[其他器件] MRF6VP3450H datasheet
查看565 | 回复1 | 2017-4-23 18:17:59 | 显示全部楼层 |阅读模式
RF Power Field Effect Transistors
Features
• Characterized with Series Equivalent Large--Signal Impedance Parameters
• Internally Input Matched for Ease of Use
• Qualified Up to a Maximum of 50 VDD Operation
• Integrated ESD Protection
• Designed for Push--Pull Operation
• Greater Negative Gate--Source Voltage Range for Improved Class C
Operation
• RoHS Compliant
• In Tape and Reel. R6 Suffix = 150 Units per 56 mm, 13 inch Reel.
R5 Suffix = 50 Units per 56 mm, 13 inch Reel.
MRF6VP3450H.pdf (1.12 MB, 下载次数: 0)
mass | 2017-4-23 19:06:43 | 显示全部楼层
