一、 综合词汇
1、 印制电路:printed circuit
2、 印制线路:printed wiring- A' V/ `; W) I8 q$ V) `1 w
3、 印制板:printed board
4、 印制板电路:printed circuit board (pcb)
5、 印制线路板:printed wiring board(pwb)_- ]6 V6 R: u
6、 印制元件:printed component
7、 印制接点:printed contact/ q/ Z# U. x. d7 q# g, ^5 K, w9 u
8、 印制板装配:printed board assembly& K9 R( L/ m( m& G2 Y* L
9、 板:board
10、 单面印制板:single-sided printed board(ssb)
11、 双面印制板:double-sided printed board(dsb)
12、 多层印制板:mulitlayer printed board(mlb)$ [' s|/ D$ U1 b, e: A3 x
13、 多层印制电路板:mulitlayer printed circuit board
14、 多层印制线路板:mulitlayer prited wiring board
15、 刚性印制板:rigid printed board, j- c4 C; Z' M+ S! ^
16、 刚性单面印制板:rigid single-sided printed borad) L+ _% n, T/ x0 C+ S1 H
17、 刚性双面印制板:rigid double-sided printed borad! z7 R' o4 i) o! T
18、 刚性多层印制板:rigid multilayer printed board
19、 挠性多层印制板:flexible multilayer printed board" U" k4 H% Y3 `/ EF; T. R
20、 挠性印制板:flexible printed board9 y. c7 W* E7 d, }: A. F
21、 挠性单面印制板:flexible single-sided printed board; H1 fR/ l/ T& ~
22、 挠性双面印制板:flexible double-sided printed board# h: C7 io. s6 \
23、 挠性印制电路:flexible printed circuit (fpc)2 x! b# i: W( B3 K
24、 挠性印制线路:flexible printed wiring
25、 刚性印制板:flex-rigid printed board, rigid-flex printed
board
26、 刚性双面印制板:flex-rigid double-sided printed board, % j% O7 z- g: L. q9 B2 z! G
rigid-flex double-sided printed( h7 }1 _9 |, \5 s7 d) c! L1 l# P
27、 刚性多层印制板:flex-rigid multilayer printed board, V, V- {9 [' T- f
rigid-flex multilayer printed board& v$ |, p+ }+ V: v# ?; E7 k
28、 齐平印制板:flush printed board) D% a/ B% \* m4 B& }* f4 |* R
29、 金属芯印制板:metal core printed board5 O% i4 b2 W. M7 _# C1 L
30、 金属基印制板:metal base printed board
31、 多重布线印制板:mulit-wiring printed board
32、 陶瓷印制板:ceramic substrate printed board# c5 s' c2 p0 m8 i
33、 导电胶印制板:electroconductive paste printed board. F/ {8 N6 p/ J
34、 模塑电路板:molded circuit board6 T8 cs" @7 W' M8 o' t
35、 模压印制板:stamped printed wiring board7 \+ C5 N* b/ f# R
36、 顺序层压多层印制板:sequentially-laminated mulitlayer
37、 散线印制板:discrete wiring board, Z6 _% A5 N! m8 w
38、 微线印制板:micro wire board2 g6 H" u. z6 |: ~$ y1 _
39、 积层印制板:buile-up printed board
40、 积层多层印制板:build-up mulitlayer printed board (bum)
41、 积层挠印制板:build-up flexible printed board
42、 表面层合电路板:surface laminar circuit (slc)3 h4 V# |! F! D. S+ y! A' r+ O
43、 埋入凸块连印制板:b2it printed board
44、 多层膜基板:multi-layered film substrate(mfs)
45、 层间全内导通多层印制板:alivh multilayer printed board; x' N$ W* M5 i# t
46、 载芯片板:chip on board (cob)
47、 埋电阻板:buried resistance board/ Z$ R, W- N: X]5 ]( g& ~' N
48、 母板:mother board: z% o1 h8 P* M- P
49、 子板:daughter board
50、 背板:backplane
51、 裸板:bare board
52、 键盘板夹心板:copper-invar-copper board
53、 动态挠性板:dynamic flex board; |0 G) ^0 J. C) z- k( s
54、 静态挠性板:static flex board$ O+ \+ I" j1 _% O# S
55、 可断拼板:break-away planel% l( m- B: O$ Gy4 t9 {
56、 电缆:cable
57、 挠性扁平电缆:flexible flat cable (ffc)0 }- e7 v5 k/ [( B) R' z4 b
58、 薄膜开关:membrane switch$ y4 |: R" a* `8 x( H
59、 混合电路:hybrid circuit/ s# \6 P. j6 S; a' A6 o
60、 厚膜:thick film- c3 `u2 [3 r* B2 B0 X: b
61、 厚膜电路:thick film circuit
62、 薄膜:thin film. v! R) u, ?, |- ?
63、 薄膜混合电路:thin film hybrid circuit8 m4 D2 h2 G+ b% [8 A
64、 互连:interconnection( C) Z( |+ G+ A8 X& \$ }, Q
65、 导线:conductor trace line
66、 齐平导线:flush conductor
67、 传输线:transmission line4 V4 S0 X* F% `) _2 h" c
68、 跨交:crossover
69、 板边插头:edge-board contact( s+ Z2 M% l- U
70、 增强板:stiffener
71、 基底:substrate' i- n5 J0 j+ E; D, U0 G1 {
72、 基板面:real estate
73、 导线面:conductor side ! g9 k( @- w6 d# C8 d0 U) \
74、 元件面:component side
75、 焊接面:solder side6 J4 C& ~# D; t7 B
76、 印制:printing
77、 网格:grid
78、 图形:pattern
79、 导电图形:conductive pattern
80、 非导电图形:non-conductive pattern
81、 字符:legend8 j% q! T6 x5 [6 r3 Z% \$ S
82、 标志:mark
二、 基材:
1、 基材:base material' V& z3 |2 J$ I6 \/ E
2、 层压板:laminate
3、 覆金属箔基材:metal-clad bade material: P2 o1 o, R4 J/ r" z$ C
4、 覆铜箔层压板:copper-clad laminate (ccl)
5、 单面覆铜箔层压板:single-sided copper-clad laminate
6、 双面覆铜箔层压板:double-sided copper-clad laminate, K5 q' O+ L; h6 v
7、 复合层压板:composite laminate! }6 A2 o! z8 D' b$ g
8、 薄层压板:thin laminate: J% Y$ M. {- M: Z: D% {
9、 金属芯覆铜箔层压板:metal core copper-clad laminate* ~' E: e% }* |6 W# U
10、 金属基覆铜层压板:metal base copper-clad laminate
11、 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film
12、 基体材料:basis material
13、 预浸材料:prepreg
14、 粘结片:bonding sheet
15、 预浸粘结片:preimpregnated bonding sheer/ |. \. ]- w' j$ c6 p' Me
16、 环氧玻璃基板:epoxy glass substrate
17、 加成法用层压板:laminate for additive process0 X5 n5 Q* m! I3 u
18、 预制内层覆箔板:mass lamination panel+ s/ x, ^* j2 m5 P9 h+ i% Q
19、 内层芯板:core material
20、 催化板材:catalyzed board ,coated catalyzed laminate
21、 涂胶催化层压板:adhesive-coated catalyzed laminate- a8 A2 U6 M2 Q8 ]% B
22、 涂胶无催层压板:adhesive-coated uncatalyzed laminate& u# d# P) b. ]5 s4 D3 p8 y( y
23、 粘结层:bonding layer
24、 粘结膜:film adhesive
25、 涂胶粘剂绝缘薄膜:adhesive coated dielectric film
26、 无支撑胶粘剂膜:unsupported adhesive film$ o- ]- x3 Q! U: L
27、 覆盖层:cover layer (cover lay)
28、 增强板材:stiffener material2 P7 [2 }! E! B: O+ ~2 N% A
29、 铜箔面:copper-clad surface
30、 去铜箔面:foil removal surface% |% ~: L/ Y' h$ c6 VD
31、 层压板面:unclad laminate surface
32、 基膜面:base film surface' ft8 I% B; N, @& H9 D; q; k$ R
33、 胶粘剂面:adhesive faec0 B; u3 I# @8 d& W4 o; o
34、 原始光洁面:plate finish5 H+ L( p7 H) a: j1 W1 j% j2 {
35、 粗面:matt finish
36、 纵向:length wise direction
37、 模向:cross wise direction
38、 剪切板:cut to size panel
39、 酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad
laminates(phenolic/paper ccl)
40、 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad
laminates (epoxy/paper ccl)
41、 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad 8 g3 I0 l+ v; X. A( {- B4 _# _
laminates [& A4 v( M( K
42、 环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass 8 K& J3 `- M. i
cloth surfaces copper-clad laminates7 M5 h; b& [% t7 f! C) ]
43、 环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass , n- w+ [& g" QI) ^n
reinforced copper-clad laminates; \2 T* I4 S3 y, a2 {
44、 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad # q9 `2 U& l( i( E
laminates
45、 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad
laminates% yM3 i( _7 @) U$ E9 y2 O
46、 双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide
woven glass fabric copper-clad lamimates
47、 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric - G- y3 y' S8 q- s' R
48、 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad
laminates
49、 超薄型层压板:ultra thin laminate& E3 u" n; q; i4 T- w
50、 陶瓷基覆铜箔板:ceramics base copper-clad laminates
51、 紫外线阻挡型覆铜箔板:uv blocking copper-clad laminates
三、 基材的材料& d* c& D0 G% _3 w1 y& n5 Y
1、 a阶树脂:a-stage resin+ N6 @. [' g+ F4 Q' }# a
2、 b阶树脂:b-stage resin
3、 c阶树脂:c-stage resin4 p* k! _. OT4 e* Y+ p
4、 环氧树脂:epoxy resin( O, ?" \$ T' m" ^0 x/ }( e. j4 k
5、 酚醛树脂:phenolic resin% [0 x9 `I* j2 y0 u
6、 聚酯树脂:polyester resin
7、 聚酰亚胺树脂:polyimide resin
8、 双马来酰亚胺三嗪树脂:bismaleimide-triazine resin
9、 丙烯酸树脂:acrylic resin' R3 Z1 U3 q9 Y$ m9 n& l; }+ O
10、 三聚氰胺甲醛树脂:melamine formaldehyde resin9 p% |+ d" a( i
11、 多官能环氧树脂:polyfunctional epoxy resin( A1 C1 b" hp& X0 m! A0 [7 ]
12、 溴化环氧树脂:brominated epoxy resin
13、 环氧酚醛:epoxy novolac
14、 氟树脂:fluroresin
15、 硅树脂:silicone resin
16、 硅烷:silane
17、 聚合物:polymer
18、 无定形聚合物:amorphous polymer' hC9 C4 V3 L( J$ G' x6 j
19、 结晶现象:crystalline polamer
20、 双晶现象:dimorphism
21、 共聚物:copolymer
22、 合成树脂:synthetic
23、 热固性树脂:thermosetting resin
24、 热塑性树脂:thermoplastic resin
25、 感光性树脂:photosensitive resin( Q4 m; g1 Q) V+ A" S
26、 环氧当量:weight per epoxy equivalent (wpe)7 y8 w& G8 B5 }% P+ Ub& J" ?
27、 环氧值:epoxy value+ @) E" Y1 q+ X, E7 P8 g
28、 双氰胺:dicyandiamide2 V) r+ Y1 l4 E4 A5 F: X
29、 粘结剂:binder# f1 h# R; N- E5 O9 \
30、 胶粘剂:adesive
31、 固化剂:curing agent
32、 阻燃剂:flame retardant
33、 遮光剂:opaquer
34、 增塑剂:plasticizers
35、 不饱和聚酯:unsatuiated polyester. B8 U; h# S+ {) _9 ~6 I
36、 聚酯薄膜:polyester% ?9 c3 ?2 E) t8 g
37、 聚酰亚胺薄膜:polyimide film (pi)! j5 ^9 d( ?$ u( [, z5 k
38、 聚四氟乙烯:polytetrafluoetylene (ptfe)
39、 聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene
copolymer film (fep)2 x% }( ^* B' ?. j$ a! t+ X) g
40、 增强材料:reinforcing material" W/ S4 _; O7 i+ v' z
41、 玻璃纤维:glass fiber! p" B0 f+ a& Z8 S5 Q
42、 e玻璃纤维:e-glass fibre2 |" F& k( D2 H8 W3 x* n
43、 d玻璃纤维:d-glass fibre. p- `; X/ n" ~; d
44、 s玻璃纤维:s-glass fibre5 w6 I$ I# a6 }0 r0 ~4 v- T1 j
45、 玻璃布:glass fabric
46、 非织布:non-woven fabric$ P8 [% b! s' }4 U) e2 HA
47、 玻璃纤维垫:glass matsD% Y1 V& I. q6 a
48、 纱线:yarn
49、 单丝:filament
50、 绞股:strand2 ?- s# E* b/ l2 V8 N' v
51、 纬纱:weft yarn9 r- Z- k2 u7 \( a( \" Ul3 q2 o
52、 经纱:warp yarn/ z0 _* V2 g- t: s
53、 但尼尔:denier
54、 经向:warp-wise1 Q$ z4 f6 @! _! E?3 c% L
55、 纬向:weft-wise, filling-wise
56、 织物经纬密度:thread count+ D4 h! ~) J: _3 u8 ~
57、 织物组织:weave structure2 M" y6 M% t, B; _' O" b
58、 平纹组织:plain structure
59、 坏布:grey fabric. q7 `2 W2 A5 R' R- `0 |
60、 稀松织物:woven scrim
61、 弓纬:bow of weave( M& q; e% D! }% ?2 d" m
62、 断经:end missing
63、 缺纬:mis-picks/ q) G& G, e$ r
64、 纬斜:bias|- z$ \5 X/ d- g
65、 折痕:crease
66、 云织:wavinessP1 O7 t; e$ B. h" [' E
67、 鱼眼:fish eye2 {" |. w1 _, z- D. G
68、 毛圈长:feather length
69、 厚薄段:mark+ ~, H# p* l# l8 k) O; _4 m) p5 l
70、 裂缝:split
71、 捻度:twist of yarn" }3 Z. h' j9 s4 C
72、 浸润剂含量:size content
73、 浸润剂残留量:size residue' Ep+ w- S6 W7 T
74、 处理剂含量:finish level3 `% Y$ Q, [1 r
75、 浸润剂:size/ f( a! g$ u/ o# f+ s! h
76、 偶联剂:couplint agent- _]' W9 `$ i/ M7 \! k2 j
77、 处理织物:finished fabric
78、 聚酰胺纤维:polyarmide fiber
79、 聚酯纤维非织布:non-woven polyester fabric& U/ c: W7 _) w2 X0 J" k
80、 浸渍绝缘纵纸:impregnating insulation paper7 `5 L/ V# g/ c$ \" p! t
81、 聚芳酰胺纤维纸:aromatic polyamide paper
82、 断裂长:breaking length0 T. {: U- s. \2 D1 h
83、 吸水高度:height of capillary rise
84、 湿强度保留率:wet strength retention
85、 白度:whitenness6 z% F7 G6 @( x2 T0 d4 \6 T; J
86、 陶瓷:ceramics
87、 导电箔:conductive foil
88、 铜箔:copper foil0 _+ ^4 I6 v+ n' k9 d5 }r
89、 电解铜箔:electrodeposited copper foil (ed copper foil)
90、 压延铜箔:rolled copper foil: S9 e# D) Vd! |) u# L0 Lk
91、 退火铜箔:annealed copper foil
92、 压延退火铜箔:rolled annealed copper foil (ra copper foil)9 ^8 T1 f* d; u3 V$ J. m
93、 薄铜箔:thin copper foil 3 O& m- n! J@- D) e' h6 @2 p" ]
94、 涂胶铜箔:adhesive coated foil! S7 E: N7 c. \2 P: k( c0 I! \4 C0 C
95、 涂胶脂铜箔:resin coated copper foil (rcc)
96、 复合金属箔:composite metallic material
97、 载体箔:carrier foil! C4 c, W' O* q: y: L
98、 殷瓦:invar
99、 箔(剖面)轮廓:foil profile$ G1 |$ v8 s& W( u
100、 光面:shiny side
101、 粗糙面:matte side
102、 处理面:treated side7 C$ A+ v% ai$ F- N( x$ i
103、 防锈处理:stain proofing
104、 双面处理铜箔:double treated foil9 F+ m8 d' D2 q4 S- J3 i6 G
四、 设计
1、 原理图:shematic diagram/ }0 e3 P2 n. ]. N, C+ D
2、 逻辑图:logic diagram: i& @% E$ h+ B' f% K
3、 印制线路布设:printed wire layout
4、 布设总图:master drawing3 H* D. w1 oh2 ]' o
5、 可制造性设计:design-for-manufacturability
6、 计算机辅助设计:computer-aided design.(cad)w* S- T- J! J; H( u- j
7、 计算机辅助制造:computer-aided manufacturing.(cam)
8、 计算机集成制造:computer integrat manufacturing.(cim)0 H! n( U! L" \0 L/ M$ G6 C
9、 计算机辅助工程:computer-aided engineering.(cae): D6 v- Z. L! ?' h" t. q
10、 计算机辅助测试:computer-aided test.(cat)
11、 电子设计自动化:electric design automation .(eda)% j+ }6 q, _5 z7 t( S
12、 工程设计自动化:engineering design automaton .(eda2)9 E! [- |/ S" ]
13、 组装设计自动化:assembly aided architectural design. (aaad)
14、 计算机辅助制图:computer aided drawing/ ^) B( ^- G3 C& {& ^5 I+ L
15、 计算机控制显示:computer controlled display .(ccd). N& N" @( i9 x9 ?( e
16、 布局:placement`7 [" _% _6 X, S, }! P8 [
17、 布线:routing
18、 布图设计:layout" R2 Q" x$ ^( \2 N
19、 重布:rerouting
20、 模拟:simulation
21、 逻辑模拟:logic simulation/ @7 `0 ~4 J3 W8 c: o
22、 电路模拟:circit simulation: e0 k5 X$ n" A& C
23、 时序模拟:timing simulation
24、 模块化:modularization% t$ M) @; T+ T7 j/ ^% a2 z
25、 布线完成率:layout effeciency
26、 机器描述格式:machine descriptionm format .(mdf)
27、 机器描述格式数据库:mdf databse6 K. X. R) _) `) F
28、 设计数据库:design database
29、 设计原点:design origin
30、 优化(设计):optimization (design)5 o" X$ h% R# Y7 e' m- cp. ?: }
31、 供设计优化坐标轴:predominant axis" s' v1 O0 W5 o7 T) v8 W
32、 表格原点:table origin% _6 \, d' J% t: t5 [
33、 镜像:mirroring
34、 驱动文件:drive file2 u1 M; A' f( k
35、 中间文件:intermediate file
36、 制造文件:manufacturing documentation
37、 队列支撑数据库:queue support database
38、 元件安置:component positioning
39、 图形显示:graphics dispaly9 e3 \$ J" ?' X; o( `# x0 s
40、 比例因子:scaling factor
41、 扫描填充:scan filling
42、 矩形填充:rectangle filling5 r, J4 O9 ~! |! v( T
43、 填充域:region filling
44、 实体设计:physical design
45、 逻辑设计:logic design
46、 逻辑电路:logic circuit6 g! E! k' Y5 j0 f* }! l. R
47、 层次设计:hierarchical design
48、 自顶向下设计:top-down design2 k- @- `+ H) ]8 ^
49、 自底向上设计:bottom-up design
50、 线网:net
51、 数字化:digitzing
52、 设计规则检查:design rule checking$ W+ X/ h% g- q# B
53、 走(布)线器:router (cad)- T4 @' S- p& G6 c; ?- H. B4 O
54、 网络表:net list
55、 计算机辅助电路分析:computer-aided circuit analysis* e* b4 Q- a. X( ^' A9 v
56、 子线网:subnet
57、 目标函数:objective function
58、 设计后处理:post design processing (pdp)9 t. I" H+ T* s2 A! \. f- a
59、 交互式制图设计:interactive drawing design- C9 r: }% O' C. j2 E; @f% D# X
60、 费用矩阵:cost metrix
61、 工程图:engineering drawing
62、 方块框图:block diagram$ N1 W* d7 E. `4 Q
63、 迷宫:moze
64、 元件密度:component density
65、 巡回售货员问题:traveling salesman problem
66、 自由度:degrees freedom. b3 I, d& z0 x& ^; w2 [. e
67、 入度:out going degree
68、 出度:incoming degree
69、 曼哈顿距离:manhatton distance
70、 欧几里德距离:euclidean distance
71、 网络:network' \) u' G- t. w
72、 阵列:array
73、 段:segment4 O$ ~* U$ G* h" [# X
74、 逻辑:logic/ _# J( x% T( {8 [; v8 k2 f! N* j0 p
75、 逻辑设计自动化:logic design automation
76、 分线:separated time' {: u4 Q1 b0 h1 R. g% c
77、 分层:separated layer
78、 定顺序:definite sequence: }- `$ E0 M8 D- y* Q/ c# k
五、 形状与尺寸:* v! h; B' U7 A9 v& g& p
1、 导线(通道):conduction (track)
2、 导线(体)宽度:conductor width
3、 导线距离:conductor spacing
4、 导线层:conductor layer
5、 导线宽度/间距:conductor line/space
6、 第一导线层:conductor layer no.1* H: @1 T: D* N+ a6 m! f( ?
7、 圆形盘:round pad& [1 I) y, y/ F2 k$ k* x
8、 方形盘:square pad1 v) `4 E3 ]) o# [" I- {5 O* n8 [
9、 菱形盘:diamond pad
10、 长方形焊盘:oblong pad
11、 子弹形盘:bullet pad
12、 泪滴盘:teardrop pad
13、 雪人盘:snowman pad
14、 v形盘:v-shaped pad
15、 环形盘:annular pad
16、 非圆形盘:non-circular pad
17、 隔离盘:isolation pad
18、 非功能连接盘:monfunctional pad$ rk" F% x6 ]+ {' s5 U
19、 偏置连接盘:offset land8 A4 U! e9 V9 m) |; Q+ e5 {' d" W
20、 腹(背)裸盘:back-bard land- ]" SP" U, J" H5 t5 o9 S
21、 盘址:anchoring spaur4 L5 k3 p" `( ?4 f
22、 连接盘图形:land pattern
23、 连接盘网格阵列:land grid array
24、 孔环:annular ring
25、 元件孔:component hole
26、 安装孔:mounting hole; Y* z: m# J9 qE% w1 U
27、 支撑孔:supported hole- l; K9 n" \" e& x
28、 非支撑孔:unsupported hole
29、 导通孔:via( r8 v. Y& S0 Z2 Y6 S; f
30、 镀通孔:plated through hole (pth)
31、 余隙孔:access hole
32、 盲孔:blind via (hole)
33、 埋孔:buried via hole7 Y; I& {( J4 f% Q% G2 J' c
34、 埋/盲孔:buried /blind via1 D* p0 s2 ~/ h2 S3 I
35、 任意层内部导通孔:any layer inner via hole (alivh)# s7 k@9 V6 l+ N# o, v
36、 全部钻孔:all drilled hole: k9 J8 y1 E$ [1 G
37、 定位孔:toaling hole& d5 ]. K1 ]/ W3 Q8 n9 @
38、 无连接盘孔:landless hole
39、 中间孔:interstitial hole' D2 z% Z9 g# o6 C
40、 无连接盘导通孔:landless via hole* ?: }0 i9 ?% f& n0 H
41、 引导孔:pilot hole2 k1 [. z( H, D8 c
42、 端接全隙孔:terminal clearomee hole" @& E6 Z?/ p5 k: L; Q. \5 M5 b
43、 准表面间镀覆孔:quasi-interfacing plated-through hole
44、 准尺寸孔:dimensioned hole
45、 在连接盘中导通孔:via-in-pad% B. I2 F0 D+ ~; H1 A
46、 孔位:hole location5 v3 V) _: U+ E5 j7 [4 g
47、 孔密度:hole density
48、 孔图:hole pattern3 j' e& n7 p; Q4 `. q1 }
49、 钻孔图:drill drawing
50、 装配图:assembly drawing3 J$ KD: R' H0 d
51、 印制板组装图:printed board assembly drawing- z5 ~, |: {2 H$ \( T7 W
52、 参考基准:datum referance |
