重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | 1C1 | C-0603B | 0.1uF | CAP_NP_2 | 1CA1 | EC10 | 100uF/16V | CAPACITOR_POL_0 | 1U1 | RT9166 | RT9166 | SOT-223_3 | 2Q1 | R-SOT3N-0.95-2.80-HX | 9018 | NPN(BEC)_0_2 | 2Q2 | R-SOT3N-0.95-2.80-HX | 8050 | NPN(BEC)_0_2 | 2Q3 | R-SOT3N-0.95-2.80-HX | 8050 | NPN(BEC)_0_2 | 3C1 | C-0603B | 102PF | CAP_NP_2 | 3C2 | C-0603B | 105PF | CAP_NP_2 | 3C3 | C-0603B | 105PF | CAP_NP_2 | 3C4 | C-0603B | 18PF | CAP_NP_2 | 3CA1 | EC10 | 2.2uF/16V | CAPACITOR_POL_0 | 3D1 | SMD1N4148 | 1N4148 | DIODE | 3D2 | SMD1N4148 | 1N4148 | DIODE | 3U1 | SI4731 | BK1080/SI5807P/SI4702/SI4730 | M24CXX_15 | ANT2 | ANT-11A | FM | ANT | BC2 | C-0603B | NC | CAP_NP_2 | CN1 | CON2.0_2PAAAA | NC | CON2-2.0 | CN2 | CON2.0_2PABAA | VIDEO OUT | CON2-2.0 | CN5 | CN10-2.5 | 10P2.54MM | CN10-2.5 | CN6 | CN10-2.5 | 10P2.54MM | CN10-2.5 | CN7 | J7-11 | 11P2.0MM | J11-2 | CN10 | SOCKET-12P | | 12P | CN12 | RC | | RCA_2 | D2 | IN54012 | 1N5401 | DD0 | D3 | SS14 | IN4001 | DIO_0 | D4 | D0805 | 1N4148 | DIODE | D5 | IN5819 | SS14 | DIO_0 | D6 | SS14 | IN4001 | DIO_0 | D8 | ZD0805 | 5.1V | ZENER | D9 | D0805 | 1N4148 | DIODE_0_2 | D11 | D0805 | 1N4148 | DIODE | D12 | ZD0805 | 5.1V | ZENER | D13 | D0805 | 1N4148 | DIODE | EC3 | ECAP2.5SC | 10UF16V | 100UF | EC4 | ECAP2.5SC | 220UF16V | 100UF | EC5 | ECAP2.5SC | 100UF16V | 100UF | EC6 | ECAP2.5SC | 100UF16V | 100UF | EC10 | 805 | 1UF50V | CAP0805 | EC11 | ECAP2.5SC | 47UF16V | 100UF | EC12 | 805 | 1UF50V | CAP0805 | EC13 | 805 | 10UF25V | CAP0805 | EC14 | 805 | 10UF25V | CAP0805 | EC15 | ECAP2.5SC | 47UF16V | 100UF | EC26 | ECAP2.5SC | 100UF16V | 100UF | EC27 | ECAP2.5SC | 100UF16V | 100UF | EC28 | ECAP2.5SC | 100UF16V | 100UF | EC29 | 805 | 10UF16V | CAP0805 | EC30 | 805 | 10UF16V | CAP0805 | EC31 | ECAP2.5SC | 4.7UF16V | 100UF | EC44 | ECAP-5-10A | 2200UF16V | 100UF | FS1 | SMD1812 | SMD-050-15V | SMD1812 | GNG | TPABAA | | PAD | J2 | CON4PIN2.0MMAA | NC | CON4PIN2.0MMAA | J6 | R-0603B | 0R | R | L1 | L-0603 | 1UH | L-0603 | L2 | 150UH | 220UH | EI-20 | L3 | RES-10 | ′??é | L2 | L4 | L-0603 | FB | L-0603 | L5 | L/TC-28LA | 110UH | L/TC-28LA | L6 | L-0603 | FB | L-0603 | L701 | 0805MILA | FB/0805 | L | L702 | L-0603 | FB | L-0603 | MAK1 | MAK | | MAK | P1 | PGNDAAAAAA | 2x4mm | PGND-2# | P2 | PGNDAAAAAA | 2x4mm | PGND-2# | P3 | PGNDAAAAAA | 2x4mm | PGND-2# | Q3 | SOT-23NPN | 9014 | 9014C | Q5 | SOT-23PNP | 9015 | 9015C | Q9 | SOT-23NPN | 9014 | 9014C | Q13 | SOT-23NPN | 9014 | 9014C | Q14 | SOT-23NPN | 9014 | 9014C | Q17 | SOT-23NPN | 9014 | 9014C | Q23 | SOT-23PNP | AO3401 | 9015C | Q24 | SOT-23NPN | 9014 | 9014C | Q29 | SOT-23PNP | 9015 | 9015C | U1 | TSOP-08 | NC | DIP8-SOP | U2 | 7805 | 7809 | 7805 | U3 | 7805 | 7809 | 7805 | U4 | SOT-23PNP | NC | 9015C | U5 | TO-252-5 | SW1507-ADJ | TO-252-5 | U6 | SOT223A | LM1117-1V2 | SOT223A | U7 | SOT223A | LM1117-3V3 | SOT223A | U8 | QFP128-0.5 | S5L5025X02-QO | QFP128-0.5 | U8A | 4558M | 4558 | 4558M | U8A1 | TDA7385 | TDA7388 | TDA7384 | U9 | DIP8-SOP2 | EN25T80 SOP-8 | DIP8-SOP2 | U10 | DIP54-SSOPAA | HY57V641620FTP-7 | DIP54-SSOP | U11 | QFP44P | P9228-AZ | QFP44P | U12 | 2244 | NJM2244 | 2244 | U13 | TSOP-08 | | DIP8-SOP | U102 | SO28M1 | PT2313/SC7313 | TDA-7313 | VCC | TPABAA | | PAD | X1 | XTAL2 | 27MHZ | XTAL2 | XT1 | 32.768K | 32.768K | CRY4.5M | XT2 | 32.768K | 4.19M | CRY4.5M | ZD2 | D0805 | NC | DIODE |
重要提示:PCB作品文件展下载说明
