重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | D7 | SOT23 | BAT54S | SOT23 | D8 | D1206 | 7V | D1206 | D9 | D1206 | 18V | D1206 | D10 | SOT23 | BAT54S | SOT23 | D11 | SOD123 | 1N5819 | SOD123 | D12 | SOD123 | 1N5819 | SOD123 | D24 | SOD323 | 1N4148 | SOD323 | D26 | SMA | DC/SS32 | SMA | D28 | SMA | DC/SS32 | SMA | D29 | SOD123 | DC/1N5819 | SOD123 | D32 | SOD123 | AZ3005-01G | SOD123 | FB11 | L0603 | 0R/600R/100M | L0603 | FB12 | L0603 | NC | L0603 | J1 | 757DC-B | DC5V | 757DC-B | J2 | MICRO_USB_NJ2 | USB | MICRO_USB_NJ2 | J3 | 757TF | TF_SD_SOCKET | 757TF | J6 | PJ-311A | AJ324F-6-S | PJ-311A | J7 | SPKPAD | CON2 | SPKPAD | J8 | FPC40-R-0.5A | AT070TNA2 | FPC40-R-0.5 | J9 | FPC24-0.5 | OV2659 | FPC24-0.5 | J15 | RS7M1609013-A | 30P0.5TOP | RS7M1609013-A | J27 | WIFIANTB | ANT1 | WIFIANTB | J29 | WIFIANTB | ANT1 | WIFIANTB | L2 | IND-3X3 | SWPA3015S1R0NT/1.6A | IND-3X3 | L3 | IND-4X4 | SWPA4020S1R0NT/3A | IND-4X4 | L5 | IND_4X4&3X3 | 10UH/2A | IND_4X4&3X3 | L6 | IND_4X4&3X3 | 10UH/2A | IND_4X4&3X3 | L10 | IND-5X5 | SWPA6020S1R0NT/3.5A | IND-5X5 | L11 | IND-4X4 | SWPA4020S1R0NT/3A | IND-4X4 | L15 | L0402 | NC | L0402 | L16 | L0402 | NC | L0402 | L17 | L0402 | NC | L0402 | L18 | L0402 | NC | L0402 | L37 | R0402 | FB600R | R0402 | L38 | IND-3X3 | SWPA3015S1R0NT/1.6A | IND-3X3 | L39 | IND-4X4 | SWPA4020S1R0NT/3A | IND-4X4 | MARK2 | MARK | MARK | MARK | MARK4 | MARK | MARK | MARK | MARK5 | MARK | MARK | MARK | MARK6 | MARK | MARK | MARK | MIC1 | MIC_4020 | MIC | MIC_4020 | P1 | PAD2X2.5 | BATT+ | PAD2X2.5 | Q1 | SOT23 | DC/8050 | SOT23 | Q8 | SOT23 | 8050 | SOT23 | Q9 | SOT23 | DC/AO3423 | SOT23 | Q14 | SOT23 | AO3423 | SOT23 | Q15 | SOT23 | NC/WPM2026 | SOT23 | Q19 | SOT23 | 8050 | SOT23 | Q27 | SOT23 | 8050 | SOT23 | Q30 | SOT23 | IPS/8050 | SOT23 | Q32 | SOT23 | IPS/AO3423 | SOT23 | Q33 | SOT23 | AO3423 | SOT23 | RP1 | RES-ARRAY0402 | 0R | RESX4 | RP2 | RES-ARRAY0402 | 0R | RESX4 | RP3 | RES-ARRAY0402 | 0R | RESX4 | RP4 | RES-ARRAY0402 | 0R | RESX4 | SHIELD1 | SHIELD-3P | CON5 | SHIELD-3P | SHIELD2 | SHIELD-3P | CON5 | SHIELD-3P | SHIELD3 | SHIELD-3P | CON5 | SHIELD-3P | SHIELD4 | SHIELD-3P | CON5 | SHIELD-3P | SHIELD5 | SHIELD-3P | CON5 | SHIELD-3P | SHIELD6 | SHIELD-3P | CON5 | SHIELD-3P | SW1 | SW8 | VOL+ | SW8 | SW4 | SW8 | VOL- | SW8 | SW6 | SW8 | PWR | SW8 | SW7 | SW-PB3 | RESET | SW-PB3 | U1 | BGA453-19X19 | RK3188 | BGA453-19X19 | U2 | MCP193 | CI_MCP | MCP193 | U3 | SOT25 | PT5108E23E-18 | SOT25 | U9 | SOT23 | DC/CE8808C33M | SOT23 | U13 | WM8988 | ES8323 | WM8988 | U14 | TSOP1-48 | NC | TSOP1-48 | U16 | SOT25 | DC/LPW5206H | SOT25 | U19 | SOT25 | NC/RT9167-30 | SOT25 | U20 | TSOP56 | NC/SN75LVDS83A | TSOP56 | U21 | MSOP8 | NS4150B | MSOP8 | U23 | SOT26 | TCS3354 | SOT26 | U24 | SOT26 | AP3127B | SOT26 | U28 | CON50P_0D5MMA | LC070LF02CWXXLA | CON50P_0D5MM | U40 | MMA7660FC | STK8312 | MMA7660FC | U45 | QFN5X5-40PIN | GSL1680/8 | QFN5X5-40PIN | U80 | WIFI_8723AS | NC/WIFI+BT | WIFI_8723AS | U90 | QFN32 | ESP8089 | ESP8080_7 | U144 | QFN68-7X7 | RK818 | QFN68-7X7 | X1 | M49S-SMD | 24MHZ | M49S-SMD | X2 | M49S-SMD | 26MHZ | M49S-SMD | Y7 | CRY-MC146 | 32.768K | CRY-MC146 |
重要提示:PCB作品文件展下载说明
