í·)AAAAA | | CON10-A | U1 | QFP100-5 | S3P830 | BU24530-9 | U2 | SOT252 | AIC1117-33 | LT1084/TO_0 | U3 | SOT26 | IA171 | IA171 | U4 | SI4730(êy×?ê?ò?IC) | SI4730/1 | SI4730/31 | U6 | PLQP64 | TMP86FS49AUG | R5F212A8SDFP | U202 | BU1924 | BU1923 | BU1923F | X1 | XTAL-3X8A | 32.768KHz | CRYSTAL1 | X2 | CRY3X8H | 32.768KHz | CRYSTAL1 | X3 | CRY/HC-49 | 4.332M | XT | X702 | XTAL3 | 4.5MHZ | CRYSTAL | Z1 | TO-92MA | T(W)L431 | TL431C | ZD1 | ZD1206 | 3.3V | ZENDIO | ZD2 | ZD1206 | 5.1V | ZENDIO | ZD3 | ZD1206 | 5.6V | ZENDIO | ZD6 | ZD1206 | 10V | ZENDIO | ZD601 | D0805A | 9V1 | ZD |
CAR_PCB.7z
(620 KB, 下载次数: 1)
重要提示:PCB作品文件展下载说明
