[IC] AFT18S290-13S datasheet
查看459 | 回复0 | 2017-4-5 12:02:41 | 显示全部楼层 |阅读模式
RF Power LDMOS Transistor
N-Channel Enhancement-Mode Lateral MOSFET
Features• Greater Negative Gate-Source Voltage Range for Improved Class C
Operation
• Designed for Digital Predistortion Error Correction Systems
• Optimized for Doherty Applications
• In Tape and Reel. R3 Suffix = 250 Units, 44 mm Tape Width, 13-inch Reel
AFT18S290-13S.pdf (529 KB, 下载次数: 0)
