[IC] UC2909-EP datasheet
查看485 | 回复1 | 2017-4-23 18:34:28 | 显示全部楼层 |阅读模式
SWITCHMODE LEAD-ACID BATTERY CHARGER
DESCRIPTION
The UC2909 controls lead acid battery charging with a highly efficient average current mode control loop. This chip combines charge state logic with average current PWM control circuitry. Charge state logic commands current or voltage control depending on the charge state. The chip includes undervoltage lockout circuitry to insure sufficient supply voltage is present before output switching starts. Additional circuit blocks include a differential current sense amplifier, a 1.5% voltage reference, a –3.9-mV/°C thermistor linearization circuit, voltage and current error amplifiers, a PWM oscillator, a PWM comparator, a PWM latch, charge state decode
bits, and a 100-mA open collector output driver.
uc2909-ep.pdf (1.18 MB, 下载次数: 0)
pekyhuang6 | 2017-4-24 08:51:50 | 显示全部楼层
