重要提示:PCB作品文件展下载说明
板子有以下主要元件。
Name | PCB Decal | Value | Part Type | ANT1 | A9BT | | TP-2.0X1.1 | ANT2 | A9BT | | TP-2.0X1.6 | ANT602 | A9GSM | POGO | Z210RF1 | ANT603 | A9GSM | POGO | Z210RF1 | ANT604 | A9GSM | POGO | Z210RF1 | BEAD1001 | BEAD0402 | | FB_/_BLM15AG121SN1 | CN1 | A9CAMERA | | 1300W_CAMERA_LCM | CN2 | A9SIM | SIMF006G5K15-00R | AX161513-06M | CN901 | A9T-FLASH | CAH11-08193-SF01 | CAH11-08193-SF01 | CN902 | A9ZHUPING1 | | LCM_12 | COIN040 | J_COIN_BAT_XH414HGIV01E | battery 20uAh 3.3V | 2800000000 | CON1 | J4TP1 | A5_TP_CON | A5_TP_CON | CON2 | A9XIAOBAN | | CONL15R16 | CON3 | A9MOZU | | A9_CAMERA24-1A9MOZU | CON5 | J5USB | | 10PIN_USB_CON | CON501 | A9ERJI | | JACK006-120L | CON600 | J_RF_MM8430-2600 | MM8130-2602 | TST_PORT_0 | D1 | SOD-523 | NC_D / RB520S-30 | DIODE_SCHOTTKY | D2 | SOD-523 | | DIODE456 | D302 | PZ5D4V2H | MMSZ5231BT1G | DIODE_SCHOTTKY | D305 | SOD-523 | NC_D / RB520S-30 | DIODE_SCHOTTKY | D419 | PESD12VL1B | PESD12VL1B | PESD12VL1B | D420 | PESD12VL1B | PESD12VL1B | PESD12VL1B | D904 | SH_VAR_1_0.6_0.5 | PESD5V0S1BL | 2400000006 | D1051 | RB551V-30 | | RB551V-30 | FEX4 | KKS_R0603 | 500mA | KKS_R0603 | FEX402 | RES0603 | 250mA | RES0603 | L1 | 201 | NC | L_/_39_/_NH_/_0402 | L3 | L/IND/SMD/2520 | | INDUCTOR | L105 | 201 | L / NC / nH / 0402 | IND0402W_7.5NH | L106 | 201 | L / NC / nH / 0402 | L_/_NC_/_0402 | L119 | 201 | L / 2.7 / nH / 0402 | IND0402_4.7NH | L206 | 201 | 0.5pF | CAP0402_0.5PF | L207 | 201 | 2.2nH | IND0402_2.2NH | L301 | L/IND/SMD/2520 | | INDUCTOR | L302 | L/IND/SMD/2520 | 2.2uH | INDUCTOR | L303 | L/IND/SMD/2520 | | INDUCTOR | L304 | L/IND/SMD/2520 | 0.68uH | INDUCTOR | L305 | L/IND/SMD/2520 | 0.68uH | INDUCTOR | L306 | L/IND/SMD/2520 | 2.2uH | INDUCTOR | L408 | R0402 | BLM18PG221SN1D | BLM18SG331TN1D45 | L409 | R0402 | BLM18PG221SN1D | BLM18SG331TN1D63 | L500 | LQH44PN | 10|ìH | L_LQH44PN | L1801 | L/IND/SMD/2520 | 1.0uH | INDUCTOR | NTC301 | R0402 | | NTC_/_NCP15WF104F03RC_/_0402_ | Q1 | VMT3_ROHM | | NPN-DTC143ZM | U1 | A91511 | | AP1511B | U2 | STK3410 | | STK3410 | U3 | SOT23-5 | | LN240623-5 | U4 | ICMEF112P900MFR | ICMEF112P900MFR | ICMEF112P900MFR | U5 | ICMEF112P900MFR | ICMEF112P900MFR | ICMEF112P900MFR | U6 | ICMEF112P900MFR | ICMEF112P900MFR | ICMEF112P900MFR | U7 | SOT23-5 | 3V3 | APL5151 | U8 | ICMEF112P900MFR | ICMEF112P900MFR | ICMEF112P900MFR | U9 | ICMEF112P900MFR | ICMEF112P900MFR | ICMEF112P900MFR | U10 | ICMEF112P900MFR | ICMEF112P900MFR | ICMEF112P900MFR | U11 | UM220 | | UM220 | U12 | PI4ULS5V102 | | PI4-TRAN | U13 | MPU-3050 | MPU-3050 | 74ALVC74PW_1 | U15 | 2-1L1B/SMD/SSM3K35MFV | SSM3K35MFV | MOSFET_N_2 | U16 | SOT-6 | STT818B | FDG6303_2 | U22 | NLAS5223 | NLAS5223 | NLAS5223 | U104 | D6PE1G960P3BP | DPX_3025_forward | D6PE1G960P3BP | U201 | MT6582/VFBGA475 | MT6582 | MT6583E1_LPDDR2_105 | U204 | ACPM-5402 | sky77761 | SKY77761 | U301 | MT6323/VFBGA145 | MT6323 | MT6323/VFBGA145/P0.4/B0.25/5.8X5.8 | U401 | AW8733TQR | AW8733TQR | AW8733TQR | U500 | SOT23-6 | | CP2129 | U501 | Z210FLASH | | Z210FLASH | U504 | ICMEF112P900MFR | ICMEF112P900MFR | ICMEF112P900MFR | U600 | MT6166/TMP/SMD | MT6166 | MT6166/TMP/SMD | U601 | SKY77590 | SKY77590 | PA_/_SKY77590_0 | U1000 | MT6627-NS/MQFN40/SMD/ | MT6627_IPD | MT6611_SMD_WLCSP-61_0 | U1006 | TCXO/SMD/2.5X2.0/IT2205BE | ?MHz | TCXO_RAKON_SMD_4P | U1017 | BMC050 | bmc050 | BMC050 | U1802 | Z210MT6333 | MT6333 | MT6333 | X301 | MS2V-T1S | SSP-T7-F | MC-146_1 | X600 | TCXO3225 | | TCVCXO_2 | XJ2 | SWITCH20279-001E-01 | | 818000157 | Z600 | BALUN/10P/SMD/BD2012 | | SAW_1_2 |
重要提示:PCB作品文件展下载说明
