REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
1C1 | C0805_C0603_TI-10UF/16V | TI-10uF/16V | C0603 |
1C2 | C0603_C0603_TI-4.7UF/16V | TI-4.7uF/16V | C0603 |
1C3 | C0603_C0402_TI-680PF | TI-680pF | C0402 |
1C4 | C0603_C0402_TI-150PF | TI-150pF | C0402 |
1C13 | C0603_C0201_TI-102 | TI-102 | C0201 |
1C20 | C0603_C0402_TI-4.7UF/10V | TI-4.7uF/10V | C0402 |
1C25 | C0603_C0603_TI-10UF/10V | TI-10uF/10V | C0603 |
1C26 | C0402_C0402_TI-47NF | TI-47nF | C0402 |
1C27 | C0402_C0402_TI-4.7UF | TI-4.7uF | C0402 |
1C28 | C0402_C0402_TI-4.7UF | TI-4.7uF | C0402 |
1C29 | C0402_C0402_TI-4.7UF | TI-4.7uF | C0402 |
1C30 | C0402_C0201_TI-0.1UF | TI-0.1uF | C0201 |
1C31 | C0402_C0201_TI-0.1UF | TI-0.1uF | C0201 |
1L1 | L_LVS505020_L-LVS505020_TI-LVS5 | TI-LVS505020-2.2uH | L-LVS505020 |
1R3 | R1206_R0201_TI-NC/100K | TI-NC/100K | R0201 |
1R4 | R0603_R0201_TI-10K | TI-10K | R0201 |
1R5 | R0201_R0201_TI-NC/10K-BQ24196_5 | TI-NC/10K-BQ24196 | R0201 |
1R6 | R0201_R0201_TI-10K_5% | TI-10K | R0201 |
1R7 | R0201_R0201_TI-100K_5% | TI-100K | R0201 |
1R8 | R0201_R0201_TI-270R_5% | TI-270R | R0201 |
1R9 | R0201_R0201_TI-4.02K_5% | TI-4.02K | R0201 |
1R10 | R0201_R0201_TI-100K_5% | TI-100K | R0201 |
1R11 | R0201_R0402_TI-0R/NC_5% | TI-0R/NC | R0402 |
1R12 | R0201_R0402_TI-0R/NC_5% | TI-0R/NC | R0402 |
1R13 | R0201_R0201_TI-27K_5% | TI-27K | R0201 |
1R14 | R0201_R0201_TI-22K_5% | TI-22K | R0201 |
1R15 | R0201_R0201_TI-NC/0R_5% | TI-NC/0R | R0201 |
1R17 | R0201_R0402_TI-0R/NC_5% | TI-0R/NC | R0402 |
1U1 | U_BQ24190RGER_QFN24_TI-BQ24196/ | TI-BQ24196/BQ24297 | QFN24 |
CN10 | CON_AXT530124_CON-AXT530124_BEB | Bebug_AXT530124 | CON-AXT530124 |
CR3509 | DIO_ESD_R0402_ESD7951ST5G_02110 | ESD7951ST5G | R0402 |
CR5111 | DIO_ESD_R0402_LCD-ESD7951ST5G_0 | LCD-ESD7951ST5G | R0402 |
CR5801 | DIO_ESD_R0402_ESD7951ST5G_02110 | ESD7951ST5G | R0402 |
CR5802 | DIO_ESD_R0402_ESD7951ST5G_02110 | ESD7951ST5G | R0402 |
CR5803 | DIO_ESD_R0402_ESD7951ST5G_02110 | ESD7951ST5G | R0402 |
CR5804 | DIO_ESD_R0402_ESD7951ST5G_02110 | ESD7951ST5G | R0402 |
CR5805 | DIO_ESD_R0402_NC/ESD7951ST5G_02 | NC/ESD7951ST5G | R0402 |
CR6601 | DIO_ESD_R0402_3G/LTE-ESD7951ST5 | 3G/LTE-ESD7951ST5G | R0402 |
CR6602 | DIO_ESD_R0402_3G/LTE-ESD7951ST5 | 3G/LTE-ESD7951ST5G | R0402 |
CR6603 | DIO_ESD_R0402_3G/LTE-ESD7951ST5 | 3G/LTE-ESD7951ST5G | R0402 |
CR6604 | DIO_ESD_R0402_3G/LTE-ESD7951ST5 | 3G/LTE-ESD7951ST5G | R0402 |
CR6605 | DIO_ESD_R0402_3G/LTE-ESD7951ST5 | 3G/LTE-ESD7951ST5G | R0402 |
CR7201 | DIO_ESD_R0402_ESD7951ST5G_02110 | ESD7951ST5G | R0402 |
CX1 | C0603_C0603_3G-10UF/6.3V | 3G-10uF/6.3V | C0603 |
CX2 | C0603_C0603_3G-NC/10UF/6.3V | 3G-NC/10uF/6.3V | C0603 |
CX3 | C0402_C0402_3G-NC/0.1UF | 3G-NC/0.1 uF | C0402 |
D2001 | DIO_SCH_SOD-523_MOTOR-SDM20U30_ | MOTOR-SDM20U30 | SOD-523 |
D5102 | D_1N5819HW_SOD-123_LCD-1N5819HW | LCD-1N5819HW | SOD-123 |
D5103 | D_1N5819HW_SOD-123_LCD-1N4148V/ | LCD-1N4148V/1N5819HW | SOD-123 |
D5104 | D_BAT54S_SOT_23_LCD-BAT54S_0211 | LCD-BAT54S | SOT_23 |
D5105 | D_BAT54S_SOT_23_LCD-BAT54S-1200 | LCD-BAT54S-1200*1920/NC-800*1280 | SOT_23 |
D5108 | D_10V_SOD-123_LCD-7.5V-1200*192 | LCD-7.5V-1200*1920/NC-800*1280 | SOD-123 |
D5200 | ESD_RCLAMP0524P_SLP2510P8_TP-TP | TP-TPD4E05U06DQAR/Rclamp0524P | SLP2510P8 |
D5800 | DIO_SCH_SOD-523_SDM20U30_021109 | SDM20U30 | SOD-523 |
D5801 | DIO_SCH_SOD-523_SDM20U30_021109 | SDM20U30 | SOD-523 |
D5802 | ESD_RCLAMP0524P_SLP2510P8_TPD4E | TPD4E05U06DQAR/Rclamp0524P | SLP2510P8 |
D5803 | ESD_RCLAMP0524P_SLP2510P8_TPD4E | TPD4E05U06DQAR/Rclamp0524P | SLP2510P8 |
D8001 | DIO_SCH_SOD-523_MOTOR-SDM20U30_ | MOTOR-SDM20U30 | SOD-523 |
F8201 | F_FUSE[1206-2.5A]_1206-A_F1206H | F1206HI-3000 | 1206-A |
FB5800 | FB0402_L0402_120R PB | 120R PB | L0402 |
FB6001 | FB0402_R0402_GPS-600R_020504009 | GPS-600R | R0402 |
FB6003 | FB0402_R0402_GPS-600R_020504009 | GPS-600R | R0402 |
FB6004 | FB0402_R0402_GPS-600R_020504009 | GPS-600R | R0402 |
FB6601 | FB0402_L0402_3G/LTE-BLM15HD102S | 3G/LTE-BLM15HD102SN1 | L0402 |
FB7010 | FB0402_L0402_120R_0205040099974 | 120R | L0402 |
FB8001 | FB0603_L0603_MOTOR-120R_0205040 | MOTOR-120R | L0603 |
FB8002 | FB0402_L0402_G+A-120R_020504009 | G+A-120R | L0402 |
FB8003 | FB0402_L0402_COMPASS-120R_02050 | COMPASS-120R | L0402 |
FIL6002 | FIL_SAW-856561_SAW-856561_GPS-S | GPS-SAFEA1G58KA0F00 | SAW-856561 |
FIL6003 | FIL_SAW-856561_SAW-856561_GPS-S | GPS-SAFEA1G58KA0F00 | SAW-856561 |
H9701 | CON_ICSRC-5210SFR_CON-ICSRC-521 | ICSRC-5210SFR | CON-ICSRC-5210SFR |
J3501 | TF_0011DAAX09A_TF-0011DAAX09A_0 | 0011DAAX09A | TF-0011DAAX09A |
J5101 | CON40_AYF534035_CON40_AYF534035 | LCD-FPC0510-40B2-G1R/AYF534035 | CON40_AYF534035 |
J5201 | CON10_0.5MM_FG_1.0H_CON10_0_5MM | TP-FP241H-010G10M | CON10_0_5MM_FG_1_0H |
J5501 | CON_FH26-25S-0.3SHW_CON-FH26-25 | FPC0310-25RL-TAG | CON-FH26-25S-0_3SHW |
J5502 | CON_FH26-25S-0.3SHW_CON-FH26-25 | FPC0310-25RL-TAG | CON-FH26-25S-0_3SHW |
J5801 | JP_HDMI-MICRO-46765-1001_HDMI-M | 46765-1301 | HDMI-MICRO-46765-1001 |
J6001 | ANT_WFL-R-SMT_ANT-WFL-R-SMT_GPS | GPS-NC/C168-JL-1663 | ANT-WFL-R-SMT |
J6002 | ANT_PAN00-01120-0107_ANT-PAN00- | GPS-PAN00-01120-0107 | ANT-PAN00-01120-0107 |
J6003 | ANT_PAN00-01120-0107_ANT-PAN00- | GPS-PAN00-01120-0107 | ANT-PAN00-01120-0107 |
J6004 | ANT_PAN00-01120-0107_ANT-PAN0_1 | GPS-NC/PAN00-01120-0107 | ANT-PAN00-01120-0107 |
J6005 | ANT_PAN00-01120-0107_ANT-PAN0_1 | GPS-NC/PAN00-01120-0107 | ANT-PAN00-01120-0107 |
J6201 | ANT_WFL-R-SMT_ANT-WFL-R-SMT_WIF | WIFI-C168-JL-1663 | ANT-WFL-R-SMT |
J6501 | CON_0_CON_246411067000883B_LTE- | LTE-246411067000883B | CON_246411067000883B |
J6502 | ANT_WFL-R-SMT_ANT-WFL-R-SMT_3G- | 3G-C168-JL-1663 | ANT-WFL-R-SMT |
J6601 | SIM_MICRO-SF56S006V4A_SIM-MICRO | 3G/LTE-SF56S006V4A | SIM-MICRO-SF56S006V4A |
J7201 | CON10_0.5MM_FG_1.0H_CON10_0_5_1 | FP241H-010G10M | CON10_0_5MM_FG_1_0H |
J7202 | JP_AUDIO-NJP372-102T_JP-AUDIO-N | PJ-310608/NJP372-103T | JP-AUDIO-NJP472-102T |
J8201 | CON5_HS8805_CON5_HS8805_MH1.25- | MH1.25-5A/HS8805 | CON5_HS8805 |
J8202 | JP_MICROUSB-DX4R005JJE_USB-MICR | DX4R005JJE | USB-MICRO-DX4R005JJE |
J8300 | CON6_AYF530635_CON6_AYF530635_F | FP241H-006G10M | CON6_AYF530635 |
J9902 | CON_JS-CL-1004A_CON-JS-CL-1004A | JS-CL-1004A | CON-JS-CL-1004A |
J9903 | CON_JS-CL-1004A_CON-JS-CL-1004A | JS-CL-1004A | CON-JS-CL-1004A |
J9904 | CON_JS-CL-1004A_CON-JS-CL-1004A | JS-CL-1004A | CON-JS-CL-1004A |
L2000 | IND_ALTSIZE_SML2520_VLS252010CX | VLS252010CX-1R0M-1.0uH | SML2520 |
L2001 | IND_ALTSIZE_SML2520_VLS252010CX | VLS252010CX-1R0M-1.0uH | SML2520 |
L2002 | IND_ALTSIZE_SML2520_VLS252010CX | VLS252010CX-1R0M-1.0uH | SML2520 |
L2003 | IND_ALTSIZE_SML2520_VLS252010CX | VLS252010CX-1R0M-1.0uH | SML2520 |
L2004 | IND_ALTSIZE_SML2520_VLS252010CX | VLS252010CX-1R0M-1.0uH | SML2520 |
L2005 | IND_ALTSIZE_SML2520_VLS252010CX | VLS252010CX-1R0M-1.0uH | SML2520 |
L2006 | IND_ALTSIZE_SML2520_VLS252010CX | VLS252010CX-1R0M-1.0uH | SML2520 |
L2007 | IND_ALTSIZE_SML2520_VLS252010_1 | VLS252010CX-1R0M-1.0uH/TI-NC | SML2520 |
L2008 | IND_ALTSIZE_L-2520_MHCD252012A- | MHCD252012A-1R0M-A8S/VLS252010HBX-1R0M | L-2520 |
L5102 | L_DLP0NSN900HL2L_L-DLP0NS_LCD-N | LCD-NC/MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L5103 | L_DLP0NSN900HL2L_L-DLP0NS_LCD-N | LCD-NC/MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L5104 | L_DLP0NSN900HL2L_L-DLP0NS_LCD-N | LCD-NC/MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L5105 | L_DLP0NSN900HL2L_L-DLP0NS_LCD-N | LCD-NC/MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L5106 | L_DLP0NSN900HL2L_L-DLP0NS_LCD-N | LCD-NC/MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L5107 | L-3_L-2520_LCD-LVF252A12-100M-N | LCD-LVF252A12-100M-N | L-2520 |
L5108 | L-3_L-2520_LCD-LVF252A12-100M-N | LCD-LVF252A12-100M-N | L-2520 |
L5801 | L_DLP0NSN900HL2L_L-DLP0NS_MCZ08 | MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L5802 | L_DLP0NSN900HL2L_L-DLP0NS_MCZ08 | MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L5803 | L_DLP0NSN900HL2L_L-DLP0NS_MCZ08 | MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L5804 | L_DLP0NSN900HL2L_L-DLP0NS_MCZ08 | MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L6001 | L0402_R0402_GPS-NC/0R_021005029 | GPS-NC/0R | R0402 |
L6002 | L0402_R0402_GPS-6.8NH_020708009 | GPS-6.8nH | R0402 |
L6003 | L0402_R0402_GPS-7.5NH_020708002 | GPS-7.5nH | R0402 |
L6004 | L0402_R0402_GPS-0R_021005029999 | GPS-0R | R0402 |
L6201 | L0402_R0402_WIFI-NC | WIFI-NC | R0402 |
L6202 | L0402_R0402_WIFI-NC | WIFI-NC | R0402 |
L6203 | L-3_L-2520_WIFI-AP6330-VLS25201 | WIFI-AP6330-VLS252012-4R7/MLK047B-NC | L-2520 |
L6501 | L_DLP0NSN900HL2L_L-DLP0NS_3G-NC | 3G-NC/MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L6502 | L_DLP0NSN900HL2L_L-DLP0NS_LTE-N | LTE-NC/MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
L6503 | L_LVS505020_L-LVS505020_LTE-ME3 | LTE-ME3960-2.2uH/3.2A | L-LVS505020 |
L6504 | IND_L0402_3G-NC__0207080099955 | 3G-NC | L0402 |
L6505 | IND_L0402_3G-NC__0207080099955 | 3G-NC | L0402 |
L7000 | IND_ALTSIZE_L-2520_LVS252010-1R | LVS252010-1R0M-N-1uH | L-2520 |
L8050 | IND_L0402_SAR-180NH_02070800200 | SAR-180nH | L0402 |
L8051 | IND_L0402_SAR-180NH_02070800200 | SAR-180nH | L0402 |
L8500 | L_DLP0NSN900HL2L_L-DLP0NS_NC/MC | NC/MCZ0806AH900L2TA0G/DLP0NSN900HL2L | L-DLP0NS |
LED2001 | LED_0402_LED0402_LED0402_RED_02 | LED0402_RED | LED0402 |
LX1 | L_LVS404018_L-2520_3G-NC/1239AS | 3G-NC/1239AS-H-1R5N-1.5uH | L-2520 |
MD8000 | MD_ALS6P_MD-ALS6P_MD-ALS6P | MD-ALS6P | MD-ALS6P |
MK1 | MARK_SMTMARK_MARK_ | MARK | SMTMARK |
MK2 | MARK_SMTMARK_MARK_ | MARK | SMTMARK |
MK3 | MARK_SMTMARK_MARK_ | MARK | SMTMARK |
MK4 | MARK_SMTMARK_MARK_ | MARK | SMTMARK |
MK5 | MARK_SMTMARK_MARK_ | MARK | SMTMARK |
MK6 | MARK_SMTMARK_MARK_ | MARK | SMTMARK |
MQ902 | MQ_AG2305GN_SOT_23_LCD-DMP2215L | LCD-DMP2215L | SOT_23 |
MQ903 | MQ_2SK3541_VMT3_LCD-2SK3541_2SK | LCD-2SK3541 | VMT3 |
MQ904 | MQ_AG2305GN_SOT_23_LCD-DMP221_1 | LCD-DMP2215L/NC | SOT_23 |
MQ905 | MQ_2SK3541_VMT3_LCD-2SK3541/NC_ | LCD-2SK3541/NC | VMT3 |
MT1 | HOLE_3_HOLE3D5-1D7_HOLE_N/A | HOLE | HOLE3D5-1D7 |
MT2 | HOLE_3_HOLE3D5-1D7_HOLE_N/A | HOLE | HOLE3D5-1D7 |
MT3 | HOLE_3_HOLE3D5-1D7_HOLE_N/A | HOLE | HOLE3D5-1D7 |
MT4 | HOLE_3_HOLE3D5-1D7_HOLE_N/A | HOLE | HOLE3D5-1D7 |
MT5 | HOLE_3_HOLE3D5-1D7_HOLE_N/A | HOLE | HOLE3D5-1D7 |
MT6 | HOLE_3_HOLE3D5-1D7_HOLE_N/A | HOLE | HOLE3D5-1D7 |
Q2000 | MQ_WPM1481_DFN-6-WPM1481_WPM148 | WPM1481 | DFN-6-WPM1481 |
Q2001 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q2002 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q5201 | MQ_AO3401_SOT_23_TP-DMP2215L_02 | TP-DMP2215L | SOT_23 |
Q5202 | MQ_2SK3541_VMT3_TP-LSK3541_0204 | TP-LSK3541 | VMT3 |
Q5501 | MQ_2SK3541_VMT3_NC/LSK3541_0204 | NC/LSK3541 | VMT3 |
Q5502 | MQ_2SK3541_VMT3_NC/LSK3541_0204 | NC/LSK3541 | VMT3 |
Q5503 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q5504 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q5801 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q5802 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q5803 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q5804 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q6201 | MQ_AO3401_SOT_23_WIFI-NC/DMP221 | WIFI-NC/DMP2215L | SOT_23 |
Q6202 | MQ_2SK3541_VMT3_WIFI-NC/LSK3541 | WIFI-NC/LSK3541 | VMT3 |
Q6501 | MQ_2SK3541_VMT3_LTE-ME936/3G-LS | LTE-ME936/3G-LSK3541 | VMT3 |
Q6502 | MQ_2SK3541_VMT3_3G-LSK3541_0204 | 3G-LSK3541 | VMT3 |
Q6503 | MQ_2SK3541_VMT3_3G-LSK3541_0204 | 3G-LSK3541 | VMT3 |
Q6504 | MQ_2SK3541_VMT3_LTE-LSK3541_020 | LTE-LSK3541 | VMT3 |
Q6505 | MQ_2SK3541_VMT3_LTE-LSK3541_020 | LTE-LSK3541 | VMT3 |
Q6506 | MQ_2SK3541_VMT3_LTE-LSK3541_020 | LTE-LSK3541 | VMT3 |
Q6507 | MQ_2SK3541_VMT3_LTE-LSK3541_020 | LTE-LSK3541 | VMT3 |
Q6508 | MQ_AO3415_SOT_23_LTE-ME936/3G-V | LTE-ME936/3G-VIC1127/RCR1540ESI4.3A | SOT_23 |
Q7201 | MQ_2SK3541_VMT3_NC/LSK3541_0204 | NC/LSK3541 | VMT3 |
Q8001 | MQ_AO3401_SOT_23_MOTOR-DMP2215L | MOTOR-DMP2215L | SOT_23 |
Q8002 | MQ_2SK3541_VMT3_MOTOR-LSK3541_0 | MOTOR-LSK3541 | VMT3 |
Q8003 | MQ_2SK3541_VMT3_G+A-LSK3541_020 | G+A-LSK3541 | VMT3 |
Q8004 | MQ_2SK3541_VMT3_LSK3541_0204010 | LSK3541 | VMT3 |
Q8801 | MQ_2SK3541_VMT3_NC/LSK3541_0204 | NC/LSK3541 | VMT3 |
Q8802 | MQ_2SK3541_VMT3_NC/LSK3541_0204 | NC/LSK3541 | VMT3 |
RT2000 | THERMISTOR_SMR0402_LBNS02-103G3 | LBNS02-103G3R-N-10K | SMR0402 |
RT8200 | THERMISTOR_SMR0402_NC/10K_02100 | NC/10K | SMR0402 |
RX1 | TP_TP_TP | TP | TP |
RX2 | R0201_R0201_NC/0R | NC/0R | R0201 |
SH5002 | SHUNT_0402_SHUNT_0402_SM_LCD-SH | LCD-SHUNT_0402 | SHUNT_0402_SM |
SH6001 | SHUNT_0402_SHUNT_0402_SM_SHUNT_ | SHUNT_0402 | SHUNT_0402_SM |
SH7000 | SHUNT_0402_SHUNT_0402_SM_SHUN_1 | SHUNT_0402 | SHUNT_0402_SM |
SH8000 | SHUNT_0402_SHUNT_0402_SM_SHUN_1 | SHUNT_0402 | SHUNT_0402_SM |
SH8001 | SHUNT_0402_SHUNT_0402_SM_SHUNT_ | SHUNT_0402 | SHUNT_0402_SM |
TX1 | TP_TP_TP | TP | TP |
U1000 | SOC_VLV2_CR_CONCEPT_CUST_WW3_3_ | Z3735F_G | Z3735F-G |
U2003 | AXP288_1P04_QFN-76-AXP288_AXP28 | AXP288_1P04 | QFN-76-AXP288 |
U2004 | SY7088_QFN8-SY7088_SY7088_02011 | SY7088 | QFN8-SY7088 |
U2006 | TPS2553DRVT_LCC6_P65MM_SQ2MM_TP | TPS2553DRVT | LCC6_P65MM_SQ2MM |
U3005 | MT41K256M16_BGA96-H5TC4G63AFR-P | H5TC4G63AFR-PBA-2G/K4B4G1646Q-HYKO(Sumsung)/H5TC2G63FFR-PBA-1G | BGA96-H5TC4G63AFR-PBA |
U3006 | MT41K256M16_BGA96-H5TC4G63AFR-P | H5TC4G63AFR-PBA-2G/K4B4G1646Q-HYKO(Sumsung)/H5TC2G63FFR-PBA-1G | BGA96-H5TC4G63AFR-PBA |
U3101 | MT41K256M16_BGA96-H5TC4G63AFR-P | H5TC4G63AFR-PBA-2G/K4B4G1646Q-HYKO(Sumsung)/H5TC2G63FFR-PBA-1G | BGA96-H5TC4G63AFR-PBA |
U3102 | MT41K256M16_BGA96-H5TC4G63AFR-P | H5TC4G63AFR-PBA-2G/K4B4G1646Q-HYKO(Sumsung)/H5TC2G63FFR-PBA-1G | BGA96-H5TC4G63AFR-PBA |
U3500 | MX25U1635E_1_SOIC-8_GD25LQ64CVI | GD25LQ64CVIGR/W25Q64FWSSIG/MX25U1635E | SOIC-8 |
U3501 | KLMCG8GE2A_BGA169-EMMC_THGBMBG7 | THGBMBG7D2KBAIL-16G/THGBMBG8D4KBAIR(Toshiba)/SDIN9DW4-32G-32G(SanDisk)/SDIN8DE4-64G(SanDisk) | BGA169-EMMC |
U5101 | U_MP3202_SOT-23-6_LCD-RT4533/SG | LCD-RT4533/SGM3732 | SOT-23-6 |
U5103 | TPS22922_1_R-XBGA-N6-0_5MM_LCD- | LCD-TPS22922YZPR | R-XBGA-N6-0_5MM |
U5104 | U_MP1540_SOT-23-5_LCD-MP1540_02 | LCD-MP1540 | SOT-23-5 |
U5500 | VRH2802LTX_0_SOT-23-5-VIC3116-1 | NC/TLV70215DBVR | SOT-23-5-VIC3116-18DK |
U6001 | U_MAX2659_0_DFN-6_GPS-BGU7005/M | GPS-BGU7005/MAX2659 | DFN-6 |
U6002 | U_BCM4752IFBG_BGA49_IC_GPS-BCM4 | GPS-BCM4752IFBG | BGA49 |
U6201 | MD_AP6476_MD-AP6476_WIFI-MLK047 | WIFI-MLK047B/AP6330-AP6330,IEEE802.11a/b/g/n,BT4.0HS,SDIO,L12*W12*H1.5 | MD-AP6476 |
U6501 | MD_MU739_0_MD-MU739_3G-MU739_07 | 3G-MU739 | MD-MU739 |
U6502 | U_MP2145_QFN-12-MP2145_LTE-ME39 | LTE-ME3960-MP2145 | QFN-12-MP2145 |
U7001 | ALC5640_VB_QFN48-0_4MM_ALC5640_ | ALC5640_VB | QFN48-0_4MM |
U7002 | U_SN74LVC1G126DBVR_R-PDSO-G5_DB | NC/SN74LVC1G126DBVR | R-PDSO-G5_DBV |
U7003 | SY7088_QFN8-SY7088_SY7088_02011 | SY7088 | QFN8-SY7088 |
U8001 | KXCJ9-1008_KXCJ9-1008_G-SENSOR- | G-sensor-KXCJ9-1008 | KXCJ9-1008 |
U8002 | U_AK8963C_AK8963C_COMPASS-AK896 | COMPASS-AK8963C | AK8963C |
U8003 | U_MPU6050_0_QFN24_G+A-MPU6050_0 | G+A-MPU6050 | QFN24 |
U8050 | SX9500_QFN20-SX9500_SAR-SX9500_ | SAR-SX9500 | QFN20-SX9500 |
U8500 | TUSB1210_S-PVQFN-N32_ANDROID-TU | Android-TUSB1210/Window8.1-NC | S-PVQFN-N32 |
U8502 | AOZ6184_DPDT_QFN-10-AOZ6184QT_A | AOZ6184_DPDT | QFN-10-AOZ6184QT |
U8503 | U_SN74AVC1T45-DRL_R-PDSO-N6_AND | Android-SN74AVC1T45-DRL/window8.1-NC | R-PDSO-N6 |
UX1 | U_TPS63021_QFN14-B_NC/TPS63021_ | NC/TPS63021 | QFN14-B |
V1 | TP_TP_TP | TP | TP |
VR1 | VR_EVM2NSX80B13_VR-EVM2NSX80B13 | LCD-NC/EVM3ESX50B23/2K | VR-EVM2NSX80B13 |
Y1000 | Y_12MHZ-FA-238V_CRY-SMD-4-CX322 | 7V25070001 18pF | CRY-SMD-4-CX3225SB |
Y1001 | Y_DST210A_CRY-2-2012_1TJG125DR1 | 1TJG125DR1A0019,32.768KHz12.5pF | CRY-2-2012 |
Y6001 | Y_7L26002009_CRY-7L26002009_GPS | GPS-7L26002009 | CRY-7L26002009 |
Y6201 | Y_12MHZ-FA-238V_CRY-SMD-4-CX3_1 | WIFI-AP6330-X3S026000BC1H-NR-26MHz_16pF_10ppm/MLK047B-NC | CRY-SMD-4-CX3225SB |
