1-1-1框架
  • 项目三作业布线布局
    项目三作业布线布局
  • 意法半导体的三端双向可控硅
    意法半导体的三端双向可控硅
  • 亿光反射式光电开关芯片ITR1204SR10A-TR
  • 如何提升微波网络分析仪的测量精度?
    如何提升微波网络分析仪的测量精度?
  • 14周年庆-发金币,500名额,每人50金币。学堂课程全场半价
[PADS9.5以下] MT7621路由器PCB和原理图 MT7662+MT7603+MT6605+IP1001+WM8960
查看20859 | 回复99 | 2017-4-27 20:24:53 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalPart TypeValue
CON1COAXIAL/SMD/CON/V/I-PEXSMA/UFLRSMA/UFLR/RF
CON2COAXIAL/SMD/CON/V/I-PEXSMA/UFLRSMA/UFLR/RF
CON3DIP3X2/P2.0/F_CONN_6_W/HOUSING_DIP_2_0.54DIP3X2/P2.0
CON5COAXIAL/SMD/CON/V/I-PEXSMA/UFLRSMA/UFLR
CON6COAXIAL/SMD/CON/V/I-PEXSMA/UFLRSMA/UFLR
CON7COAXIAL/SMD/CON/V/I-PEXSMA/UFLRSMA/UFLR
CON8COAXIAL/SMD/CON/V/I-PEXSMA/UFLRSMA/UFLR
D7LED0603LED/0603LED
D9LED0603LED/0603LED
D11D/SMD/P3.325/SOD-123/1N4148DIODE_SK34A_21N4148/NI
D12D/SMD/P6.61/B540CDIODE_SK34A_2B320A/NI
D27DO-214AC/SMD/SM5817ADIODE_SK34ASK34A/NI
D28DO-214AC/SMD/SM5817ADIODE_SK34ASK34A/NI
D29LED0603LED/0603LED
E1ANT/2P/MT7621/GANT-RA-USB-1ANT-MT7621-G
E2ANT/2P/MT7621/GANT-RA-USB-1ANT-MT7621-G
J1DIP7X2/P2.54HEADER_7X2-MALEHeader 7X2-2.54
J2CONSG/54/MINICARD/AS0B22-S68-7F/HALF/FULMINICARD_CARD_HOST_V12_1MiniCard_Card_Host
J4DIP4/P2.54HEADER_4X1_0HEADER 4x1
J5USB/4P/P2.0/DIP/R/F/SUA-110VB-B2NCON_USB-A_RAV_AMP1734775CON,USB-A,RAV
J6CON\DC-JACK\4.7CON3DC JACK
J8USB3.0/9P/DIP/MAINSUPERUSB3_CONNUSB3.0 TypeA_CONN
J10DIP4/P2.54HEADER_4X1_0HEADER 4x1/NI
J11DIP2/P2.54HEADER_4X1_1HEADER 2x1/NI
J302DIP2/P2.54JMP2BNI
J850PHONEJACK/6P/SMD/EJ24-PFHEADSET_0Earphone-GRN
J851PHONEJACK/6P/SMD/EJ24-PFHEADSET_0MIC-Pink
J1601SMA1SMA_PORT_0NFC SMA_PORT
L16L/IND/SMD/VLS252012EL/2.5_2.0VLS2520-2R2M
L18L0201INDUCTORNI
L19L0201INDUCTORNI
L360L0603INDUCTOR_20R
L361L0402INDUCTOR_2Bead 0402(300mA)
L608L1206L/0805_06030
L613L1206L/0805_06030
L616L0805L/0805_06030
L728L/IND/DIP/GDR0810L/GDR101210uH-GDR0810PU-100K
L729L/IND/SMD/LVS252015TL/GDR10122.2uH-LQM2HPN2R2MG0
L730L/IND/DIP/GDR0810L/GDR101210uH-GDR0810PU-100K
L731L/IND/SMD/LVS252015TL/GDR10122.2uH-LQM2HPN2R2MG0
L850L0603L06030R
L851L0603L06030R
L852L0603L06030R
L853L0603L06030R
L1201L/IND/SMD/0603FERRITE_BEAD_SMD_0402560nH
L1202L/IND/SMD/0603FERRITE_BEAD_SMD_0402560nH
L1321L/IND/SMD/VLS252012EL/2.5_2.0VLS2520-2R2M
L1322L0402/FCSL/04026.8pF
L1323L0402/FCSL/04025.6pF
L1324L0402/FCSL/0402NI
L1325L0402/FCSL/04025.6nH
LA5L0402L/0402_20
LA10L0402L/0402_20
LA11L0201INDUCTOR2.7nH
LA12L0201INDUCTORNI
LA13L0402INDUCTOR0.3pF
LA14L0402INDUCTOR0.3pF
OSC1OSC/SMD/3.2X2.5/TSTOSC_3225/SMD12MHz
P1RJ45/8P/DIP/R/8208C-B01RJ45X1_4RJ45X1
P1202PHJ8X4_NPHJ8X4_2PHJ 8*4
Q7D/SMD/P1.9/SOT-23/BAS16LT12N1132_0MMBT3906/NI
Q8D/SMD/P1.9/SOT-23/BAS16LT12N1132_1MMBT3904/NI
Q600SOT-89/SMD/2SB1386BJT_2SB1386-PNP_72SB1386
Q601SOT-89/SMD/2SB1386BJT_2SB1386-PNP_52SB1386
S3SW-TACT\4.5MMSW_PUSHBUTTONIT-1102V
S4SW-2P2T-6.3SW_DPDT_1SW DPDT
T300TRANSFORMER/48P/SMD/GS5014LFXMER_2P_G2PM109NHN4824CG
T301TRANSFORMER/48P/SMD/GS5014LFXMER_2P_G2PM109NHN4824CG
T302TRANSFORMER/24P/SMD/HN2429CGFT20-252B_2FT20-252B
T600TRANSFORMER/24P/SMD/HN2429CGFT20-252B_2FT20-252B
TP600PAD/1P/0.5MMTP-SMD_2SMD
U4MT7662/WSQFN76/SMD/P0.4/9X9/SMT7662E-20121128_0MT7612E
U6MT7621/LFBGA346/P0.65/B0.3/11.7X13.6MT7621AMT7621A
U8SOP8/SMD/P1.27/MX25L3206ESPIFLASH-WINBOND25P16_1MX25L6406EM2I
U10CRYS/SMD/D3.2X2.5/E3SB40/HOSONICXTAL_1.5XTAL 40MHz
U17SOT223-3/SMD/P2.3/AX1007LDO_RT9164A-SOT223_1ZTP1117SA
U21SKY85601SPDT_/_SKYWORKS_/_SKY85601-21SPDT / SKYWORKS / SKY85601-11/NI
U23XTAL-SMD/3.2X2.5XTAL_3.2X2.540MHz/NI
U26FILTER/4P/SMD/TCF0504H90002AF4P-2012/0402_2TCF0504U30002/NI
U27FILTER/4P/SMD/TCF0504H90002AF4P-2012/0402_2TCF0504U30002/NI
U83SOT-143/SMD/G693IC_DET_SOT-143/SC-82ABG693L_R3132Q/NI
U84SOP8/SMD/P1.27/FR9888CAT71990_1AP3503H
U86SOP8/SMD/P1.27/FR9888CAT71990_1AP3503H
U400FBGA96/SMD/P0.8/MICRONIC_DDR3_X16_FBGA-96DDR3-128Mx16
U450TSOP48/SMDTMP_0NAND,Flash,x8,TSOP48/NI
U607QFN64/SMD/P0.5/IP1001IP1001_0IP1001
U614RJ45/8P/DIP/R/8208C-B01RJ-45X1P-NO-SHRJ-45X1P
U642SKY85601SPDT_/_SKYWORKS_/_SKY85601-21SPDT / SKYWORKS / SKY85601-11/NI
U850QFN32/SMD/P0.5/WM8960WM8960WM8960
U851AUDIO/3P/DIP/TX179AFTX179AFTX179AF/NI
U900P-VFBGA153/SMD/P0.5/11.5X13/TOSHIBAEMMCeMMC
U1202MT6605/MQFN32/SMD/P0.4/4X4/SMT3301-140_SMD_PBGA-140_0MT6605 QFN (32 Pins, 0.4mm pitch)
U1205SOT23-5LDO_AP2112AP2127
U1207SOT23-5LDO_AP2112_0AP3418
U1208SOT23-5LDO_AP2112_0AP3418
U1209SOT23-5LDO_AP2112AP2127
U1301MT7603/WSQFN56/SMD/7X7/SMT7603EMT7603E
X601CRYS/DIP/D5X10.6/GB2000025/ECERACRYSTAL-3X9_0DIP 25MHz
X1201CRYS/SMD/FA-128QUARTZ_IQX0_1QUARTZ 27.12 Mhz
X1301CRYS/SMD/D3.2X2.5/E3SB40/HOSONICXTAL_1.5XTAL 40MHz/NI
重要提示:PCB作品文件展下载说明
人人为我,我为人人。希望大家下载资料的同时能回帖支持,你们的支持,是我最大的共享动力。不回帖以后不共享了。哈哈
yangxf0120 | 2017-4-27 20:37:52 | 显示全部楼层
谢谢分享MT7621路由器PCB
layout | 2017-4-27 20:47:47 | 显示全部楼层
PCB文件
MT7621.7z (920 KB, 下载次数: 68)
dengxin123 | 2017-4-27 21:23:48 | 显示全部楼层
1425151571 | 2017-4-28 08:01:26 | 显示全部楼层
zhifang88 | 2017-4-28 08:11:52 | 显示全部楼层
路由器资料本人少接触
riverhill | 2017-4-28 08:12:54 | 显示全部楼层
kbh2006@163.com | 2017-4-28 08:17:07 | 显示全部楼层
lg0556 | 2017-4-28 08:26:21 | 显示全部楼层
佝偻的戒指 | 2017-4-28 08:35:05 | 显示全部楼层
