[其他器件] MRFE8VP8600H datasheet
查看472 | 回复1 | 2017-4-23 18:25:43 | 显示全部楼层 |阅读模式
RF Power LDMOS Transistor
Features Excellent Thermal Characteristics
 High Gain for Reduced PA Size
 High Efficiency for Class AB and Doherty Operations
 Integrated Input Matching. Unmatched Output.
 Extended Negative Gate--Source Voltage Range of –6.0 Vdc to +10 Vdc
MRFE8VP8600H.pdf (361 KB, 下载次数: 0)
mass | 2017-4-23 19:07:50 | 显示全部楼层
