重要提示:PCB作品文件展下载说明
板子收集来的,由于没有原理图。好多信息查不到。板子里面也没有信息。PCB文件名写:RF_Digital 。共享上来。有需要的下载。没需要的看看就好。
REFDES | COMP_DEVICE_TYPE | SYM_NAME | BT1 | CR1220 | CR1220 | C11 | SMT_DIA10MM | SMT_DIA10MM | C17 | SMT_DIA10MM | SMT_DIA10MM | C18 | FPC-0402C | FPC-0402C | C19 | SMT_DIA10MM | SMT_DIA10MM | D3 | LED_0603_C1 | LED_0603_C1 | D4 | SMB-RC | SMB-RC | D12 | 1206-DIODE | 1206-DIODE | D20 | SOT23T02 | SOT23T02 | D24 | LED_0603_C1 | LED_0603_C1 | D25 | LED_0603_C1 | LED_0603_C1 | D26 | 1206-DIODE | 1206-DIODE | D27 | LED_0603_C1 | LED_0603_C1 | D29 | LED_0603_C1 | LED_0603_C1 | D31 | 1206-DIODE | 1206-DIODE | D32 | LED_0603_C1 | LED_0603_C1 | D33 | LED_0603_C1 | LED_0603_C1 | D34 | 1206-DIODE | 1206-DIODE | D35 | SOD-323 | SOD-323 | D36 | SOD-323 | SOD-323 | D42 | 1206-DIODE | 1206-DIODE | D44 | SOD-323 | SOD-323 | D48 | LED_0603_C1 | LED_0603_C1 | D49 | TO-277A | TO-277A | D50 | 1206-DIODE | 1206-DIODE | D51 | 1206-DIODE | 1206-DIODE | D52 | TO-277A | TO-277A | D53 | TO-277A | TO-277A | F1 | FUSE_10A | FUSE_10A | J2 | SIM | SIM | J15 | IDC20A | IDC20A | J16 | SIP3 | SIP3 | J21 | SIP2 | SIP2 | J22 | USB_A_TH_SAMTEC | USB_A_TH_SAMTEC | J25 | SSMB-50JHD | SSMB-50JHD | J26 | SSMB-50JHD | SSMB-50JHD | J27 | SSMB-50JHD | SSMB-50JHD | J28 | SSMB-50JHD | SSMB-50JHD | J31 | IDC8A | IDC8A | J32 | IDC8A | IDC8A | J34 | IDC8A | IDC8A | L131 | IND_ACM_4532 | IND_ACM_4532 | L132 | FPC-0805L | FPC-0805L | L159 | IND_10MMX10MM2 | IND_10MMX10MM2 | L267 | IND_ACM_4532 | IND_ACM_4532 | MG6 | TO-263 | TO-263 | P1 | CON8_RJ45_JACK_LED | CON8_RJ45_JACK_LED | Q1 | SC-89 | SC-89 | Q2 | SOT-23A | SOT-23A | RN95 | RP8 | RP8 | SW3 | SW-QC | SW-QC | SW4 | T1011LTNQ | T1011LTNQ | SW6 | SW-QC | SW-QC | T1 | H1102_XFMR16_SM | H1102_XFMR16_SM | T16 | SM-22 | SM-22 | T22 | TC4-1W | TC4-1W | U1 | SOT-23-5 | SOT-23-5 | U2 | SLM110-MODIFY | SLM110-MODIFY | U3 | GL868 | GL868 | U4 | SOIC-8A | SOIC-8A | U5 | CP-64-3 | CP-64-3 | U6 | SO-8 | SO-8 | U7 | SOT-23-5 | SOT-23-5 | U8 | TQFP-100 | TQFP-100 | U9 | FGG484 | FGG484 | U10 | MBPD | MBPD | U11 | TQFP-100 | TQFP-100 | U12 | MBPD | MBPD | U13 | SV-100-1 | SV-100-1 | U14 | SV-100-1 | SV-100-1 | U15 | MMIC-10 | MMIC-10 | U16 | SOIC-8A | SOIC-8A | U17 | SSOP16 | SSOP16 | U18 | SO-8A | SO-8A | U19 | SO-8 | SO-8 | U20 | SC-70-5 | SC-70-5 | U21 | IDC10A | IDC10A | U22 | SV-100-1 | SV-100-1 | U23 | SOT-223 | SOT-223 | U24 | TSOP56_A | TSOP56_A | U25 | SC70-5 | SC70-5 | U26 | TSOPII_54 | TSOPII_54 | U27 | SO-14 | SO-14 | U28 | LQFP48 | LQFP48 | U29 | SOIC-16 | SOIC-16 | U30 | ZD21-17K-0211-10M | ZD21-17K-0211-10M | U32 | LLP-16 | LLP-16 | U33 | SOT-25A | SOT-25A | U34 | TFBGA208 | TFBGA208 | U35 | SO-8A | SO-8A | U36 | LLP-16 | LLP-16 | U37 | SOT-23 | SOT-23 | U38 | SOT-23 | SOT-23 | U39 | QFN-20 | QFN-20 | U40 | SOT-89 | SOT-89 | U41 | QFN-20 | QFN-20 | U44 | SOT-23 | SOT-23 | U45 | SOT-223 | SOT-223 | U50 | SO-8 | SO-8 | U54 | SOT23-5L | SOT23-5L | U58 | SO-8 | SO-8 | U60 | SOIC-8C | SOIC-8C | U65 | KSP-5A | KSP-5A | U78 | VC936B | VC936B | U80 | CP-64-4 | CP-64-4 | U82 | TSOC-6 | TSOC-6 | U83 | SOIC-8 | SOIC-8 | U91 | SOT-89 | SOT-89 | U103 | CP-24-3 | CP-24-3 | U104 | SAW | SAW | U105 | CP-24-3 | CP-24-3 | U106 | SOT-89 | SOT-89 | U107 | SAW | SAW | U109 | CP-24-3 | CP-24-3 | U117 | TO-263 | TO-263 | U121 | 40-PIN-TQFN | 40-PIN-TQFN | U122 | TX_10MHZ | TX_10MHZ | U123 | SOT-23 | SOT-23 | V6 | SOT-89 | SOT-89 | X10 | SMA-50KFD | SMA-50KFD | Y5 | XTL_HC49SLF | XTL_HC49SLF | Y6 | XTL_D3MM | XTL_D3MM | Y8 | SMD7050 | SMD7050 |
重要提示:PCB作品文件展下载说明
