| 6292 | Restored the possibility to change lifecycles when working with versions of Altium Vault earlier than 2.5. |
| 6317 | Undo of component layer flip no longer modifies the component's Flipped On Layer property. |
| 6409 | Resolved an issue when managed project was invisible in AltiumDesigner when it was created in repository which URL had "/" at the end. |
| 6427 | Resolved an issue when generation STEP file from output job was impossible. |
| 6239 | False violations of Board Outline Clearance rule no longer occurs for primitives on Mechanical layers. |
| 6277 | Resolved an issue with schematics where the compiler did nothighlight an error for components which have duplicate designators (BC:5449). |
| 6349 | Altium Designer no longer crashes when rendering a solder mask for pads, after switching from 2D to 3D. |
| 6351 | Altium Designer no longer crashes when user removes polygons imported from Camtastic. |
| 6369 | Restored the ability to change all selected cells at Next State column in Batch. |
| 6376 | Extruded 3D Body objects converted to STEP in Altium DesignerVersions 15.0 and earlier now retain their shapes in Altium DesignerVersion 15.1 (BC:5467, BC:5511). |
| 6013 | Resolved an issue with component rotation during Eagle import with non US regional settings. |
| 6040 | Objects selected in PCB Layout using the Board Insight panel now correctly update the PCB Inspector panel. |
| 6284 | Added the option to display mechanical layers in board planning mode. |
| 6310 | Fixed crash during sequential repour of overlapped polygons. |
