TA的每日心情 | 开心 2025-4-15 09:12 |
签到天数: 127 天 [LV.7]常住居民III
- 1471
发表于 2023-2-3 10:24:06
显示全部楼层
Name Part Type PCB Decal
ANT1 ANT/3P/MT7658/BT1 ANT/3P/MT7658/BT1
BC1 BARCODE-33X7 BARCODE-33X7
CON1 COAXIAL/SMD/CON/V/I-PEX COAXIAL/SMD/CON/V/I-PEX
CON2 COAXIAL/SMD/CON/V/I-PEX COAXIAL/SMD/CON/V/I-PEX
CON5 COAXIAL/SMD/CON/V/I-PEX COAXIAL/SMD/CON/V/I-PEX
CON6 COAXIAL/SMD/CON/V/I-PEX COAXIAL/SMD/CON/V/I-PEX
D7 LED/SMD/0603 LED/SMD/0603
D9 LED/SMD/0603 LED/SMD/0603
D11 D/SMD/P3.325/SOD-123/1N4148 D/SMD/P3.325/SOD-123/1N4148
D12 D/SMD/P6.61/B540C D/SMD/P6.61/B540C
H12 HOLE/PTH/R0.762X1.6D0.508X1.3 HOLE/PTH/R0.762X1.6D0.508X1.3
H13 TOOLING_HOLE/3.5MM TOOLING_HOLE/3.5MM
H14 HOLE/PTH/R0.762X1.6D0.508X1.3 HOLE/PTH/R0.762X1.6D0.508X1.3
H15 HOLE/PTH/R0.762X1.6D0.508X1.3 HOLE/PTH/R0.762X1.6D0.508X1.3
J4 DIP4/P2.54 DIP4/P2.54
J6 CON\\DC-JACK\\4.7 CON\\DC-JACK\\4.7
L29 L/SMD/GNR6045PM-2R2M L/SMD/GNR6045PM-2R2M
L30 L/SMD/GNR6045PM-2R2M L/SMD/GNR6045PM-2R2M
L360 L0603 L0603
L361 L0402 L0402
L1323 L/SMD/GNR6045PM-2R2M L/SMD/GNR6045PM-2R2M
L1324 L/SMD/GNR6045PM-2R2M L/SMD/GNR6045PM-2R2M
L1325 L/SMD/GNR6045PM-2R2M L/SMD/GNR6045PM-2R2M
P1 RJ45/8P/DIP/R/8208C-B01 RJ45/8P/DIP/R/8208C-B01
P1202 PHJ8X4_N PHJ8X4_N
S4 SW-2P2T-6.3 SW-2P2T-6.3
S5 SW-TACT\\4.5MM SW-TACT\\4.5MM
SH3 HOLE/PTH/R0.8128X1.6D0.508X1.35 HOLE/PTH/R0.8128X1.6D0.508X1.35
SH5 HOLE/PTH/R0.8128X1.6D0.508X1.35 HOLE/PTH/R0.8128X1.6D0.508X1.35
SH7 HOLE/PTH/R0.8128X1.6D0.508X1.35 HOLE/PTH/R0.8128X1.6D0.508X1.35
T300 TRANSFORMER/48P/SMD/GS5014LF TRANSFORMER/48P/SMD/GS5014LF
T301 TRANSFORMER/48P/SMD/GS5014LF TRANSFORMER/48P/SMD/GS5014LF
T302 TRANSFORMER/24P/SMD/HN2429CG TRANSFORMER/24P/SMD/HN2429CG
U6 MT7621/LFBGA346/P0.65/B0.3/11.7X13.6 MT7621/LFBGA346/P0.65/B0.3/11.7X13.6
U8 SOP8/SMD/P1.27/MX25L3206E SOP8/SMD/P1.27/MX25L3206E
U9 DIPLEXER/6P/SMD/DPX165900DT-8025A1/TDK DIPLEXER/6P/SMD/DPX165900DT-8025A1/TDK
U10 SOT23-6 SOT23-6
U23 XTAL-SMD/3.2X2.5 XTAL-SMD/3.2X2.5
U24 FBGA96/SMD/P0.8/MICRON FBGA96/SMD/P0.8/MICRON
U83 SOT-143/SMD/G693 SOT-143/SMD/G693
U450 TSOP48/SMD TSOP48/SMD
U1257 SOT23-6 SOT23-6
U1260 SOT23-5 SOT23-5
U1263 SOT23-6 SOT23-6
U1264 SOT23-6 SOT23-6
U1302 SOT223-3/SMD/P2.3/AX1007 SOT223-3/SMD/P2.3/AX1007
U1305 FILTER/3P/SMD/RFBPF1608060K98Q1C FILTER/3P/SMD/RFBPF1608060K98Q1C
U1308 MT7975/DRQFN111/SMD/10.5X9 MT7975/DRQFN111/SMD/10.5X9
U1309 MT7915/DR-QFN164/SMD/P0.5/12X12 MT7915/DR-QFN164/SMD/P0.5/12X12
U1310 SOT23-6 SOT23-6
U1312 FILTER/3P/SMD/RFBPF1608060K98Q1C FILTER/3P/SMD/RFBPF1608060K98Q1C
U1313 QFN6/SMD/P0.35/RTC6608OSP QFN6/SMD/P0.35/RTC6608OSP
WCON24 COAXIAL/SMD/CON/V/I-PEX COAXIAL/SMD/CON/V/I-PEX
WCON25 COAXIAL/SMD/CON/V/I-PEX COAXIAL/SMD/CON/V/I-PEX
WU4 CRYS/SMD/D3.2X2.5/E3SB40/HOSONIC CRYS/SMD/D3.2X2.5/E3SB40/HOSONIC |
