[其他器件] MRF1513N datasheet
查看459 | 回复1 | 2017-4-23 18:23:45 | 显示全部楼层 |阅读模式
RF Power Field Effect Transistor
Features• Excellent Thermal Stability
• Characterized with Series Equivalent Large-Signal
Impedance Parameters
• N Suffix Indicates Lead-Free Terminations. RoHS Compliant.
• In Tape and Reel. T1 Suffix = 1,000 Units per 12 mm,
7 inch Reel.
MRF1513N.pdf (530 KB, 下载次数: 0)
pekyhuang6 | 2017-4-24 08:52:07 | 显示全部楼层
