| REF | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CA19 | ELCAPD5_CD110D5L12_100U/16V | 100u/16V | CD110D5L12 |
| CON1 | PCMCIA_T_WG_PCMCIA_PCMCIA_T | PCMCIA_T | WG_PCMCIA |
| CON2 | HDMI_HDMI_HDMI | HDMI | HDMI |
| CON3 | PHONOJACK_CK35-215_PHONOJACK | PHONOJACK | CK35-215 |
| CON4 | RCA-1_AV1-8R4-30_RCA-1 | RCA-1 | AV1-8R4-30 |
| CON5 | SCART_CS-107T_SCART | SCART | CS-107T |
| CON6 | PHONOJACK_CK35-215_PHONOJACK | PHONOJACK | CK35-215 |
| CON7 | HDMI_HDMI_HDMI | HDMI | HDMI |
| CON8 | HDMI_HDMI_HDMI | HDMI | HDMI |
| CON9 | VGA_DB15-1_VGA | VGA | DB15-1 |
| D1 | SK34_DO214AA_SK34 | SK34 | DO214AA |
| D2 | 1N4148_LL34_1N4148 | 1N4148 | LL34 |
| D3 | SK34_DO214AA_IN4007 | IN4007 | DO214AA |
| D4 | HDMI_DIODEZENER_1_E0402_NC | NC | E0402 |
| D5 | 1N4148_LL34_1N4148 | 1N4148 | LL34 |
| DD1 | BAV99_SOT23_BAV99 | BAV99 | SOT23 |
| H1 | DIP_LOGO_DIP_LOGO_MANUFACTURE_D | DIP_LOGO | DIP_LOGO_MANUFACTURE |
| H2 | P_O_P_O_MANUFACTURE_P_O | P_O | P_O_MANUFACTURE |
| H3 | QC_PASS_QC_PASS_MANUFACTURE_QC_ | QC_PASS | QC_PASS_MANUFACTURE |
| H4 | PCB_LOGO_PCB_LOGO_MANUFACTURE_P | PCB_LOGO | PCB_LOGO_MANUFACTURE |
| H5 | S/N_S_N_MANUFACTURE_S/N | S/N | S_N_MANUFACTURE |
| J1 | HEAD2X10_0_HEADER2X5_2MMM_HEAD | HEAD 2X5 | HEADER2X5_2MMM |
| J2 | XH-4A_SPEARK_BTL_TJC3-4A_XH-4A_ | XH-4A_SPEARK_BTL | TJC3-4A |
| J3 | XH-4A_AMPLIFIERPOWER_TJC3-4A_X | XH-4A_AMPLIFIER POWER | TJC3-4A |
| J4 | AV3-8R4-5_AV3-8R4-30_NC | NC | AV3-8R4-30 |
| J5 | PH-3A_PH-3A_PH-3A | PH-3A | PH-3A |
| J6 | HEAD2X20_LVDS_HEADER2X20_2MM_L | HEAD 2x20_LVDS | HEADER2X20_2MM_LVDS |
| J7 | HEAD 1X3_2.5_PANELPOWER_SIP_JU | HEAD 1x3_2.5_PANELPOWER | SIP_JUMP3 |
| J8 | PH-8A_DVDPOWER&CONTROL_PH-8A_P | PH-8A | PH-8A |
| J9 | XH-10A_POWER_TJC3-10A_XH-10A_PO | XH-10A_POWER | TJC3-10A |
| J10 | USB-H_USB_H_USB-H | USB-H | USB_H |
| J11 | PH-14A_PH-14A_PH-14A | PH-14A | PH-14A |
| J12 | CON4_PH-4A_NC | NC | PH-4A |
| J13 | PH-6A_INVERTER_PH-6A_PH-6A_INVE | PH-6A_INVERTER | PH-6A |
| J14 | SHIELD_SCALER_6_SHIELD_JL_SHIEL | shield_scaler_6 | SHIELD_JL |
| J15 | HEAD 2X10_HDMI_0_HEADER2X10_2M | NC | HEADER2X10_2MM_IN-HDMI |
| J16 | PH-11A_YPBPR&AUDIO_PH-11A_PH-1 | PH-11A_YPBPR&AUDIO | PH-11A |
| J17 | AV3-8R4-5_AV3-8R4-30_NC | NC | AV3-8R4-30 |
| J18 | RF_DVB-T_RF_CON2_RF_DVB-T | RF_DVB-T | RF_CON2 |
| J19 | HEAD 1X3_1.5_PANELPOWER_SIP_JU | DIP 1*3 | SIP_JUMP3 |
| J20 | PH-2A_PH-2A_PH-2A/NC | PH-2A/NC | PH-2A |
| L1 | INDUCTOR_L0810_L0810_DIP_32UH/3 | 32uH/3A | L0810_DIP |
| L2 | INDUCTOR_L0810_L0810_DIP_32UH/3 | 32uH/3A | L0810_DIP |
| L3 | INDUCTOR_L0810_L0810_DIP_32UH/3 | 32uH/3A | L0810_DIP |
| L4 | INDUCTOR_L0810_L0810_DIP_32UH/3 | 32uH/3A | L0810_DIP |
| L5 | FB1206_L1206_FUSE1.1A | FUSE 1.1A | L1206 |
| L6 | FB1206_FB0603_FB0603 | FB0603 | FB0603 |
| L7 | FB1206_L1206_NC | NC | L1206 |
| L8 | FB1206_FB0603_NC | NC | FB0603 |
| L9 | INDUCTOR_SMD_WSA43-6R8M-R_6.8UH | 6.8uH | WSA43-6R8M-R |
| L10 | FB0805_FB0805_10UH | 10UH | FB0805 |
| L11 | FB0805_FB0805_10UH | 10UH | FB0805 |
| L12 | CHOKE RF_FB0603_NC | NC | FB0603 |
| L13 | FB0603_FB0603_FB0603 | FB0603 | FB0603 |
| L14 | FB0603_FB0603_FB0603 | FB0603 | FB0603 |
| L15 | FB0603_FB0603_FB0603 | FB0603 | FB0603 |
| Q1 | MMBT3904_SOT23_3904 | 3904 | SOT23 |
| Q2 | BAV70_SOT23_BAV70 | BAV70 | SOT23 |
| Q3 | MMBT3906_SOT23_3906 | 3906 | SOT23 |
| Q4 | MMBT3904_SOT23_3904 | 3904 | SOT23 |
| Q6 | 3401_SOT23L_3407 | 3407 | SOT23L |
| Q7 | 3401_SOT23L_3407 | 3407 | SOT23L |
| Q29 | MMBT3904_SOT23_3904 | 3904 | SOT23 |
| U1 | TPA3110D2_TSSOP28_TPA3110D2 | TPA3110D2 | TSSOP28 |
| U2 | DDR3_IC_96P_TFBGA_DDR3_K4B1G164 | K4B1G1646G-BCK0 | IC_96P_TFBGA_DDR3 |
| U3 | LDO-1117_SOT223_BL1117-ADJ | BL1117-ADJ | SOT223 |
| U4 | A717X17_13_IC_21X21P_P0_8MM_1_ | MSD309B_17x17 | IC_21X21P_P0_8MM_1 |
| U5 | FLASH_SOP8_255_50_MX25L3206 | MX25L3206 | SOP8_255_50 |
| U6 | G5628_SOT23_5_SY8009A | SY8009A | SOT23_5 |
| U7 | LDO-1117_SOT223_BL1117-3.3V | BL1117-3.3V | SOT223 |
| U8 | LDO-1117_SOT223_BL1117-3.3V | BL1117-3.3V | SOT223 |
| U9 | LDO-1117_SOT223_BL1117-3.3V | BL1117-3.3V | SOT223 |
| U10 | PI5V330_QSOP16_PI5V330 | PI5V330 | QSOP16 |
| U11 | TUNER_0_TUNER_SMD_TUNER | TUNER | TUNER_SMD |
| U12 | 24C08_SOIC8_NC/24C04 | NC/24C04 | SOIC8 |
| Y1 | CRYSTAL_XTAL_HC49_F_24MHZ/DIP | 24MHz/DIP | XTAL_HC49_F |
