Features• Characterized with Series Equivalent Large-Signal Impedance Parameters
and Common Source Scattering Parameters
• On-Chip Matching (50 Ohm Input, DC Blocked, >5 Ohm Output)
• Integrated Quiescent Current Temperature Compensation with
Enable/Disable Function (1)
• Integrated ESD Protection
• Designed for Lower Memory Effects and Wide Instantaneous Bandwidth Applications
• 225°C Capable Plastic Package
• RoHS Compliant
• In Tape and Reel. R1 Suffix = 500 Units per 44 mm, 13 inch Reel
