<strong>第</strong><strong>1</strong><strong>处</strong><strong>:</strong>
P24,图2.6中,LCD的数据总线 VD[23:0],连接到 L1 VD0 的管脚,CPU内管脚名是
VD0/GPC9, 应为
VD0/GPC8. <strong>第</strong><strong>2</strong><strong>处</strong><strong>:</strong>
P60, 倒数第1段第4行,“SP720为ESD(静电放电)和过电压保护的电子保护<strong>陈列</strong>,”,应为“电子保护<strong>阵列</strong>”.<strong>第</strong><strong>3</strong><strong>处</strong><strong>:</strong>
P12, 图2.2中,“Touch <strong>anle</strong> & LCD”,应为“Touch <strong>anel</strong> & LCD”.<strong>第</strong><strong>4</strong><strong>处</strong><strong>:</strong>
P22, "OM[1:0]"的"11"项中,“Test mode,只在芯片出厂<strong>是</strong>使用”,应为“只在芯片出厂<strong>时</strong>使用”.<strong>第</strong><strong>5</strong><strong>处</strong><strong>:</strong>
P195, 第5行中,“而在费尽心思地查找sector的地址,<strong>实践</strong>上它指的是字节地址”,应为“<strong>实际</strong>上它指的是字节地址”.<strong>第</strong><strong>6</strong><strong>处</strong><strong>:</strong>
P72, 倒数第8行和倒数第6行,“<strong>接</strong>快捷键Shift + S”和“<strong>接</strong>快捷键S + N”,应为“<strong>按</strong>快捷键”.<strong>第</strong><strong>7</strong><strong>处</strong><strong>:</strong>
P109, 中间一段第5行,“ARM Linker→<strong>Option</strong>→Image”,应为“<strong>Options</strong>”.<strong>第</strong><strong>8</strong><strong>处</strong><strong>:</strong>
P317, 第3行,“<strong>telnet</strong>>sz vivi zImage root.cramfs imagewrite”,应为“<strong>ztelnet</strong>”.<strong>第</strong><strong>9</strong><strong>处</strong><strong>:</strong>
P18, 倒数第3段第3行,“另外还有<strong>安森美导体</strong>”,应为“<strong>安森美半导体</strong>”.<strong>第</strong><strong>10</strong><strong>处</strong><strong>:</strong>
P26, 第一行的“<strong>上</strong>拉电阻”应该为“<strong>下</strong>拉电阻”。<strong>第</strong><strong>11</strong><strong>处</strong><strong>:</strong>
P149, 图6-13 分频比表格5行6列“FCLK/<strong>2</strong>”应该为“FCLK/<strong>4</strong>”<strong>第</strong><strong>12</strong><strong>处</strong><strong>:</strong>
P422第3行“192.168.0.2”应为“192.168.<strong>1</strong>.2”;第4行“192.168.<strong>0</strong>.1”应为“192.168.<strong>1</strong>.1”<strong>第</strong><strong>13</strong><strong>处</strong><strong>:</strong>
P5 倒数第1、3行 “<strong>STD</strong>”应该为“<strong>SDT</strong>”<strong>第</strong><strong>14</strong><strong>处</strong><strong>:</strong>
P7 第6行 “<strong>JTGA</strong>”应该为“<strong>JTAG</strong>”<strong>第</strong><strong>15</strong><strong>处</strong><strong>:</strong>
P8 第2段最后一行 “<strong>实践</strong>”应该为“<strong>实际</strong>”<strong>第</strong><strong>16</strong><strong>处</strong><strong>:</strong>
P8 倒数第8行 “<strong>Read Hat</strong>”应该为“<strong>Red Hat</strong>”<strong>第</strong><strong>17</strong><strong>处</strong><strong>:</strong>
P9 倒数第4行 “ 费<strong>劲</strong>心血”应该为“费<strong>尽</strong>心血”<strong>第</strong><strong>18</strong><strong>处</strong><strong>:</strong>
P114 “(1)掉电唤醒检测”段落部分
“该段程序通过判断<strong>bit2</strong>以确定处理器是否从掉电模式唤醒....”修改“该段程序通过判断<strong>bit1</strong>以确定处理器是否从掉电模式唤醒....”<strong>第</strong><strong>19</strong><strong>处</strong><strong>:</strong>
P149 倒12行,“2<strong>m_SDIV</strong>”应为“2M_SDIV”
<strong>第</strong><strong>20</strong><strong>处</strong><strong>:</strong>
P162 第二段第5行,“<strong>ST</strong>2410SSB”应为:“<strong>AN</strong>2410SSB”
<strong>第</strong><strong>21</strong><strong>处</strong><strong>:</strong>
P49 第三行“<strong>C8900A</strong>”应为:“<strong>CS8900A</strong>”
<strong>第</strong><strong>22</strong><strong>处</strong><strong>:</strong>
P321 第四行 #include<stdio<strong>.c</strong>>应该改成 #include<stdio<strong>.h</strong>>
<strong>第</strong><strong>23</strong><strong>处</strong><strong>:</strong>
P308 第五行 “tar cvf /<strong>linuetter</strong>/linuetter.tar *”应该为“tar cvf /<strong>linuette</strong>/linuetter.tar *”
<strong>第</strong><strong>24</strong><strong>处</strong><strong>:</strong>
前言第三页第十四行“《<strong>Unix</strong><strong>高级环境</strong>编程》”应为“《<strong>UNIX</strong><strong>环境高级</strong>编程》”<strong>第</strong><strong>25</strong><strong>处</strong><strong>:</strong>
P41图2.24 二极管“<strong>I</strong>N4148”应为“<strong>1</strong>N4148”<strong>第</strong><strong>26</strong><strong>处</strong><strong>:</strong><strong>(需看书确认)</strong>
P439 字节排序函数uint16_t htonl (uint32_t host32bitvalue)--->uint32_t htonl (uint32_t host32bitvalue) uint16_t ntohl(uint32_t net32bitvalue) ----->uint32_t ntohl(uint32_t net32bitvalue) <strong>第</strong><strong>27</strong><strong>处</strong><strong>:</strong>
P301 第14行“Sigfunc *<strong>S</strong>ignal(int signo, Sigfunc *func){”应该为“Sigfunc *<strong>s</strong>ignal(int signo, Sigfunc *func){”<strong>第</strong><strong>28</strong><strong>处</strong><strong>:</strong>
P112
第二行,"否则当<strong>看门</strong>溢出产生"应该为"当<strong>看门狗</strong>溢出"
<strong>第</strong><strong>29</strong><strong>处</strong><strong>:</strong>
P30图2.11中“返回时钟<strong>(须连接上拉电阻)</strong>”应为“返回时钟”<strong>第</strong><strong>30</strong><strong>处</strong><strong>:</strong>
P30图2.11中“数据输出<strong>(须连接上拉电阻)</strong>”修改为“数据输出”<strong>第</strong><strong>31</strong><strong>处</strong><strong>:</strong>
P295 第十一行,第十三行,“#/sbin/<strong>services</strong>”应为“#/sbin/<strong>service</strong>”
<strong>第</strong><strong>32</strong><strong>处</strong><strong>:</strong>
P123 倒数第5行,“<strong>HandlerIR</strong>”应为“<strong>HandlerIRQ</strong>” |
