重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | AV1 | AV-JACK_0_2 | AVHEADER3 | AV-JACK-3 | AV3 | COMP/S-VIDEO_3 | SCJACK | comp/S-video | AV4 | AV-JACK_8 | AV-JACK | AV-JACK-1 | AV5 | TOTX178_2 | JACK3X1A | OPTI OUT | AV6 | CON2_4 | RCA | COAX | CN1 | CON5 | HEADER5-2 | JST-CON5-2 mm | CN2 | CON6 | HEADER6-2 | JST-CON6-2 mm | CN3 | CON2 | SIP2-2MM | SCART2 | CN4 | ELCO-CON24_0 | CON24-0.5-F2 | ELCO-CON24(Left) | CN5 | HEADER_4_2 | HEADER4-2.54 | POWER | CN6 | CON2 | HEADER2-2.54 | Card baord power | CN7 | HEADER_16 | CON16A | CARD | CN8 | CON6 | HEADER6-2.54 | IR/VFD | CN9 | HEADER_13_0 | CON11B-2.0 | SCART | CN10 | CON4 | HEADER4-2.54 | UART debug | CN11 | CON4 | HEADER4-2.54 | HEADER4-2.54 | CN12 | HEADER_4_2 | SIP4 | MIC | D1 | DIODE_2 | D-1206 | 1N4148 | D4 | DIODE_2 | DIODE | 1N4004 | D5 | DIODE_2 | D-1206 | 1N4148(SMT) | D7 | DIODE_2 | D-1206 | 1N4148(SMT) | D10 | BAV99/SOT_0 | SOT-23 | BAV99 | D11 | BAV99/SOT_0 | SOT-23 | BAV99 | D12 | BAV99/SOT_0 | SOT-23 | BAV99 | D13 | BAV99/SOT_0 | SOT-23 | BAV99 | F1 | FUSE | L-1206 | FUSE(1206,500mA) | J1 | HDMI_3 | CON-HDMI19-0.5 | HDMI | JP1 | CON2_2 | SIP2 | Bootstrap On | L39 | CHOKE_CM | CHOKE-2012 | ACM2012H-900-2P | L40 | CHOKE_CM | CHOKE-2012 | ACM2012H-900-2P | L41 | CHOKE_CM | CHOKE-2012 | ACM2012H-900-2P | L42 | CHOKE_CM | CHOKE-2012 | ACM2012H-900-2P | Q1 | NPN_0 | SOT-23 | 9014 | Q2 | MOSFET_N_0 | SOT-23 | 2SK3018 | Q3 | NPN_0 | SOT-23 | 9014 | Q4 | NPN_0 | SOT-23 | 9014 | Q5 | NPN_0 | SOT-23 | 2N3904 | Q6 | NPN | SOT-23 | 2N3904 | Q7 | MOSFET_N_0 | SOT-23 | 2SK3018 | Q8 | PNP_5 | 2SB1132 | 2SB1132(type R) | Q9 | PNP_5 | 2SB1132 | 2SB1132(type R) | Q10 | PNP_6 | PNP-EBC1 | 9015(DIP EBC) | Q11 | PNP_6 | PNP-EBC1 | 9015(DIP EBC) | Q12 | PNP_6 | PNP-EBC1 | 9015(DIP EBC) | Q13 | PNP_6 | PNP-EBC1 | 9015(DIP EBC) | Q14 | NPN_2 | SOT-23 | 2N3904 | Q15 | PNP_6 | SOT-23 | 2N3906 | Q16 | NPN_2 | SOT-23 | 2N3904 | Q17 | PNP_6 | SOT-23 | 2N3906 | Q18 | PNP_6 | SOT-23 | 2N3906 | Q19 | NPN_2 | SOT-23 | 2N3904 | Q20 | NPN_2 | SOT-23 | 2N3904 | Q21 | NPN_2 | SOT-23 | 2N3904 | Q22 | NPN_2 | SOT-23 | 2N3904 | Q23 | 2N7008 | SOT-23 | 2SK3018 | Q24 | 2N7008 | SOT-23 | 2SK3018 | U1 | LM7805CT_1 | SMD-TO-252-4 | AMS1085 TO-252 | U2 | SPHE6500A_10 | QFP128-0.5 | SPHE6500A | U3 | LM7805CT_0 | SMD-TO-252-4 | AMS1085 TO-252 | U4 | BA5934FP_8 | DIP28-SSOPH | AM5668 | U6 | FLASH_1MX16_2 | DIP48-TSOP | MX29LV800T/B,SST39VF088 | U7 | AM27C040_4 | DIP34-600S | AM27C040/AM27c080/Flash MX29F040 | U8 | SPCA8200(32BIT_SDRAM)_82 | QFP256-0.4 | SPHE8202A-256 | U9 | 4MX16 | DIP54-SSOP | SDRAM 64Mb-7T | U10 | SDRAM_512KX16X2 | DIP50-TSOP | SDRAM 16M-6(512Kx16x2) | U11 | 4558 | DIP8-SOP | NJM4558 | U12 | 24C01A_1 | DIP8-SOP | 24C01/CAT24C021 | U13 | SDRAM_512KX16X2 | DIP50-TSOP | SDRAM 16M-6(512Kx16x2) | U14 | 4558 | DIP8-SOP | NJM4558 | U15 | 4MX16 | DIP54-SSOP | SDRAM 64Mb-7T | U16 | CS4334 | DIP8-SOP | CS4334 | U17 | WM8716_6 | DIP28-SSOP1 | WM8772 | U18 | 4558 | DIP8-SOP | NJM4558 | U19 | 74F04 | DIP14-SOP | 74HCU04 | U20 | 24C01A_1 | DIP8-SOP | 24C04 | XT1 | CRYSTAL | X'TAL | 27MHz | ZD1 | DIODE_BREAKDOWN | DIODE-ZENER-300 | Zener / 5V1(dip) |
原理图和PCB 没有完全对应。 仅做学习用。一起打包。原理图是ORCAD格式。
8202A.7z
(756 KB, 下载次数: 19)
重要提示:PCB作品文件展下载说明
