SGM8291/2/4
High Voltage Rail-to-Rail
Output Operational Amplifiers
The SGM8291 (single), SGM8292 (dual) and SGM8294
(quad) are high voltage operational amplifiers that are
designed to offer a wide input common mode voltage
range and output voltage swing. These devices can
operate from ±2.25V to ±18V dual power supplies or
from +4.5V to +36V single supplies.
The devices feature high slew rate, low input bias and
offset current, low offset voltage and low offset-voltage
temperature coefficient.
The SGM8291/2/4 are specified over the extended -40℃
to +125℃ temperature range. The SGM8291 single is
available in Green SOT-23-5, MSOP-8 and SOIC-8
packages. The SGM8292 dual is available in Green
SOIC-8 and MSOP-8 packages. The SGM8294 quad is
available in Green SOIC-14 and TSSOP-14 packages.
SGM8291datasheet.pdf
(338 KB, 下载次数: 0)
