[其他器件] MRF8S9100H datasheet
查看451 | 回复0 | 2017-4-23 18:21:43 | 显示全部楼层 |阅读模式
RF Power Field Effect Transistors
Features• Characterized with Series Equivalent Large--Signal Impedance Parameters
and Common Source S--Parameters
• Internally Matched for Ease of Use
• Integrated ESD Protection
• Greater Negative Gate--Source Voltage Range for Improved Class C
Operation
• RoHS Compliant
• In Tape and Reel. R3 Suffix = 250 Units per 56 mm, 13 inch Reel.
MRF8S9100H.pdf (535 KB, 下载次数: 0)
