[Allegro16.6以下] CX92755-11Z做的楼宇视频对讲控制主板PCB和原理图(CX20707-12ZP
查看6018 | 回复23 | 2017-8-17 19:17:25 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
+12VCCDTP-R_A0438-TP100_TP-RTP-RA0438-TP100
3V3TPTP-R_A0438-TP100_TP-RTP-RA0438-TP100
ALARM1ZIF-24PIN_9_PH-9P-90-1_B9B-PH-KB9B-PH-K-SPH-9P-90-1
ALARM_OUTTP-R_A0438-TP100_TP-RTP-RA0438-TP100
AUDIO_RSTTP-R_A0438-TP100_TP-RTP-RA0438-TP100
AVDDTP-R_A0438-TP100_TP-RTP-RA0438-TP100
BL1TP-R_A0438-TP100_TP-RTP-RA0438-TP100
BL2TP-R_A0438-TP100_TP-RTP-RA0438-TP100
BLOTP-R_A0438-TP100_TP-RTP-RA0438-TP100
BT2BATTERY_HOLDER_2P_ENG_BATLI-1_NNC/HLDR CR2032BATLI-1
CLASDHEADER9_1_B0110-OUPIIN_2112-1XNC/951104-8622-ARB0110-OUPIIN_2112-1X4GFSB-1
CLK1HEADER9_1_B0110-OUPIIN_2112-_1951104-8622-ARB0110-OUPIIN_2112-1X4GFSB-1
CMOS12VPTP-R_A0438-TP100_TP-RTP-RA0438-TP100
CN16AM2321_7_PH-3P-90-1_B3B-PH-K-SB3B-PH-K-SPH-3P-90-1
CTP1ZIF-24PIN_13_CAPTC10PIN0M5_FPC-FPC-1D-10P-BOT?CAPTC10PIN0M5
CTP2ZIF-24PIN_34_CAPTC6PIN0M5-1_FPCFPC-1D-6P-BOT?CAPTC6PIN0M5-1
CVBS&KZIF-24PIN_15_PH-10P-90-1_B10B-PB10B-PH-K-SPH-10P-90-1
D1DIODESCHOTTKY-AK_B0080-SOD-523RB520S30B0080-SOD-523F-AK
D2LED-SINGLE_1_A0143-LED1608X80-1SML-310MTA0143-LED1608X80-12-1
D3LED-SINGLE_A0143-LED1608X80-12-SML-310MTA0143-LED1608X80-12-1
D4DIODESCHOTTKY-AK_B0080-SOD-5_1NC/RB520S30B0080-SOD-523F-AK
D5DIODESCHOTTKY-AK_B0014-DIOM532B240A-13-FB0014-DIOM5329X244-AK
D6LED-SINGLE_A0143-LED1608X80-12_SML-310MTA0143-LED1608X80-12
D7DIODESCHOTTKY-AK_B0014-DIOM532B240A-13-FB0014-DIOM5329X244-AK
D8LED-SINGLE_A0143-LED1608X80-12-SML-310MTA0143-LED1608X80-12-1
D9DIODESCHOTTKY-AK_B0014-DIOM532B240A-13-FB0014-DIOM5329X244-AK
D10LED_K1A2_A0143-LED1608X80-12-1_NC/SML-310MTA0143-LED1608X80-12-1
D11DIODE_1_LL4148-223_LL4148LL4148LL4148-223
D12TVS_1_SS24SMA_EGA10603V05EGA10603V05SS24SMA
D13DIODE_4_SS24SMA_SS24SS24SS24SMA
D14DIODE_2_SS24SMA_SS24SS24SS24SMA
D15DIODE_3_SS24SMA_SS24SS24SS24SMA
D18TVS_SS24SMA_EGA10603V05EGA10603V05SS24SMA
D19DIODE_0_SS24SMA_MBRS240T3MBRS240T3SS24SMA
D20DIODE_5_SS24SMA_MBRS240T3MBRS240T3SS24SMA
D21BAT54S_0_A0271-SOT95P240X122-3_BAT54SA0271-SOT95P240X122-3
D22LED-SINGLE_A0143-LED1608X80-12-SML-310MTA0143-LED1608X80-12-1
D23LED-SINGLE_A0143-LED1608X80-12-SML-310MTA0143-LED1608X80-12-1
D24TVS_SS24SMA_EGA10603V05EGA10603V05SS24SMA
D25DIODE_LL4148-223_LL4148LL4148LL4148-223
D26DIODE_LL4148-223_LL4148LL4148LL4148-223
D27BAT54S_A0271-SOT95P240X122-3_BABAT54SA0271-SOT95P240X122-3
DD1R_14_RFDIODIE_BK23000702BK23000702RFDIODIE
DD9R_13_3PESDDIODE_3RL975M-5-SS3RL975M-5-SS3PESDDIODE
DETP-R_A0438-TP100_TP-RTP-RA0438-TP100
DF1R_11_DF_MD6SMD6SDF
DF2R_11_DF_MD6SMD6SDF
DZ1TVS_SS24SMA_SMBJ20ASMBJ20ASS24SMA
DZ2TVS_SS24SMA_SMBJ10ASMBJ10ASS24SMA
DZ3TVS_SS24SMA_SMBJ10ASMBJ10ASS24SMA
DZ4TVS_SS24SMA_SMBJ20ASMBJ20ASS24SMA
DZ5TVS_SS24SMA_SMBJ20ASMBJ20ASS24SMA
DZ6TVS_0_SS24SMA_SMBJ5.0ASMBJ5.0ASS24SMA
DZ7TVS_SS24SMA_SMBJ5.0ASMBJ5.0ASS24SMA
DZ8TVS_SS24SMA_BGA10603V05BGA10603V05SS24SMA
DZ9TVS_SS24SMA_BGA10603V05BGA10603V05SS24SMA
EXT+3.3VTP-R_A0438-TP100_TP-RTP-RA0438-TP100
F1FUSE_FUSE_24V_500MA_24V_500MA24V_500MAFUSE_24V_500MA
GPIO_P3TP-R_A0438-TP100_TP-RTP-RA0438-TP100
HOST1ZIF-24PIN_10_B0110-OUPIIN_2112-NC/951104-8622-ARB0110-OUPIIN_2112-1X4GFSB-3
HOST0CZIF-24PIN_12_CVBSTOUSB-1_CVBS-UCVBS-USB MODULE CONN.CVBSTOUSB-1
HSTP-R_A0438-TP100_TP-RTP-RA0438-TP100
ICMOS1ZIF-50PIN_14_A0789-OUPIIN_2345-FH12A-24S-0.5SH-TOPA0789-OUPIIN_2345-24TD2
INTTPTP-R_A0438-TP100_TP-RTP-RA0438-TP100
J7CON12_3_SD-13P-1_SDSDSD-13P-1
J8CON12_7_TF-2_TFTFTF-2
JTAG1HEADER9_B0110-OUPIIN_2112-1X9GNC/951109-8622-ARB0110-OUPIIN_2112-1X9GFSB
JUMP1R_7_DSHP03TS_1D27_3P_DSHP03TSDSHP03TSDSHP03TS_1D27_3P
K1TP-R_A0438-TP100_TP-RTP-RA0438-TP100
KEY3ZIF-24PIN_17_WAFER_1D25_7P_90_WWAFER-1.25-SMT-7pWAFER_1D25_7P_90
LTP-R_A0438-TP100_TP-RTP-RA0438-TP100
L4FB_A0076-FBC1005X55_30OHM@100M30 Ohm@100MHzA0076-FBC1005X55
L5FB_A0076-FBC1005X55_30OHM@100M30 Ohm@100MHzA0076-FBC1005X55
L6CHOKE_CM_4P_ENG_0_B0116-WURTH_790 OhmB0116-WURTH_744232090
L7L-NORMAL_B0078-INDP8080X200_10U10uH_2.4ACKRH8D38
CDRH8D38NP-100NC
B0078-INDP8080X200
L11FB_A0076-FBC1005X55_30OHM@100M30 Ohm@100MHzA0076-FBC1005X55
L12FB_A0076-FBC1005X55_30OHM@100M30 Ohm@100MHzA0076-FBC1005X55
L13L-NORMAL_IND-7X7_2D1_10UH_1A10uH_1AIND-7X7_2D1
L14L-NORMAL_IND-7X7_2D1_10UH_1A10uH_1AIND-7X7_2D1
L16FB_A0076-FBC1005X55_30OHM@100M30 Ohm@100MHzA0076-FBC1005X55
L17L-NORMAL_A0486-INDM1608X95_0.680.68uHA0486-INDM1608X95
L18CHOKE_CM_4P_ENG_0_B0116-WURTH_790 OhmB0116-WURTH_744232090
L19L-NORMAL_IND-7X7_2D1_47UH_0.82A47uH_0.82AIND-7X7_2D1
L20L-NORMAL_0_IND-7X7_2D1_4.7UH_2A4.7uH_2AIND-7X7_2D1
L21L-NORMAL_0_IND-7X7_2D1_4.7UH_2A4.7uH_2AIND-7X7_2D1
L29FB_A0076-FBC1005X55_30OHM@100M30 Ohm@100MHzA0076-FBC1005X55
LCD_POWERTP-R_A0438-TP100_TP-RTP-RA0438-TP100
LD1SIP-2PIN_1_WAFER_2P_1D25_90-1_11.25 WAFER 90 SMT 2PWAFER_2P_1D25_90-1
LD2SIP-2PIN_2_WAFER_2P_1D25_90-1_11.25 WAFER 90 SMT 2PWAFER_2P_1D25_90-1
LD3SIP-2PIN_2_WAFER_2P_1D25_90-1_11.25 WAFER 90 SMT 2PWAFER_2P_1D25_90-1
LEDCN1HEADER9_5_WAFER-4P_1D25_1.25 W1.25 WAFER 90 SMT 4PWAFER-4P_1D25
LEDCN2HEADER9_4_WAFER-4P_1D25_1.25 W1.25 WAFER 90 SMT 4PWAFER-4P_1D25
LEDCN3HEADER9_4_WAFER-4P_1D25_1.25 W1.25 WAFER 90 SMT 4PWAFER-4P_1D25
LEDD1SIP-2PIN_0_SM02B-BHSS-1-TB_SM02SM02B-BHSS-1-TBSM02B-BHSS-1-TB
LED_ALARMTP-R_A0438-TP100_TP-RTP-RA0438-TP100
LED_ARMEDTP-R_A0438-TP100_TP-RTP-RA0438-TP100
LED_SMSTP-R_A0438-TP100_TP-RTP-RA0438-TP100
LINEOUT7HEADER9_1_B0110-OUPIIN_2112-1XNC/951104-8622-ARB0110-OUPIIN_2112-1X4GFSB-1
LINEOUT9HEADER9_1_B0110-OUPIIN_2112-1XNC/951104-8622-ARB0110-OUPIIN_2112-1X4GFSB-1
LOCK1HEADER9_2_PH-6P-90-1_B6B-PH-K-B6B-PH-K-SPH-6P-90-1
LOCK_COMTP-R_A0438-TP100_TP-RTP-RA0438-TP100
LOCK_NCTP-R_A0438-TP100_TP-RTP-RA0438-TP100
LOCK_NOTP-R_A0438-TP100_TP-RTP-RA0438-TP100
LVD1ZIF-50PIN_15_LVDS40PIN0M5_1_FH1FH12A-40S-0.5SH-TOPLVDS40PIN0M5_1
MH1MTG_HOLE_SCROW-3D1_DNEDNESCROW-3D1
MIC1SIP-2PIN_0_WAFER_2P_1D25_90-1_11.25 WAFERWAFER_2P_1D25_90-1
NRSETTP-R_A0438-TP100_TP-RTP-RA0438-TP100
NVCLKTP-R_A0438-TP100_TP-RTP-RA0438-TP100
NVDATTP-R_A0438-TP100_TP-RTP-RA0438-TP100
PGNDTP-R_A0438-TP100_TP-RTP-RA0438-TP100
PLCKTP-R_A0438-TP100_TP-RTP-RA0438-TP100
POWSIP-2PIN_1_PH-2P-90-1_B2B-PH-K-B2B-PH-K-SPH-2P-90-1
PWM0TP-R_A0438-TP100_TP-RTP-RA0438-TP100
PWRTP-R_A0438-TP100_TP-RTP-RA0438-TP100
Q1SI3586DV_B0081-TSOP-6_SI3586DVSI3586DVB0081-TSOP-6
Q2BSH205/P-CH_A0279-SOT95P260X112AP2303A0279-SOT95P260X112-3
Q3NPN-NORMAL_A0279-SOT95P260X112-SS8050LT1A0279-SOT95P260X112-3
Q4SI3586DV_B0081-TSOP-6_SI3586DVSI3586DVB0081-TSOP-6
Q5BSH205/P-CH_A0279-SOT95P260X112AP2303A0279-SOT95P260X112-3
Q6SI3586DV_B0081-TSOP-6_SI3586DVSI3586DVB0081-TSOP-6
Q21BSH205/P-CH_A0279-SOT95P260X112AP2303A0279-SOT95P260X112-3
Q22NPN-NORMAL_A0279-SOT95P260X112-SS8050LT1A0279-SOT95P260X112-3
RA1RA8PIN_A0201-RESCAXE50P100X20033RA0201-RESCAXE50P100X200X45-8
RA2RA8PIN_A0201-RESCAXE50P100X20033RA0201-RESCAXE50P100X200X45-8
RET2SWPUSHBUTTON_1_TS_V370625_SWPBSWPBTS_V370625
RETTPTP-R_A0438-TP100_TP-RTP-RA0438-TP100
RFD1HEADER9_6_WAFER-3P_1D25_WAFER-WAFER-3P_1D25WAFER-3P_1D25
RJ45RJ45-V_B0109-POWERWAY_5388C-B_CCONN MOD JACK 8P8CVERT SHIELDED A-2014-2S-4-N-RB0109-POWERWAY_5388C-B
RL1G6H_3_RELAY_SMT8P_HFD4/5SRHFD4/5SRRELAY_SMT8P
RLOTP-R_A0438-TP100_TP-RTP-RA0438-TP100
RS485+TP-R_A0438-TP100_TP-RTP-RA0438-TP100
RS485-TP-R_A0438-TP100_TP-RTP-RA0438-TP100
RTP1ZIF-24PIN_33_A0776-CVILUX_CF070FPC-1D-4P-BOTA0776-CVILUX_CF07041D0R0
SF_CSTP-R_A0438-TP100_TP-RTP-RA0438-TP100
SIP1HEADER9_B0110-OUPIIN_2112-1X_1951109-7622-ARB0110-OUPIIN_2112-1X9GFSB-1
SKLSIP-2PIN_1_WAFER_2P_1D25_90-1_21.25 WAFERWAFER_2P_1D25_90-1
SKRSIP-2PIN_1_WAFER_2P_1D25_90-1_21.25 WAFERWAFER_2P_1D25_90-1
SPI1HEADER9_2_B0110-OUPIIN_2112-1XNC/2112-1X6GFSBB0110-OUPIIN_2112-1X6GFSB-1
SYS_NRESETTP-R_A0438-TP100_TP-RTP-RA0438-TP100
T1CAPNP_3_ACM7060-701-2PL_ACM706ACM7060-701-2PLACM7060-701-2PL
U1CX92755-11Z_B0084-BGA441N80X80PCX92755-11ZB0084-BGA441N80X80P21X21_165
U2K4B2G1646B-HCH9_B0089-BGA96C80PK4B2G1646B-HCH9B0089-BGA96C80P9X16_96
U4SPX1117M3_A0715-SOT230P696X180-SPX1117M3-1.8A0715-SOT230P696X180-4
U5K9GAG08U0E-SCB0_A0241-SOP50P200K9GAG08U0E-SCB0A0241-SOP50P2000X120-48
U6M0145_A0331-XFMR_H1102NL_MODULEMODULE XFRMR SGL ETHRLAN 16SOIC H1102NLA0331-XFMR_H1102NL
U7SP3485_2_MAX487E_MAX487EMAX487EMAX487E
U9CX20707-12ZP_4_CX20707-12ZP_CX2CX20707-12ZP_4CX20707-12ZP
U10RTL8201CP-VD_0_A0179-QFP50P900XRTL8201CP-VD-LF/LQFP-48A0179-QFP50P900X900X170-48
U11MH7050_A0279-SOT95P260X112-3_NCNC/MH7033A0279-SOT95P260X112-3
U14LM358_7_B0085-SOP127P500X163-8_LM393B0085-SOP127P500X163-8
U16MP1482_3_B0085-SOP127P500X163-8TPS54232B0085-SOP127P500X163-8
U17MP1482_3_B0085-SOP127P500X163-8TPS54232B0085-SOP127P500X163-8
U18MP1482_4_B0085-SOP127P500X163-8TG03B0085-SOP127P500X163-8
U19AMC7140DL_2_B0081-TSOP-6_FP6745FP6745CB0081-TSOP-6
U20AMC7140DL_3_SOT-23-5-M_APW7137APW7137SOT-23-5-M
U21AMC7140DL_0_SOT-23-5-M_RT9179RT9179SOT-23-5-M
U22AMC7140DL_0_SOT-23-5-M_RT9179RT9179SOT-23-5-M
UART2_RXTP-R_A0438-TP100_TP-RTP-RA0438-TP100
UART2_RX1TP-R_A0438-TP100_TP-RTP-RA0438-TP100
UAT0HEADER9_1_B0110-OUPIIN_2112-_1951104-8622-ARB0110-OUPIIN_2112-1X4GFSB-1
UAT1HEADER9_1_B0110-OUPIIN_2112-_1951104-8622-ARB0110-OUPIIN_2112-1X4GFSB-1
UD1R_9_SOP8_MAX906XMAX906XSOP8
USBDV1ZIF-24PIN_10_B0110-OUPIIN_211_1NC/951104-8622-ARB0110-OUPIIN_2112-1X4GFSB-1
Y1XTAL-2PIN_1_48M3205_48MHZ48Mhz48M3205
Y2XTAL-2PIN_2_32D576_32.768K32.768k32D576
Y3XTAL-2PIN_48M3205_48MHZ48Mhz48M3205
Y4XTAL-2PIN_48M3205_25MHZ25Mhz48M3205
重要提示:PCB作品文件展下载说明
老吴 | 2017-8-17 19:19:55 | 显示全部楼层
最近派发完我的金币了,成穷人了。所以要努力赚金币。不然下一波就没金币发了。
PCB是ALLEGRO16.6格式,销售20金币, 原理图PDF格式。
CX92755.7z (2.37 MB, 下载次数: 11)
地沟油 | 2017-8-17 19:52:51 | 显示全部楼层
xnima_irumei | 2017-8-17 20:29:24 | 显示全部楼层
o桃花岛主o | 2017-8-18 00:24:34 | 显示全部楼层
jopey | 2017-8-18 08:10:53 | 显示全部楼层
longxuekai | 2017-8-18 08:11:13 | 显示全部楼层
kbh2006@163.com | 2017-8-18 08:19:49 | 显示全部楼层
hlim89 | 2017-8-18 08:44:56 | 显示全部楼层
lfc | 2017-8-18 08:46:03 | 显示全部楼层
