重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | D1 | DIODE | SOD123 | 1N5819 | D3 | DIODE_2 | SOD323 | 1N4148 | D7 | DIODE | SOD323 | NC/1N4148 | D8 | DIODE_2 | SOD123 | NC/1N5819 | D9 | DIODE_2 | SOD128 | NC/1N5819 | D10 | DIODE_DUAL | SOT23 | BAT54C | D11 | DIODE | SOD123 | 1N5819 | D12 | DIODE_DUAL | SOT23 | BAT54C | D14 | DIODE_ZENER13_0 | SOD80 | 18V | D15 | DIODE_ZENER13_0 | SOD80 | 7.5V | D19 | DIODE_1_2 | SOT23 | BAT54S | D24 | DIODE_1_2 | SOT23 | BAT54S | D26 | DIODE_2 | SOT23 | BAT54C | EC3 | CAPACITOR_POL_2 | C0603 | 22uF/4V | EC4 | CAPACITOR_POL_2 | C0603 | 22uF/4V | ED3 | DIODE_BI-DIR_TRIG | E0402N | ESD9B5V | ED5 | DIODE_TVS | E0402N | NC/ESD9B5V | ED37 | DIODE_TVS | E0402N | NC/ESD9B5V | FB2 | INDUCTOR_2 | L0603 | FB180R | FB4 | INDUCTOR_2 | L0603 | FB180R | J2 | TF_SD_SOCKET | TF-CARD | TF_SD_SOCKET | J3 | DC-33_0 | 757DC | 757DC | J9 | OV2659 | CON_05MM_24P | OV2659 | J11 | PJ381-2_0 | PJ-311A | 2SJ2271 | J12 | RS7M1609013_0 | RS7M1609013-A | 30P0.5TOP | J13 | MINI_USB | MICRO_USB_NJ2 | USB_JACK | J25 | CON2_2 | R1206 | SPEAK1 | J28 | CON2_2 | R1210 | BACKLIGHT | J29 | CON2_2 | WIFIANT | ANT1 | J30 | CON2_2 | WIFIANT | ANT1 | L1 | INDUCTORS_OF_FERRITE | IND_4X4&3X3 | 4.7uH/1.5A | L9 | INDUCTORS_OF_FERRITE | IND_4X4&3X3 | 10uH/1.5A | L14 | INDUCTOR_0 | IND_4X4&3X3 | 10UH/1.5A | L17 | INDUCTORS_OF_FERRITE | IND_4X4&3X3 | NC/3.3uH/1A | L18 | INDUCTORS_OF_FERRITE | IND_4X4&3X3 | 2.2uH/2A | L19 | INDUCTORS_OF_FERRITE | IND_4X4&3X3 | 2.2uH/1.5A | L20 | INDUCTOR | L0402 | NC | L21 | INDUCTORS_OF_FERRITE | IND_4X4&3X3 | 2.2uH/1.5A | L22 | INDUCTOR | L0402 | NC | L24 | INDUCTOR | L0402 | NC | L25 | INDUCTOR | L0402 | NC | L27 | INDUCTOR | L0402 | NC | L36 | INDUCTOR_2 | L0603 | FB180R | MIC3 | MIC | MIC_4020 | MIC | Q1 | 40852_1 | SOT23 | 8050 | Q6 | MOSFET_P_2 | SOT23 | NC/SI2305 | Q10 | MOSFET_N_0 | SOT23 | WPM2026 | Q13 | MOSFET_N_0 | SOT23 | WPM2026 | Q14 | 40852_1 | SOT23 | 8050 | SW3 | SW4P | SW8 | VOL+(RECOVER) | SW4 | SW4P | SW8 | VOL- | SW9 | SW4P_1 | ST-1114RJ | POWER | SW10 | SW4P_0 | SW-PB3 | RESET | T4 | CAP_NP_0 | MARK | RTCK | T6 | CAP_NP_0 | MARK | RTCK | U1 | MCU_RK2926_LQFP176_1 | LQFP176_16X16 | MCU_RK2926 | U3 | DDRII_3 | FBGA96-10X14 | DDR3_256M_16BIT | U4 | NANDFLASH_0 | TSOP1_48 | NAND_FLASH | U5 | G5121_1 | SOT26 | AP2004H | U6 | DDRII_3 | FBGA96-10X14 | DDR3_256M_16BIT | U7 | DS8008_0 | SOT25 | AP1610 | U8 | LM4990_0 | MSOP8 | HYM8563 | U9 | NANDFLASH_3 | ESP8080_7 | ESP8089 | U12 | MMA7660FC_1 | MMA7660FC | MMA7660FC | U13 | LM4990 | MSOP8 | TCS7191 | U15 | U_MP3202 | SOT26 | AP3127B | U22 | DS8008_6 | SOT25 | NC/AP2415 | U24 | ATC8931A_5 | QFN40L | ACT8931A | U25 | RT9271_0 | SOT26 | TCS3354 | U28 | CLAP070LF02CW_0 | CON50P_0D5MM | LC070LF02CWXXLA | U43 | MXC6225XU | LCC6 | NC/MXC6225XU | U44 | GSL1680_0 | QFN5X5-40PIN | GSL1680/8 | U45 | NANDFLASH8-LGA | VLGA60-13X18 | NANDFLASH-LGA | U80 | RLUM02BS_0 | WIFI_8723AS | WIFI+BT | X1 | XTAL_ELLIP | M49S-SMD | 24MHz | X2 | XTAL_ELLIP | M49S-SMD | 24MHz | Y5 | CRYSTAL-4_0 | CRY_MC146 | nc/32.768KHZ-20ppm | Y7 | CRYSTAL-4_0 | CRY_2X6 | 32.768KHZ-20ppm |
重要提示:PCB作品文件展下载说明
