重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | 1 | SOP16-6 | PT2399/CD2399/CD3699GP | PT2399 | BT-ANT1 | FM-ANTABC | FM ANT | FM-ANT | BT-ANT2 | FM-ANTABBAAA | FM ANT | FM-ANT | BT1 | F-6388-2AA | BK3254MK | BK3254MK | CN301 | CN12P-2.0 | 12PIN_2.0MM | CN2012 | CN903 | CN03 | 3PIN_2.5MM | CN2003 | CW401 | P9/2.0-2 | 9P/2.0 | P9/2.54 | CW801 | CN2004 | 2PIN_2.5MM | CN2004 | D1 | D1206 | IN4148 | D1206 | D2 | D1206 | IN4148 | D1206 | D3 | DIODE_1N5401ABAAA | IN5401 | DIODE_1N5401 | D4 | DIODE_1N5401ABAAA | IN5401 | DIODE_1N5401 | D301 | D1206 | IN4148 | D1206 | D302 | D1206 | IN4148 | D1206 | D401 | D1206 | IN4148 | D1206 | D402 | SOT23 | BAT54S | BAT54 | D403 | SOT23 | BAT54S | BAT54 | D404 | D1206 | IN4148 | D1206 | D405 | TR-SMD(BCE)/8050 | BAT54S | 9014_PART | D601 | D1206 | IN4148 | D1206 | DZ1 | SOD80 | 4001 | DIODE | DZ2 | DIODE_ZD3V6 | 13.1V | DIODE_ZD3V6 | DZ301 | DIODE_ZD3V6 | 5.6V | DIODE_ZD3V6 | DZ302 | DIODE_ZD3V6 | NC | DIODE_ZD3V6 | FM_ANT | ANT-TUNER | | ANT-TUNER | FM_ANT1 | ANT-TUNER | | ANT-TUNER | IC101 | L1117-SOT-223 | L1117-5V | L1117-SOT-223 | IC102 | QFP48-0707-0.5N | AU6210K | AU6210K | IC103 | SO-8 | 24C02 | 24C02 | IC301 | SOP16-103 | PT2399 | PT2399 | IC302 | 24C01 | 4558 | NJM4558 | IC303 | 24C01 | 4558 | NJM4558 | IC304 | 4558B | 4558 | 4558B | IC401 | SC7314_SO28WB | SC7314 | CSC2314 | IC801 | TPA3110D2_TSSOP28 | TPA3110D2 | TPA3110D2 | IC901 | TO-252-2L | 78M08 | TO-252-2L | J1 | SIP-6P | | CON-SIP-6P | J401 | JACK\STEREO-5PA | AUX JACK | HPJACK-5P | J501 | USB_DIPA | USB-JACK | USB | J502 | SD1A | SD JACK | SD-JACK | L2 | FIDUCIAL-1A | | FIDUCIAL-1 | L3 | FIDUCIAL-1B | | FIDUCIAL-1 | L4 | PAD1 | | FIDUCIAL-1 | L6 | FIDUCIAL-1 | | FIDUCIAL-1 | L7 | FIDUCIAL-1 | | FIDUCIAL-1 | L101 | L0603 | 330nH | L0603 | L103 | R0603 | 600R | RES | L801 | CHOKE\COIL\2P\8 | 33UH | CHOKE\COIL\2P\8 | L802 | CHOKE\COIL\2P\8 | 33UH | CHOKE\COIL\2P\8 | LN1 | 805 | 0R | 805 | Q1 | SOT23-NPN | 3904 | NPN_M | Q2 | SOT23-NPN | 3904 | NPN_M | Q4 | SOT23-NPN | 3904 | NPN_M | Q7 | SOT23-NPN | 3904 | NPN_M | Q101 | 9018F1AA | 9018F | 9018FN | Q301 | SOT23-NPN | 9014 | NPN_M | Q302 | SOT23-NPN | 9014 | NPN_M | Q303 | SOT23-NPN | NC | NPN_M | Q304 | SOT23-NPN | 3904 | NPN_M | Q305 | SOT23-NPN | 3904 | NPN_M | Q306 | SOT23-NPN | 3904 | NPN_M | Q307 | SOT23-NPN | 3904 | NPN_M | Q401 | SOT23-NPN | 3904 | NPN_M | Q402 | SOT23-PNP | S8550 | PNP_M | Q403 | SOT23-NPN | NC | NPN_M | Q404 | SOT23-NPN | 3904 | NPN_M | Q405 | SOT23-NPN | 3904 | NPN_M | Q406 | 2SK3018 | NC | 2SK3018 | Q407 | 2SK3018 | 2SK3018 | 2SK3018 | Q408 | 2SK3018 | 2SK3018 | 2SK3018 | Q801 | SOT23-NPN | 3904 | NPN_M | Q901 | TR-8550A | | TR-8550 | Q902 | SOT23-NPN | 3904 | NPN_M | SW301 | SK-12D07AA | AVC SW | SK-12D07 | SW701 | SWTC02 | STANDBY | SWTC02 | SW702 | SWTC02 | MODE | SWTC02 | SW703 | SWTC02 | NEXT | SWTC02 | SW704 | SWTC02 | BACK | SWTC02 | SW705 | SWTC02 | PLAY/PAUSE | SWTC02 | U1 | SOP-8 | MEM2309 | MEM2309 | U2 | SOT25 | ME6119 | WB6332A | XTAL1 | SMT_Y2A | 32.768Khz | CRYSTAL32K |
AU6210K.7z
(558 KB, 下载次数: 29)
重要提示:PCB作品文件展下载说明
