[IC] MRF8P9300H datasheet
查看412 | 回复0 | 2017-4-23 18:20:30 | 显示全部楼层 |阅读模式
RF Power Field Effect Transistors
Features• 100% PAR Tested for Guaranteed Output Power Capability
• Characterized with Series Equivalent Large--Signal Impedance Parameters
and Common Source S--Parameters
• Internally Matched for Ease of Use
• Integrated ESD Protection
• Greater Negative Gate--Source Voltage Range for Improved Class C Operation
• Designed for Digital Predistortion Error Correction Systems
• Optimized for Doherty Applications
• RoHS Compliant
• In Tape and Reel. R6 Suffix = 150 Units per 56 mm, 13 inch Reel.
MRF8P9300H.pdf (903 KB, 下载次数: 0)
