[其他器件] MRF7S35120HS datasheet
查看520 | 回复1 | 2017-4-23 18:19:18 | 显示全部楼层 |阅读模式
RF Power Field Effect Transistor
Features• Characterized with Series Equivalent Large--Signal Impedance Parameters
• Internally Matched for Ease of Use
• Qualified Up to a Maximum of 32 VDD Operation
• Integrated ESD Protection
• Greater Negative Gate--Source Voltage Range for Improved Class C
Operation
• RoHS Compliant
• In Tape and Reel. R3 Suffix = 250 Units per 56 mm, 13 inch Reel.
MRF7S35120HS.pdf (772 KB, 下载次数: 0)
bidinghong | 2017-4-24 08:48:03 | 显示全部楼层
look  look 射頻功率场效应管的datasheet
