重要提示:PCB作品文件展下载说明
| Name | PCB Decal | Value | Part Type | | BAT+ | 1.5DA | TEST_POINT | 1.5 | | BAT- | 1.5F | TEST_POINT | 1.5 | | CON3 | FPC6PIN | CONN6 | FPC6PIN | | CR7005 | CMP_419_3 | ESD9N5BM-2/TR | CMP_419 | | CR7008 | SMCR_P6X1P0_P40H | ESD | SMCR_P6X1P0_P40H | | CR7009 | SMCR_P6X1P0_P40H | ESD | SMCR_P6X1P0_P40H | | CR7010 | CMP_419_3 | ESD9N5BM-2/TR | CMP_419 | | CR7012 | SMCR_P6X1P0_P40H | ESD | SMCR_P6X1P0_P40H | | CR7013 | SMCR_P6X1P0_P40H | ESD | SMCR_P6X1P0_P40H | | CR8200 | D1206 | WSB5502W | D1206 | | CR9401 | CMP_419_3 | ESD9N5BM-2/TR | CMP_419 | | CR9402 | CMP_419_3 | ESD9N5BM-2/TR | CMP_419 | | CR9403 | CMP_419_3 | ESD9N5BM-2/TR | CMP_419 | | D1 | D1206 | B5819W | D1206 | | D2 | SOT23 | BAT54S | SOT23 | | D3 | D1206 | 5.6V | D1206 | | D903 | D1206 | B5819W/SOD123 | D1206 | | F9400 | R1206 | FUSE | R1206 | | FB4002 | R0402 | FERRITE_ALTSIZE | R0402 | | J3501 | TFABC | CON12_MICROSD_MTG4 | TFABC | | J4002 | SIM12PIN | CON8_MICRO_SIM_MTG4 | SIM12PIN | | J4101 | CMP_395_1 | CON4_COAX_2X2_MM4829_2702 | CMP_395 | | J6401 | CMP_395_1 | CON4_COAX_2X2_MM4829_2702 | CMP_395 | | J8504 | CON24 | CON24_RCPT_CAM_BYT_CR | CON24 | | J8505 | CON24 | CON24_RCPT_CAM_BYT_CR | CON24 | | J9400 | USB-ST-01H5-CA | CON5_USB_MICRO_AB_MTG4 | USB-ST-01H5-CA | | L1 | SML2520_1P0H_1 | 4.7UH/2A | SML2520_1P0H | | L2009 | SML2520_1P0H_1 | 4.7UH | SML2520_1P0H | | L4000 | R0201 | 4.7NH | R0201 | | L4001 | R0201 | 4.7NH | R0201 | | L6010 | CMP_418 | 6.8NH | CMP_418 | | L8205 | IND-4X4 | 4.7UH | IND-4X4 | | L8404 | SML_4P_43X53_CM_P35H | 80OHM_100MHZ | SML_4P_43X53_CM_P35H | | L8405 | SML_4P_43X53_CM_P35H | 80OHM_100MHZ | SML_4P_43X53_CM_P35H | | L8406 | SML_4P_43X53_CM_P35H | 80OHM_100MHZ | SML_4P_43X53_CM_P35H | | L8407 | SML_4P_43X53_CM_P35H | 80OHM_100MHZ | SML_4P_43X53_CM_P35H | | L8408 | SML_4P_43X53_CM_P35H | 80OHM_100MHZ | SML_4P_43X53_CM_P35H | | L9000 | CMP_521_1 | 80OHM_100MHZ | CMP_521 | | NTC | 1.5E | TEST_POINT | 1.5 | | PT11 | C-DIP | ICSRC-5210SFR | C-DIP | | Q1 | SOT723 | WNM2030 | SOT723 | | Q11 | SOT23 | WPM2026 | SOT23 | | Q12 | SOT23 | WPM2026 | SOT23 | | Q104 | SOT23 | NC/WNM2030 | SOT23 | | Q2000 | CMP_456_1 | WPM1481 | CMP_456 | | Q8400B | SOT723 | WNM2030 | SOT723 | | Q8401 | LCC6_P65MM_SQ2P05MM_NS | WPM1481 | LCC6_P65MM_SQ2P05MM_NS | | Q9503A | SOT723 | WNM2030 | SOT723 | | Q9503B | SOT723 | WNM2030 | SOT723 | | SH2003 | SHUNT_0402 | SHUNT_BYT_CR_MRD | SHUNT_0402 | | SH2004 | SHUNT_0402 | SHUNT_BYT_CR_MRD | SHUNT_0402 | | SH2005 | SHUNT_0402 | SHUNT_BYT_CR_MRD | SHUNT_0402 | | SH2006 | SHUNT_0402 | SHUNT_BYT_CR_MRD | SHUNT_0402 | | SH2007 | SHUNT_0402 | SHUNT_BYT_CR_MRD | SHUNT_0402 | | SH2008 | SHUNT_0402 | SHUNT_BYT_CR_MRD | SHUNT_0402 | | SH4001 | R0201 | SHUNT_LOCAL | R0201 | | SH4002 | R0201 | SHUNT_LOCAL | R0201 | | U4 | SOT26 | TCS3358 | SOT26 | | U16 | SOT25A | TCS9322 | SOT25 | | U17 | SOT-25 | RT9193-28GB | SOT-25 | | U18 | SOT-25 | TCS2109-1V2 | SOT-25 | | U23 | SOT23-6 | WD3126 | SOT23-6 | | U704 | UART-2 | UART | UART-2 | | U1000 | CMP_4 | SOC_VLV2_CR_CONCEPT_CUST_WW3 | CMP_4 | | U2003 | CMP_404 | AXP288_1P04 | CMP_404 | | U3005 | BGA96_P8MM_9P1X14P1 | MT41K256M16 | BGA96_P8MM_9P1X14P1 | | U3006 | BGA96_P8MM_9P1X14P1 | MT41K256M16 | BGA96_P8MM_9P1X14P1 | | U3500 | SOP8 | MX25U1635E | SOP8 | | U3501 | CMP_406 | KLM8G1WEMB_B031 | CMP_406 | | U4000 | CMP_409 | H350_A50_10 | CMP_409 | | U6013 | CMP_455 | SAFFB1G58KA0F0 | CMP_455 | | U6014 | CMP_451 | BCM4752IFBG_P12 | CMP_451 | | U6206 | CMP_405 | RL_SM02BD_8723BS | CMP_405 | | U6400 | LFD181 | LFD211G58DPFC268 | LFD181 | | U7001 | QFN48 | ALC5640_VB | CMP_518 | | U7002 | SOT25AA | 74LVC1G126 | SOT25 | | U7086 | FPC6PIN | CON2 | FPC6PIN | | U7087 | FPC6PIN | CON2 | FPC6PIN | | U8000 | LTR-533 | JSA1213 | LTR-533 | | U8001 | CMP_513 | KXCJK_1013 | CMP_513 | | U8200 | SOT26 | KTD2511CEHD | SOT26 | | U9001 | CMP_512 | TUSB1210 | CMP_512 | | U9009 | CMP_511 | 74AVC1T45YZP | CMP_511 | | U9010 | CMP_377 | AOZ6184_DPDT | CMP_377 | | U9012 | FPC32PIN | 40PIN | FPC32PIN | | Y1000 | CMP_516 | 25.0MHZ | CMP_516 | | Y1001 | SMY2P_49X83 | 32.768KHZ | SMY2P_49X83 | | Y6001 | CMP_453 | 26MHZ | CMP_453 |
重要提示:PCB作品文件展下载说明
