[其他器件] MMG3002NT1 datasheet
查看433 | 回复0 | 2017-4-17 16:57:28 | 显示全部楼层 |阅读模式
Heterojunction Bipolar Transistor Technology (InGaP HBT)
Broadband High Linearity Amplifier
Features
 Frequency: 40--3600 MHz
 P1dB: 21 dBm @ 900 MHz
 Small--Signal Gain: 20 dB @ 900 MHz
 Third Order Output Intercept Point: 37.5 dBm @ 900 MHz
 Single Voltage Supply
 Internally Matched to 50 Ohms
 Cost--effective SOT--89 Surface Mount Plastic Package
 In Tape and Reel. T1 Suffix = 1,000 Units, 12 mm Tape Width, 7--inch Reel.
MMG3002NT1.pdf (489 KB, 下载次数: 0)
