SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
MTG156_PTH | MOUNT_HOLE_MTG156_PTH_IC_0.05MM | MOUNTING HOLE | | IC | BH1 |
MTG156_PTH | MOUNT_HOLE_MTG156_PTH_IC_0.05MM | MOUNTING HOLE | | IC | BH2 |
MTG156_PTH | MOUNT_HOLE_MTG156_PTH_IC_0.05MM | MOUNTING HOLE | | IC | BH3 |
MTG156_PTH | MOUNT_HOLE_MTG156_PTH_IC_0.05MM | MOUNTING HOLE | | IC | BH4 |
MTG156_PTH | MOUNT_HOLE_MTG156_PTH_IC_0.05MM | MOUNTING HOLE | | IC | BH5 |
MTG156_PTH | MOUNT_HOLE_MTG156_PTH_IC_0.05MM | MOUNTING HOLE | | IC | BH6 |
MTG156_PTH | MOUNT_HOLE_MTG156_PTH_IC_0.05MM | MOUNTING HOLE | | IC | BH7 |
MH175-125P | MOUNT_HOLE_MH175-125P_IC_0MM_2 | Mounting Hole | | IC | BH8 |
CONN_BATTERY | LICELL_A_CONN_BATTERY_IC_5.35MM | HU2032-LF | | IC | BT1 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_2 | 22uF | 20% | DISCRETE | C3 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_2 | 22uF | 20% | DISCRETE | C4 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C5 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_2 | 22uF | 20% | DISCRETE | C6 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C7 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C25 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C28 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C29 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C30 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C31 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C32 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C33 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C34 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C35 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C36 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C37 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C38 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C39 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C40 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C41 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C42 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C43 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C44 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C45 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C46 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C47 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C48 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C49 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C50 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C51 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C52 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 10pF | | DISCRETE | C53 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._11 | 330PF | | DISCRETE | C54 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 10pF | | DISCRETE | C55 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._11 | 330PF | | DISCRETE | C56 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C57 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C60 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C61 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C62 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C63 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C64 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C65 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C66 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C67 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C68 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C69 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C70 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C71 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C72 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C73 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C74 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C75 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C79 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C80 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C81 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C83 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C84 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C85 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C87 |
CC_D4 | CAP_POL_CC_D4_DISCRETE_3MM_150- | 470UF | | DISCRETE | C88 |
CC7343 | CAP_POL_CC7343_DISCRETE_3.1MM_1 | 220UF | | DISCRETE | C89 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C90 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C91 |
CC7343 | CAP_POL_CC7343_DISCRETE_3.1MM_1 | 220UF | | DISCRETE | C92 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C93 |
CC_D4 | CAP_POL_CC_D4_DISCRETE_3MM_150- | 470UF | | DISCRETE | C94 |
CC7343 | CAP_POL_CC7343_DISCRETE_3.1MM_1 | 220UF | | DISCRETE | C95 |
CC7343 | CAP_POL_CC7343_DISCRETE_3.1MM_1 | 220UF | | DISCRETE | C96 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C97 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C98 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C99 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C100 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C101 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C102 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C103 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C108 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C109 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C110 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C111 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C112 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C113 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C114 |
CC7361 | CAP_POL_CC7361_DISCRETE_3.75MM_ | 100UF | | DISCRETE | C115 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM_15 | 100UF | | DISCRETE | C116 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C117 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C118 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C119 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C120 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C121 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C122 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C123 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C124 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C125 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C129 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C131 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C133 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C135 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C137 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C138 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C139 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C140 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C141 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C142 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C143 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C144 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__1 | 22UF | | DISCRETE | C145 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C148 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C180 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C181 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C182 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C183 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C184 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C185 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C186 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._13 | 3300pF | | DISCRETE | C187 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C188 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C189 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._13 | 3300pF | | DISCRETE | C190 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C191 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C192 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C193 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C194 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C195 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C196 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C197 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C198 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C199 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C200 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C201 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C202 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C203 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C204 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C205 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C206 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C207 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C208 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._13 | 3300pF | | DISCRETE | C209 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C210 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._13 | 3300pF | | DISCRETE | C211 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C212 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C213 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C214 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C215 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C216 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C217 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C218 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C219 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C220 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C221 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C222 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C223 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C224 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C225 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C226 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C227 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C228 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C229 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C230 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C231 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C232 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C233 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C234 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C235 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C236 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C237 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C241 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C242 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C243 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C244 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C245 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C246 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C247 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C248 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 1.0UF | 10% | DISCRETE | C249 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C250 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C251 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C252 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C266 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C267 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C268 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C269 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C270 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C271 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C272 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C274 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C275 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C276 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C277 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C278 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C279 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C280 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C286 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C287 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C328 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C329 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C330 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C333 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C345 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C346 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C347 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C348 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C349 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C350 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C351 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C352 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C353 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C354 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C355 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C356 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C357 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C358 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C359 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C360 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C361 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C362 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C363 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C364 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C365 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C366 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C367 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C368 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C369 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C370 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C371 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C372 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C373 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C374 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C375 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C376 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C377 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C378 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C379 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C380 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C381 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C382 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C383 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C384 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C385 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C386 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C387 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C388 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C389 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C390 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C391 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C392 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C393 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C394 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C395 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C396 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C397 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C398 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C399 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C400 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C401 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C402 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C403 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C408 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C409 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 4.7uF | | DISCRETE | C410 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C411 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C412 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C413 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C414 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C415 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C416 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C417 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C418 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C419 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C420 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C421 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C422 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C423 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C424 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C425 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C426 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C427 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C428 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C429 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C430 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C435 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C436 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C437 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C438 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C439 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C440 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C442 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C443 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C445 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C446 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C447 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C448 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C449 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C450 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C451 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C452 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C453 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C454 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C455 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C456 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C457 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C505 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C506 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C519 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C520 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C533 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C534 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | | DISCRETE | C535 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | | DISCRETE | C536 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | | DISCRETE | C537 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | | DISCRETE | C538 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C548 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C549 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C560 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C561 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C563 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C564 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C565 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C566 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C567 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C568 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C569 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C570 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C571 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C572 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C573 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C574 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C575 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C576 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C577 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C578 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C579 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C580 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C583 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8MM | 22UF | 20% | DISCRETE | C584 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C585 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C587 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C588 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C589 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C590 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C591 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8MM | 22UF | 20% | DISCRETE | C592 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C593 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C594 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C595 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8MM | 22UF | 20% | DISCRETE | C596 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C597 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C598 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C599 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C600 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C601 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_4 | 1.0UF | | DISCRETE | C602 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C603 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C604 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C605 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_5 | 1.0UF | | DISCRETE | C606 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C607 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C608 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C609 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C610 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C611 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._15 | 0.22uF | 10% | DISCRETE | C612 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C613 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C614 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C615 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C616 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C617 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C618 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_5 | 1.0UF | | DISCRETE | C619 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C620 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C621 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C622 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._15 | 0.22uF | 10% | DISCRETE | C623 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C624 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C625 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C626 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C627 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C628 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C629 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C630 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C631 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C632 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C633 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C634 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C635 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C636 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C637 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C638 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C639 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C640 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C641 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_5 | 1.0UF | | DISCRETE | C642 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C643 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C644 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C646 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C647 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C649 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_5 | 1.0UF | | DISCRETE | C650 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C651 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C652 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 2.2uF | | DISCRETE | C653 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C654 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C655 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C658 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C659 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C660 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C661 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C663 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C664 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C665 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C666 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C667 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C668 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C669 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C670 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C671 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C672 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C673 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C674 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C675 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C676 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C677 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C678 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C679 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C680 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C681 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C682 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C683 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C684 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C685 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C686 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C687 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C688 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C689 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C690 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C691 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C692 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C693 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C694 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C695 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C696 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C697 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C698 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C699 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C700 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C701 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C702 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C703 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C704 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C705 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C706 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C715 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C716 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C717 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C718 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C719 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C720 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C721 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C722 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C723 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C724 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C725 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C726 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C727 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C728 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C729 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C730 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C731 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C732 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C733 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C735 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C736 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C747 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C748 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C749 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C750 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C751 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C752 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C753 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C754 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C755 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C756 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C759 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C760 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C761 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C762 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C763 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C764 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C765 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C766 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C767 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C770 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C771 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C772 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C773 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C774 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C775 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C776 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C777 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C778 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C779 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C782 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C783 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C784 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C785 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C786 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C787 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C788 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C789 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C790 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C791 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C792 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C793 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C794 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C795 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C796 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C797 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C798 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C799 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C800 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C801 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C802 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C803 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C804 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C805 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_2 | 0.1UF | | DISCRETE | C806 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_2 | 0.1UF | | DISCRETE | C807 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C808 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C809 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C810 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C811 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C812 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C813 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C814 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C815 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C816 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C817 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C818 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C821 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C822 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C823 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C825 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C826 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C827 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C828 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C829 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C830 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C831 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C832 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C833 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C834 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C835 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C836 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C837 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C838 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C839 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C840 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C841 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C842 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C843 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C844 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C845 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C846 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C847 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C848 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C849 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C850 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C851 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C852 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C853 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C854 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C855 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C858 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45 | 47uF | | DISCRETE | C859 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C860 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C861 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C862 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C863 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_5 | 1.0UF | | DISCRETE | C864 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | 470pF | | DISCRETE | C865 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C868 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C869 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C870 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C872 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C874 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C875 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C879 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C881 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C882 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C883 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C884 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C885 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C886 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C887 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C888 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C890 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C891 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C892 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C893 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C894 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 4700PF | | DISCRETE | C895 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C896 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C897 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C898 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C899 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 2.2uF | | DISCRETE | C900 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C901 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C902 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C906 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C908 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_3 | 22UF | 20% | DISCRETE | C910 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C911 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C912 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C913 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_3 | 22UF | 20% | DISCRETE | C914 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C915 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C917 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C919 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C920 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C921 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C922 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._16 | 0.022UF | 10% | DISCRETE | C923 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._16 | 0.022UF | 10% | DISCRETE | C924 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C925 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._15 | 0.22uF | 10% | DISCRETE | C926 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._15 | 0.22uF | 10% | DISCRETE | C927 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C928 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C929 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C930 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C931 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C932 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C933 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C964 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C965 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 4700PF | | DISCRETE | C966 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C967 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C968 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C969 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C970 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C971 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C972 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C973 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C974 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C975 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C979 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C982 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C983 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C984 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C985 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C987 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C988 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C992 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C993 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C994 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C995 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C996 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C997 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C998 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C999 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1000 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1001 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1002 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1003 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1004 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1005 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1006 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1007 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1008 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1009 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1010 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1011 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1012 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1013 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1014 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1015 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1016 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1017 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1018 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1019 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C1020 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1021 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1022 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1023 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1024 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1025 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1026 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1027 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1028 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1029 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1030 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1031 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C1032 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C1033 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C1034 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1035 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1036 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1037 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1038 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1039 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1040 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1041 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1042 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1043 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1044 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1045 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1046 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1047 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1048 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1049 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1050 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1051 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1052 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1053 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C1054 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1055 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1056 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1057 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1058 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1059 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1060 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1061 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1062 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1063 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1064 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1065 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1066 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1067 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1068 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1069 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1070 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1071 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1072 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1073 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1074 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1075 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1077 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1078 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1083 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1084 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1088 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1089 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1090 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1091 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1092 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1093 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1094 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1095 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1096 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1097 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1098 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1099 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1100 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1101 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1102 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1103 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | 5% | DISCRETE | C1104 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1107 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1108 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1111 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1112 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1113 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1114 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1122 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1123 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | 470pF | | DISCRETE | C1124 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | 470pF | | DISCRETE | C1125 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1126 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1127 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1128 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1129 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1130 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1131 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1132 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1133 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1134 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1135 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1136 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1137 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1138 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1139 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 100pF | 5% | DISCRETE | C1140 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1141 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | 10% | DISCRETE | C1142 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1145 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1146 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1147 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1155 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1156 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1157 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1158 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1159 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1160 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1161 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1162 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 4.7uF | | DISCRETE | C1163 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1164 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1165 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1166 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1167 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1168 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1169 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1170 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_2 | 0.1UF | | DISCRETE | C1171 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1172 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1173 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 4.7uF | | DISCRETE | C1174 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1175 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1176 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1177 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1178 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1179 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1180 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1181 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1182 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1183 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1184 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1185 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1186 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1187 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1188 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1189 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1190 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1191 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1192 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1193 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1194 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1195 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1196 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1197 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1198 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1199 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1200 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1201 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | | DISCRETE | C1202 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1203 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1204 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C1205 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C1206 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C1207 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1208 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1209 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1210 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1211 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1212 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1213 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1215 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C1216 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 4700PF | | DISCRETE | C1217 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 4700PF | | DISCRETE | C1218 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 2.2uF | | DISCRETE | C1219 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1220 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C1221 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1222 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C1223 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 4700PF | | DISCRETE | C1224 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 2.2uF | | DISCRETE | C1225 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1237 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1245 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1248 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1249 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1251 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C1252 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1256 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1257 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1258 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1259 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C1260 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1261 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1262 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1263 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 4700PF | | DISCRETE | C1264 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1265 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1266 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1267 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1268 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1269 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1270 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1271 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1272 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C1273 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 4700PF | | DISCRETE | C1274 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 2.2uF | | DISCRETE | C1275 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1276 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1277 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1279 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C1280 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1281 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1282 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1284 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1285 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1286 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1287 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56 | 27 PF | | DISCRETE | C1288 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56 | 27 PF | | DISCRETE | C1289 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1290 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1291 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1292 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1293 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1294 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1295 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C1298 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1300 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1301 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1302 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1303 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1304 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C1306 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C1308 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1309 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1311 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1312 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1313 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1314 |
CC7343A_LP | CAP_POL_CC7343A_LP_DISCRETE_2.1 | 560uF | | DISCRETE | C1315 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1316 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1317 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1318 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1319 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C1321 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1322 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1324 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1325 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1326 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1327 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1328 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1329 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1330 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1331 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1332 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1333 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1334 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1335 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2UF | 20% | DISCRETE | C1336 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C1338 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1340 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.55MM_1 | 4.7uF | | DISCRETE | C1341 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_ | 0.22UF | | DISCRETE | C1342 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C1343 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1344 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1345 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1346 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1347 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1348 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1349 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1350 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1351 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1352 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1353 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1354 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1355 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1356 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1357 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1358 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56 | 27 PF | | DISCRETE | C1359 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1360 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1361 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_7 | 2200PF | 5% | DISCRETE | C1363 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74M | 33PF | 5% | DISCRETE | C1365 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1366 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1367 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74M | 33PF | 5% | DISCRETE | C1368 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1369 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1370 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56 | 27 PF | | DISCRETE | C1371 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74M | 33PF | 5% | DISCRETE | C1372 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1374 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1375 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1376 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1377 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1378 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74M | 33PF | 5% | DISCRETE | C1379 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74M | 33PF | 5% | DISCRETE | C1380 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | | DISCRETE | C1381 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | | DISCRETE | C1382 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C1383 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1384 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 1000pF | | DISCRETE | C1385 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1386 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1387 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1389 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 1500pF | 5% | DISCRETE | C1392 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1393 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | 10% | DISCRETE | C1402 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9M | 100UF | | DISCRETE | C1403 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1404 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 1UF | | DISCRETE | C1405 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.87M | 2200PF | | DISCRETE | C1406 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 10pF | | DISCRETE | C1407 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_8 | 0.1uF | | DISCRETE | C1408 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1409 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | | DISCRETE | C1410 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 22uF | | DISCRETE | C1411 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_8 | 0.1uF | | DISCRETE | C1412 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 1UF | | DISCRETE | C1413 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1414 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C1415 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 22uF | | DISCRETE | C1416 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1417 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 1UF | | DISCRETE | C1418 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.87M | 2200PF | | DISCRETE | C1419 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 10pF | | DISCRETE | C1420 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_8 | 0.1uF | | DISCRETE | C1421 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1422 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | | DISCRETE | C1423 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 22uF | | DISCRETE | C1424 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_8 | 0.1uF | | DISCRETE | C1425 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 1UF | | DISCRETE | C1426 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1427 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C1428 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 22uF | | DISCRETE | C1429 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | | DISCRETE | C1430 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C1435 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_9 | 0.1uF | | DISCRETE | C1436 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | 10% | DISCRETE | C1438 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1440 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | 10% | DISCRETE | C1441 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1442 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C1443 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | 20% | DISCRETE | C1444 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7_1 | 0.01UF | | DISCRETE | C1447 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C1466 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._10 | 0.1uF | | DISCRETE | C1467 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.8MM__2 | 100uF | | DISCRETE | C1468 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._10 | 0.1uF | | DISCRETE | C1469 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C1471 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | | DISCRETE | C1472 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._10 | 0.1uF | | DISCRETE | C1473 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._10 | 0.1uF | | DISCRETE | C1474 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._10 | 0.1uF | | DISCRETE | C1475 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1476 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22uF | | DISCRETE | C1477 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | 0.022UF | | DISCRETE | C1478 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1479 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1480 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 470UF | | DISCRETE | C1481 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._11 | 330PF | | DISCRETE | C1482 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | | DISCRETE | C1483 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C1484 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7_1 | 0.01UF | | DISCRETE | C1487 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7_1 | 0.01UF | | DISCRETE | C1489 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C1491 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C1492 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C1493 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0._12 | 0.22uF | | DISCRETE | C1494 |
8X10P8 | CAP_POL_8X10P8_DISCRETE_10.5MM | 330uF | | DISCRETE | C1495 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1496 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 1UF | | DISCRETE | C1497 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.87M | 2200PF | | DISCRETE | C1498 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 10pF | | DISCRETE | C1499 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_8 | 0.1uF | | DISCRETE | C1500 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1501 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | | DISCRETE | C1502 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 22uF | | DISCRETE | C1503 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_8 | 0.1uF | | DISCRETE | C1504 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 1UF | | DISCRETE | C1505 |
CC1210 | MOT_CAP_CC1210_DISCRETE_2.7MM_ | 47UF | | DISCRETE | C1506 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 22uF | | DISCRETE | C1507 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 1UF | | DISCRETE | C1508 |
SOD123LF | ZDIODE_SOD123LF_IC_1.2MM_480-78 | NZH15B | | IC | D1 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D2 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D4 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D5 |
SOD-882 | DIODE_SCHTKY_SOD-882_IC_0.5MM_4 | PMEG2005AEL | | IC | D8 |
SOD-882 | DIODE_SCHTKY_SOD-882_IC_0.5MM_4 | PMEG2005AEL | | IC | D9 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D23 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D24 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75078 | BLUE | | IC | D33 |
LED_0603 | LED_LED_0603_IC_0.65MM_370-7590 | RED LED | | IC | D34 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | | IC | D35 |
LED_0603 | LED_LED_0603_IC_0.65MM_370-7590 | RED LED | | IC | D36 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D37 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D38 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D39 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D40 |
LED_0603 | LED_LED_0603_IC_0.65MM_370-7590 | RED LED | | IC | D41 |
LED_0603 | LED_LED_0603_IC_0.65MM_370-7590 | RED LED | | IC | D42 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D43 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | | IC | D44 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | | IC | D45 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D48 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D49 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D50 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D51 |
LED_0603 | LED_LED_0603_IC_1.1MM_370-75143 | LED_GREEN | | IC | D52 |
FUSE_SMD050 | FUSE_RESETTABLE_FUSE_SMD050_DIS | 1A | | DISCRETE | F1 |
FUSE_SMD050 | FUSE_RESETTABLE_FUSE_SMD050_DIS | 1A | | DISCRETE | F2 |
FUSE_SMD050 | FUSE_RESETTABLE_FUSE_SMD050_DIS | 1A | | DISCRETE | F3 |
FUSE_SMD050 | FUSE_RESETTABLE_FUSE_SMD050_DIS | 1A | | DISCRETE | F4 |
FUSE_3P4X1P8 | FUSE_RST_FUSE_3P4X1P8_DISCRETE_ | 8A | | DISCRETE | F8 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB18 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB19 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB20 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB21 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB22 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB23 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB24 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB25 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB26 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB27 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.1MM_1 | 30 OHM | 25% | DISCRETE | FB28 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL13 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL14 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL15 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL16 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL17 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL18 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL19 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL20 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL21 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL22 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL25 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL26 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL27 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL28 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL29 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL30 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL31 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL32 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL33 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL34 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL35 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL36 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL37 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL38 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL39 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL40 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL41 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL42 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL43 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL44 |
CAP3_3P4X1P8_SM | EMIFILTER_CC_CAP3_3P4X1P8_SM_DI | 27uF | | DISCRETE | FL46 |
CAP3_3P4X1P8_SM | EMIFILTER_CC_CAP3_3P4X1P8_SM_DI | 27uF | | DISCRETE | FL47 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL49 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL50 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL51 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL52 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | | DISCRETE | FL53 |
FILTER6_12P3X9P3 | FILTER_BNX028_FILTER6_12P3X9P3_ | BNX028-01 | | IC | FL54 |
HDR1X3_TH | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | | IO | J4 |
HDR1X3_TH | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | | IO | J5 |
HDR1X3_TH | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | | IO | J6 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J7 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J8 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J10 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J11 |
HDR1X3_TH | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | | IO | J12 |
CON9_CARD_SMT | CONN_SD_CARD_9P_CON9_CARD_SMT_I | 2041021-1 | | IO | J31 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.38MM_ | HDR_1X3 | | IO | J33 |
CON9_USBA_VER_7P32X25P7 | USB_3P0_TYPEA_CON9_USBA_VER_7P3 | USB_TYPE_A | | IO | J34 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J35 |
CON10_MICROUSB_0P65MM_SM | USB_KMMX_10P_CON10_MICROUSB_0P6 | USB3_MICRO_AB | | IO | J36 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J37 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J39 |
SUBASSY_SFP-CAGE | CON_CAGE_SUBASSY_SFP-CAGE_IO_9. | CON 2X10 WITH SFPCAGE | | IO | J40 |
HDR205 | CONN_HDR_5X2_HDR205_IO_8.6MM_21 | HDR 2X5 | | IO | J41 |
CONN_PCIEXPRESS_67P_B | CON_67_FEMALE_RA_CONN_PCIEXPRES | M.2 SKT KEY-E | | IO | J42 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.38MM_ | HDR_1X3 | | IO | J44 |
CONN_PCIEXPRESS_67P_B | CON_67_FEMALE_RA_CONN_PCIEXPRES | M.2 SKT KEY-E | | IO | J45 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.38MM_ | HDR_1X3 | | IO | J46 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.38MM_ | HDR_1X3 | | IO | J47 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J48 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | TSW-102-08-G-S | | IO | J49 |
CON19_RJ-45_LED_80MIL_TH_RA_A | CON_RJ45_19P_A_CON19_RJ-45_LED_ | RJ45-19 | | IO | J50 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.38MM_ | HDR_1X3 | | IO | J54 |
HDR205_10M_50_SM_K | CONN_HDR_5X2_HDR205_10M_50_SM_K | FTSH-105-01-L-DV-K | | IO | J55 |
HDR210_50_TFM-SN | CONN_HDR_10X2_HDR210_50_TFM-SN_ | TFM-110-02-S-D-SN-K-TR | | IO | J59 |
TSM2X6_SMD | CONN_HDR_6X2_TSM2X6_SMD_IO_9.65 | HDR_2X6 | | IO | J62 |
JUMP1X8-6040 | HDR-1X8_JUMP1X8-6040_IO_8.382M | HDR_1X8 | | IO | J68 |
RJ45_2X2_LED_32P15X28P15_TH | CONN_RJ45_2X2_LED_TE_RJ45_2X2_L | RJ45_2X2 | | IO | J75 |
RJ45_2X2_LED_32P15X28P15_TH | CONN_RJ45_2X2_LED_TE_RJ45_2X2_L | RJ45_2X2 | | IO | J77 |
JACK_PWR_RA_4P | KPJX-4S-S_JACK_PWR_RA_4P_IO_15. | CON PWR JACK 4 | | IO | J85 |
CON4_MWCOAX_MM5829 | CON_COAX_MM9329_CON4_MWCOAX_MM5 | MM5829-2700 | | IO | J86 |
CON4_MWCOAX_MM5829 | CON_COAX_MM9329_CON4_MWCOAX_MM5 | MM5829-2700 | | IO | J87 |
CON4_MWCOAX_MM5829 | CON_COAX_MM9329_CON4_MWCOAX_MM5 | MM5829-2700 | | IO | J89 |
CON4_MWCOAX_MM5829 | CON_COAX_MM9329_CON4_MWCOAX_MM5 | MM5829-2700 | | IO | J90 |
HDR106_TH_TSW | CONN_HDR_6X1_HDR106_TH_TSW_IO_8 | HDR 1X6 | | IO | J91 |
HDR106_TH_TSW | CONN_HDR_6X1_HDR106_TH_TSW_IO_8 | HDR 1X6 | | IO | J92 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L1 |
IND2_10P4X8 | ETQP6F_2P_IND2_10P4X8_DISCRETE_ | 175nH | 10% | DISCRETE | L2 |
IND2_10P4X8 | ETQP6F_2P_IND2_10P4X8_DISCRETE_ | 175nH | 10% | DISCRETE | L3 |
IND_2016A | INDUCTOR_IND_2016A_DISCRETE_1.8 | 10UH | 20% | DISCRETE | L20 |
IND_2016A | INDUCTOR_IND_2016A_DISCRETE_1.8 | 10UH | 20% | DISCRETE | L21 |
IND_NFE31P | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | 50% | DISCRETE | L22 |
IND_NFE31P | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | 50% | DISCRETE | L25 |
IND_NFE31P | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | 50% | DISCRETE | L28 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L30 |
IND_2P2X2 | IND_IND_2P2X2_DISCRETE_1.4MM_18 | 4.7UH | 20% | DISCRETE | L35 |
IND_2P2X2 | IND_IND_2P2X2_DISCRETE_1.4MM_18 | 4.7UH | 20% | DISCRETE | L36 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L57 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L59 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L60 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L61 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L62 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L63 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L64 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L65 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L66 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L67 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L68 |
IND2_XAL70_245 | INDUCTOR_IND2_XAL70_245_DISCRET | 3.3uH | | DISCRETE | L69 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L70 |
IND2_XAL70_245 | INDUCTOR_IND2_XAL70_245_DISCRET | 3.3uH | | DISCRETE | L71 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L72 |
IND2_744308033 | INDUCTOR_IND2_744308033_DISCRET | 0.33uH | | DISCRETE | L74 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L75 |
IND2_XAL70_245 | INDUCTOR_IND2_XAL70_245_DISCRET | 3.3uH | | DISCRETE | L76 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | 20% | DISCRETE | L77 |
SOT23_A | MOSFET_N_SOT23_A_IC_1.1MM_480- | 2N7002 | | IC | M2 |
SOT23_A | MOSFET_N_SOT23_A_IC_1.1MM_480- | 2N7002 | | IC | M3 |
MH_C256-165T | MOUNT_HOLE_MH_C256-165T_IC_0.12 | M.2 MOUNTING HOLE | | IC | M4 |
MH_C256-165T | MOUNT_HOLE_MH_C256-165T_IC_0.12 | M.2 MOUNTING HOLE | | IC | M5 |
DUALDB-9MM | DSD9M_DUALDB-9MM_IO_31.75MM_210 | 2XDB9 | | IO | P1 |
PQFN08B | MOSFET_P_5P_SO8_PQFN08B_IC_0.8M | FDMC6686P | | IC | Q1 |
SOT23 | PNP_SOT23_IC_1.3MM_480-75192_MM | MMBT3906L | | IC | Q2 |
SOT23 | PNP_SOT23_IC_1.3MM_480-75192_MM | MMBT3906L | | IC | Q3 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40MM_ | 2.21M | 5% | DISCRETE | R1 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__7 | 100K | | DISCRETE | R2 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R4 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__2 | 1.0K | 5% | DISCRETE | R17 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__2 | 1.0K | 5% | DISCRETE | R18 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_4 | 15K | | DISCRETE | R19 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM__1 | 1 | | DISCRETE | R20 |
RES_4P_WSL3637 | RES_4PIN_RES_4P_WSL3637_DISCRET | 0.001 | | DISCRETE | R21 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_4 | 15K | | DISCRETE | R22 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_47 | 1.0K | | DISCRETE | R23 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R24 |
RES_4P_WSL3637 | RES_4PIN_RES_4P_WSL3637_DISCRET | 0.001 | | DISCRETE | R25 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 49.9 | 1% | DISCRETE | R26 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R27 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R28 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_30 | 2 | | DISCRETE | R29 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_30 | 2 | | DISCRETE | R30 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_30 | 2 | | DISCRETE | R31 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R32 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R33 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R34 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 49.9 | 1% | DISCRETE | R35 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 49.9 | 1% | DISCRETE | R36 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_34 | 2.67K | | DISCRETE | R37 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_30 | 2 | | DISCRETE | R38 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R39 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R40 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R41 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R42 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_14 | 69.8K | | DISCRETE | R43 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R45 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | 0 | | DISCRETE | R46 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R47 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R48 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 49.9 | 1% | DISCRETE | R49 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R50 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R52 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R53 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R54 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R55 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_ | 30.1K | | DISCRETE | R56 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R57 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_37 | 3.48K | | DISCRETE | R58 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_37 | 3.48K | | DISCRETE | R59 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_ | 30.1K | | DISCRETE | R60 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R61 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R62 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R63 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R65 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R66 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R67 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R68 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_40 | 4.32K | | DISCRETE | R69 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_41 | 9.09K | | DISCRETE | R70 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_44 | 11K | | DISCRETE | R72 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_42 | 7.32K | | DISCRETE | R73 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_3 | 11.3K | | DISCRETE | R74 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__2 | 1.0K | 5% | DISCRETE | R75 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__2 | 1.0K | 5% | DISCRETE | R76 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_34 | 2.67K | | DISCRETE | R77 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R78 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R80 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R81 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R82 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R83 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R85 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R86 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R87 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 49.9 | 1% | DISCRETE | R88 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R89 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | 0 | | DISCRETE | R90 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R91 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R92 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R94 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R95 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R96 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 2.2 | | DISCRETE | R97 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R98 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R99 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R100 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R101 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R102 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R103 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 2.2 | | DISCRETE | R104 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R105 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 49.9 | 1% | DISCRETE | R106 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R107 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R108 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 49.9 | 1% | DISCRETE | R109 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_2 | 24.9K | | DISCRETE | R110 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R111 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R112 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R113 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R114 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 20K | | DISCRETE | R115 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 49.9 | 1% | DISCRETE | R116 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R117 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R118 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R119 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R120 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R121 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R122 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R123 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R124 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 49.9K | | DISCRETE | R125 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R126 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R127 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_16 | 18.7K | | DISCRETE | R128 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | 26.1K | | DISCRETE | R129 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_10 | 21K | | DISCRETE | R130 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_17 | 330 | | DISCRETE | R131 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_11 | 20.5K | | DISCRETE | R132 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R133 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_12 | 4.02K | | DISCRETE | R134 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_11 | 20.5K | | DISCRETE | R135 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 2.2 | | DISCRETE | R136 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_11 | 20.5K | | DISCRETE | R137 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 2.2 | | DISCRETE | R138 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 2.2 | | DISCRETE | R139 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 2.2 | | DISCRETE | R140 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R144 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_18 | 10 | | DISCRETE | R145 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_18 | 10 | | DISCRETE | R146 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R147 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R148 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R150 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R151 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R153 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R154 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_19 | 0.33 OHM | | DISCRETE | R201 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_19 | 0.33 OHM | | DISCRETE | R202 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_19 | 0.33 OHM | | DISCRETE | R203 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_19 | 0.33 OHM | | DISCRETE | R204 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R205 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_13 | 5.1 | 1% | DISCRETE | R206 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_13 | 5.1 | 1% | DISCRETE | R207 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R208 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R210 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_13 | 5.1 | 1% | DISCRETE | R213 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_13 | 5.1 | 1% | DISCRETE | R214 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_14 | 69.8K | | DISCRETE | R219 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_15 | 1.21K | | DISCRETE | R220 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_16 | 30.9K | | DISCRETE | R221 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_16 | 30.9K | | DISCRETE | R222 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_15 | 1.21K | | DISCRETE | R223 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM_47 | 2 | | DISCRETE | R224 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R225 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_17 | 28K | | DISCRETE | R226 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_15 | 1.21K | | DISCRETE | R228 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R229 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_15 | 1.21K | | DISCRETE | R230 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R231 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R232 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R233 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R234 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_15 | 1.21K | | DISCRETE | R235 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_20 | 93.1K | | DISCRETE | R237 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R238 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_21 | 1.91K | | DISCRETE | R239 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R240 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R241 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R242 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_15 | 1.21K | | DISCRETE | R243 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_22 | 1.43K | | DISCRETE | R244 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55M_1 | 7.68K | | DISCRETE | R245 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R246 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R247 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_22 | 1.43K | | DISCRETE | R248 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_16 | 30.9K | | DISCRETE | R249 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_23 | 12.7K | | DISCRETE | R250 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R251 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_24 | 162 | | DISCRETE | R252 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_24 | 162 | | DISCRETE | R253 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R254 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R255 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R256 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R257 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R258 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R259 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R260 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R261 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R262 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R263 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R264 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R265 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R266 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R269 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R270 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM_47 | 2 | | DISCRETE | R271 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_1 | 200 | 1% | DISCRETE | R272 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_20 | 698 | 1% | DISCRETE | R273 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_25 | 5.36K | | DISCRETE | R274 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_26 | 15K | | DISCRETE | R275 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_27 | 13K | | DISCRETE | R276 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_27 | 13K | | DISCRETE | R277 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_18 | 45.3K | | DISCRETE | R278 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R279 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R280 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_28 | 21.5K | | DISCRETE | R281 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_29 | 30.1K | | DISCRETE | R282 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_26 | 15K | | DISCRETE | R283 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_27 | 13K | | DISCRETE | R284 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_27 | 13K | | DISCRETE | R285 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_26 | 15K | | DISCRETE | R286 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_27 | 13K | | DISCRETE | R287 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_27 | 13K | | DISCRETE | R288 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R289 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R290 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R291 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_14 | 69.8K | | DISCRETE | R296 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_16 | 30.9K | | DISCRETE | R298 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_15 | 1.21K | | DISCRETE | R299 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R300 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_19 | 20 | | DISCRETE | R301 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R302 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R303 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R304 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R305 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R306 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R307 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R308 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_31 | 34.8K | | DISCRETE | R310 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_32 | 19.1K | | DISCRETE | R313 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_33 | 17.4K | | DISCRETE | R314 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R315 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R318 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_21 | 1.91K | | DISCRETE | R319 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_21 | 619 | | DISCRETE | R338 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R360 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R361 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R362 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R363 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R372 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R373 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R374 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R375 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_23 | 33 | 5% | DISCRETE | R376 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R384 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R385 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R386 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R387 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R389 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R396 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R397 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R398 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_22 | 510 | | DISCRETE | R399 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_1 | 180 | | DISCRETE | R415 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_1 | 180 | | DISCRETE | R416 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_4 | 200K | | DISCRETE | R428 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R429 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R430 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_9 | 412K | | DISCRETE | R433 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__9 | 1M | | DISCRETE | R434 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_ | 60.4K | | DISCRETE | R435 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 10.0K | | DISCRETE | R436 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 4.7K | 5% | DISCRETE | R437 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R482 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_35 | 20 | 1% | DISCRETE | R520 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_35 | 20 | 1% | DISCRETE | R521 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_35 | 20 | 1% | DISCRETE | R522 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_36 | 27 | 1% | DISCRETE | R526 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | 0 | | DISCRETE | R547 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R554 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R555 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R556 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R557 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R558 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R559 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R561 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R562 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R563 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R564 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R565 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R566 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R568 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R569 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R570 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R572 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R573 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R574 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R575 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R576 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R577 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R578 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R581 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R582 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R583 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R584 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R585 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R586 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R587 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_32 | 19.1K | | DISCRETE | R588 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R589 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R590 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R591 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R592 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R593 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R594 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R595 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R596 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R597 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R598 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R599 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R600 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R601 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R602 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R603 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R604 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R605 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R608 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_25 | 2.0K | 1% | DISCRETE | R609 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R610 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_38 | 3.09K | | DISCRETE | R611 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | 26.1K | | DISCRETE | R612 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R613 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R614 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R615 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R616 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R617 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R618 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R619 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R620 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R621 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R622 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R623 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R624 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R625 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R626 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R627 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R629 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R630 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R631 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R632 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R633 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R634 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_34 | 2.67K | | DISCRETE | R635 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_34 | 2.67K | | DISCRETE | R636 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R637 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R638 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R639 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R640 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R641 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R642 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R643 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R644 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R645 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_33 | 17.4K | | DISCRETE | R646 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R647 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_1 | 200 | 1% | DISCRETE | R651 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_1 | 200 | 1% | DISCRETE | R653 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R654 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R656 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_33 | 17.4K | | DISCRETE | R657 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_23 | 33 | 5% | DISCRETE | R661 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R664 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R668 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R669 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R670 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R671 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R672 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R674 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_13 | 5.1 | 1% | DISCRETE | R675 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R676 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R677 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R678 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R695 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_1 | 200 | 1% | DISCRETE | R696 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R697 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R703 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_29 | 30.1K | | DISCRETE | R705 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_20 | 698 | 1% | DISCRETE | R706 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R707 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_17 | 330 | | DISCRETE | R708 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R709 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_43 | 249 | | DISCRETE | R710 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_26 | 10 | 5% | DISCRETE | R711 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R712 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_26 | 10 | 5% | DISCRETE | R713 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R720 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R721 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R722 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R724 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R725 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R726 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R727 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R728 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R729 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R730 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R731 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R732 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R733 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_45 | 97.6K | | DISCRETE | R734 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R735 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R736 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R737 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_27 | 1.0K | 5% | DISCRETE | R738 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_27 | 1.0K | 5% | DISCRETE | R739 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R740 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_27 | 1.0K | 5% | DISCRETE | R741 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R742 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R743 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R752 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R753 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R754 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R755 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_17 | 330 | | DISCRETE | R757 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R758 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R759 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R760 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R761 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R762 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_45 | 97.6K | | DISCRETE | R764 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R766 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R767 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R768 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R769 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R770 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R771 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R773 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R774 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R775 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R776 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R777 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R778 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R779 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R780 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R781 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R782 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R783 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R784 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R785 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R788 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R792 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R793 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 1.0K | 1% | DISCRETE | R796 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_25 | 2.0K | 1% | DISCRETE | R800 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R801 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_38 | 3.09K | | DISCRETE | R803 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_38 | 3.09K | | DISCRETE | R804 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R805 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R807 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R808 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R809 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_17 | 330 | | DISCRETE | R810 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R811 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R812 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 1.0K | 1% | DISCRETE | R813 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_25 | 2.0K | 1% | DISCRETE | R814 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 1.0K | 1% | DISCRETE | R815 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 1.0K | 1% | DISCRETE | R816 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R817 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R818 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R819 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.45MM_4 | 750 | 1% | DISCRETE | R820 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R821 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R822 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R823 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R824 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R825 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R826 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R827 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R828 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R829 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R830 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R832 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R833 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 1.0K | 1% | DISCRETE | R834 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R835 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__2 | 1.0K | 5% | DISCRETE | R852 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R853 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R854 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R855 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_21 | 619 | | DISCRETE | R856 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R857 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_25 | 2.0K | 1% | DISCRETE | R858 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 1.0K | 1% | DISCRETE | R859 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R860 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R861 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__5 | 10 | | DISCRETE | R862 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_4 | 100 | | DISCRETE | R863 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_5 | 22 | 1% | DISCRETE | R864 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 1.0K | 1% | DISCRETE | R865 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R866 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R867 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R868 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 1.0K | 1% | DISCRETE | R871 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R889 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R890 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R891 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R892 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R893 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R894 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R895 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R896 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R897 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_46 | 51.1K | | DISCRETE | R901 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R907 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R908 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R909 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R924 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R931 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R932 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R933 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R934 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R936 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R937 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R940 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R941 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40_38 | 3.09K | | DISCRETE | R942 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R943 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R946 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R947 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R949 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R962 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R966 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R981 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R982 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R990 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R991 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R992 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R994 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__4 | 10.0K | | DISCRETE | R995 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R997 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R998 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R999 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1000 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1001 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1002 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R1003 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R1004 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM_47 | 2 | | DISCRETE | R1005 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1007 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1008 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1009 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1010 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1011 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1012 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1013 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1014 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1015 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1016 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1017 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1018 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1019 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1020 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1021 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1022 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1023 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1024 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1025 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1026 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1027 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1028 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1029 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1030 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1031 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1032 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1033 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1034 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1035 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1036 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1037 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_1 | 75 | | DISCRETE | R1038 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM_47 | 2 | | DISCRETE | R1039 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__7 | 100K | | DISCRETE | R1088 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_3 | 66.5K | | DISCRETE | R1089 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_4 | 200K | | DISCRETE | R1090 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__7 | 100K | | DISCRETE | R1091 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R1092 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R1093 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R1094 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__9 | 1M | | DISCRETE | R1096 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_ | 60.4K | | DISCRETE | R1097 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 10.0K | | DISCRETE | R1098 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 4.7K | 5% | DISCRETE | R1099 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_10 | 240K | | DISCRETE | R1100 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_47 | 1.0K | | DISCRETE | R1108 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_47 | 1.0K | | DISCRETE | R1109 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_47 | 1.0K | | DISCRETE | R1110 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM_47 | 1.0K | | DISCRETE | R1111 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R1112 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R1113 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 10.0K | | DISCRETE | R1114 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 0 | | DISCRETE | R1115 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 10.0K | | DISCRETE | R1116 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R1117 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 4.7K | 1% | DISCRETE | R1118 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_5 | 10K | | DISCRETE | R1119 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__7 | 100K | | DISCRETE | R1122 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_12 | 0 | | DISCRETE | R1123 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R1126 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R1128 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1137 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R1138 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 10 | | DISCRETE | R1139 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R1140 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R1141 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R1142 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R1143 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM__1 | 1 | | DISCRETE | R1144 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_7 | 169K | | DISCRETE | R1146 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_8 | 73.2K | | DISCRETE | R1147 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_ | 60.4K | | DISCRETE | R1148 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1149 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_15 | 33 | | DISCRETE | R1151 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_15 | 33 | | DISCRETE | R1152 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_12 | 0 | | DISCRETE | R1155 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_12 | 0 | | DISCRETE | R1157 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_12 | 0 | | DISCRETE | R1159 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_12 | 0 | | DISCRETE | R1161 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__9 | 1M | | DISCRETE | R1162 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 4.7K | 5% | DISCRETE | R1163 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 10.0K | | DISCRETE | R1164 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_9 | 412K | | DISCRETE | R1165 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_ | 60.4K | | DISCRETE | R1166 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40M_6 | 4.99K | | DISCRETE | R1167 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0 | 5% | DISCRETE | R1168 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R1169 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R1170 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.4MM__1 | 390 | | DISCRETE | R1171 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1172 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1173 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1174 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | | DISCRETE | R1175 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 4.7K | 5% | DISCRETE | R1176 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 4.7K | | DISCRETE | R1177 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_IC_2. | 218-8LPST | | IC | SW1 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_IC_2. | 218-8LPST | | IC | SW2 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_IC_2. | 218-8LPST | | IC | SW3 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_IC_2. | 218-8LPST | | IC | SW4 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_IC_2. | 218-8LPST | | IC | SW5 |
SW_ELTSA-66_TH | SW_PB_SPST_4P_SW_ELTSA-66_TH_IC | ELTSA-66N-H | | IC | SW18 |
SW6_TACT_LED_TH | SPL6BL_SW6_TACT_SW6_TACT_LED_TH | SPL6BLH | | IC | SW19 |
H5008 | H5008_ALT_H5008_IC_5.72MM_312-7 | H5008 | | IC | T4 |
H5008 | H5008_ALT_H5008_IC_5.72MM_312-7 | H5008 | | IC | T5 |
H5008 | H5008_ALT_H5008_IC_5.72MM_312-7 | H5008 | | IC | T6 |
H5008 | H5008_ALT_H5008_IC_5.72MM_312-7 | H5008 | | IC | T7 |
H5008 | H5008_ALT_H5008_IC_5.72MM_312-7 | H5008 | | IC | T8 |
H5008 | H5008_ALT_H5008_IC_5.72MM_312-7 | H5008 | | IC | T9 |
H5008 | H5008_ALT_H5008_IC_5.72MM_312-7 | H5008 | | IC | T10 |
H5008 | H5008_ALT_H5008_IC_5.72MM_312-7 | H5008 | | IC | T11 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP9 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP10 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP11 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP16 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP30 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP31 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP32 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP82 |
TESTPOINT_100_050MIL | TESTLOOP_TESTPOINT_100_050MIL_I | WHITE | | IO | TP175 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP176 |
TESTPOINT_100_050MIL | TESTLOOP_TESTPOINT_100_050MIL_I | WHITE | | IO | TP177 |
TESTPOINT_100_050MIL | TESTLOOP_TESTPOINT_100_050MIL_I | WHITE | | IO | TP178 |
TP_TH_063 | TEST_POINT_TP_TH_063_IC_5.6MM_2 | 5006 | | IC | TP185 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP190 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP191 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP192 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP193 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP194 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP195 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP196 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP197 |
TESTPOINT_35MIL | TESTPAD_TESTPOINT_35MIL_IC_0.1 | 35 MIL | | IC | TP198 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP219 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP220 |
TP_TH_063 | TEST_POINT_TP_TH_063_IC_5.6MM_2 | 5006 | | IC | TP221 |
TP_TH_063 | TEST_POINT_TP_TH_063_IC_5.6MM_2 | 5006 | | IC | TP222 |
TP_TH_063 | TEST_POINT_TP_TH_063_IC_5.6MM_2 | 5006 | | IC | TP223 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP234 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP235 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP239 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP240 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP241 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP242 |
TP_PTH | T POINTTH_TP_PTH_IC_0.1 MM_210 | TP_PTH | | IC | TP243 |
TP_TH_063 | TEST_POINT_TP_TH_063_IC_5.6MM_2 | 5006 | | IC | TP254 |
BGA780_0P8_23X23MM | LS1088A_SS_LS1043A_BGA780_0P8_2 | PLS1088ASE7Q1A | | IC | U1 |
BGA42_0P8_5X6 | LTC7150_BGA42_BGA42_0P8_5X6_IC_ | LTC7150S | | IC | U3 |
CON12_SHRD_2MM_TH | CON12_98414_PMBUS_CON12_SHRD_2M | CON_2X6 TH | | IC | U4 |
PQFN31_0P5_5X5 | FDMF5820DC_PQFN31_0P5_5X5_IC_0. | FDMF5820DC | | IC | U5 |
QFN40_0P5_6P1X6P1 | LTC3882_40P_EP_QFN40_0P5_6P1X6P | LTC3882 | | IC | U6 |
PQFN31_0P5_5X5 | FDMF5820DC_PQFN31_0P5_5X5_IC_0. | FDMF5820DC | | IC | U7 |
SOT-363_0P65_SMT | 74LVC2G17_SOT-363_0P65_SMT_IC_1 | 74LVC2G17 | | IC | U8 |
SOT-363_0P65_SMT | 74LVC2G17_SOT-363_0P65_SMT_IC_1 | 74LVC2G17 | | IC | U9 |
MSOP10_0P5_3P1X3P1_EP | LTC3026_MSOP_10P_MSOP10_0P5_3P1 | LTC3026EMSE | | IC | U12 |
TDFN8_1P98_2P10X2P10 | MAX8902B_TDFN8_1P98_2P10X2P10_I | MAX8902B | | IC | U13 |
BGA68_1P27_9X15MM | LTM4649EY-BGA68_BGA68_1P27_9X15 | LTM4649 | | IC | U17 |
CON_DDR4_288_0P85_TH | DIMM_MODULE_CON_DDR4_288_0P85_T | 78726-1004 | | IO | U30 |
BGA6_0P5_0P92X1P42_NSP | NX5P2924BUK_BGA6_0P5_0P92X1P42_ | NX5P2924BUK | | IC | U32 |
WLCSP6_0P5_0P98X1P48 | FPF1321_6P_WLCSP6_0P5_0P98X1P48 | FPF1321UCX | | IC | U36 |
QFN64_0P5_9X9C | SI5341B_64P_EP_A_QFN64_0P5_9X9C | Si5341B-B04862-GM | | IC | U44 |
QFN28_3X6_0P5 | LT8612_28P_QFN_EP_QFN28_3X6_0P5 | LT8612 | | IC | U45 |
AQFN138_0P65_12X12_EP | VSC8514_QFN_138P_A_AQFN138_0P65 | VSC8514_QFN | | IC | U51 |
TSOT23_8_0P65_2X1 | LTC2955-2_TSOT23_8P_TSOT23_8_0P | LTC2955CTS8-2 | | IC | U82 |
TSSOP24_0P65_7P9X4P5 | PCA9547_24P_TSSOP24_0P65_7P9X4P | PCA9547PW | | IC | U87 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_UQFN10_0P4_1 | NX3DV42GU | | IC | U94 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_UQFN10_0P4_1 | NX3DV42GU | | IC | U95 |
TSSOP8 | AT24CXX_TSSOP8_IC_1.2MM_334-756 | AT24C512C-XHD-B | | IC | U97 |
TSSOP8 | ATMEL_SERIAL_EEPROM_64K-1_TSSOP | AT24C02C-XHM-B | | IC | U98 |
SO20_1P27_7P6X12P95 | PCF2129AT_SO_20P_SO20_1P27_7P6X | PCF2129AT | | IC | U99 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_UQFN10_0P4_1 | NX3DV42GU | | IC | U100 |
BGA324_1MM_19X19MM_C019S | AQR105_BGA324_BGA324_1MM_19X19M | AQR105-B1 | | IC | U101 |
SO8_1P27_4X5 | MX25V4006E_8P_SO8_1P27_4X5_IC_1 | MX25V4006E | | IC | U102 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_UQFN10_0P4_1 | NX3DV42GU | | IC | U103 |
MSOP_10_0P5_3X3 | INA220AIDGST_MSOP_10_0P5_3X3_IC | INA220AIDGST | | IC | U104 |
SO8 | ADT7461_SO8_IC_1.75MM_315-76826 | ADT7461 | | IC | U106 |
XSON8_0P5_3P1X2P1 | NTSX2102GD_XSON8_0P5_3P1X2P1_IC | NTSX2102GD | | IC | U107 |
TSSOP8 | ATMEL_SERIAL_EEPROM_64K-1_TSSOP | AT24C02C-XHM-B | | IC | U108 |
TSSOP24_0P65_7P9X4P5 | PCA9547_24P_TSSOP24_0P65_7P9X4P | PCA9547PW | | IC | U109 |
XSON8_0P5_3P1X2P1 | NTSX2102GD_XSON8_0P5_3P1X2P1_IC | NTSX2102GD | | IC | U110 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_A_UQFN10_0P4 | NX3DV42GU | | IC | U111 |
TSSOP8_A | NTB0102_8P_TSSOP8_A_IC_1.1MM_31 | NTS0102 | | IC | U112 |
SSOP16_4P8X3P8MM | LTC2804_SSOP16_SSOP16_4P8X3P8MM | LTC2804-1 | | IC | U113 |
TSSOP8_A | NTB0102_8P_TSSOP8_A_IC_1.1MM_31 | NTS0102 | | IC | U115 |
SSOP16_4P8X3P8MM | LTC2804_SSOP16_SSOP16_4P8X3P8MM | LTC2804-1 | | IC | U120 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_A_UQFN10_0P4 | NX3DV42GU | | IC | U121 |
XSON10_0P5_1P1X2P6MM | DIODE_ESD_4CH_PUSB3AB4_XSON10_0 | PUSB3AB4 | | IC | U131 |
WLCSP12_0P4_1P38X1P68MM_SMDP | NX5P3090UK_WLCSP12_WLCSP12_0P4_ | NX5P3090UK | | IC | U132 |
SOT143B | PRTR5V0U2AX_SOT143B_IC_1.1MM_48 | PRTR5V0U2AX | | IC | U133 |
XSON10_0P5_1P1X2P6MM | DIODE_ESD_4CH_PUSB3AB4_XSON10_0 | PUSB3AB4 | | IC | U134 |
WLCSP12_0P4_1P38X1P68MM_SMDP | NX5P3090UK_WLCSP12_WLCSP12_0P4_ | NX5P3090UK | | IC | U135 |
SOT143B | PRTR5V0U2AX_SOT143B_IC_1.1MM_48 | PRTR5V0U2AX | | IC | U136 |
SOT143B | PRTR5V0U2AX_SOT143B_IC_1.1MM_48 | PRTR5V0U2AX | | IC | U137 |
QFN24_0P5_4P15SQ_EP2P6 | DS125DF111_QFN24_0P5_4P15SQ_EP2 | DS125DF111 | | IC | U144 |
XSON7_0P5_2P2X1P2 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | | IC | U145 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_A_UQFN10_0P4 | NX3DV42GU | | IC | U146 |
XSON7_0P5_2P2X1P2 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | | IC | U147 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_A_UQFN10_0P4 | NX3DV42GU | | IC | U148 |
UQFN10_0P4_1P45X1P85 | NX3DV42GU_XQFN_10P_A_UQFN10_0P4 | NX3DV42GU | | IC | U150 |
SOT-363_0P65_SMT | 74AUP2G07GW_SOT-363_0P65_SMT_IC | 74AUP2G07GW | | IC | U164 |
SOT143-25X60 | MAX811_SOT143-25X60_IC_1.22MM_ | MAX811 | | IC | U168 |
SC70-5 | 74AUP1T34GW_SC70-5_IC_1.1MM_312 | 74AUP1T34GW | | IC | U169 |
SC70-5 | 74AUP1T34GW_SC70-5_IC_1.1MM_312 | 74AUP1T34GW | | IC | U172 |
SOIC16_1P27_7P5X10P3 | S25FS512SAGMFI011_SOIC16_1P27_7 | S25FS512SDSMFI011 | | IC | U182 |
TDFN10_0P5_3P1X3P1 | NX3DV221TK_10P_B_TDFN10_0P5_3P1 | NX3DV221TK | | IC | U183 |
SOIC16_1P27_7P5X10P3 | S25FS512SAGMFI011_SOIC16_1P27_7 | S25FS512SDSMFI011 | | IC | U185 |
VFBGA63_0P8_9X11 | MT29F4G08ABBDAH4_VFBGA63_0P8_9X | MT29F4G08ABBDAH4 | | IC | U187 |
TDFN10_0P5_3P1X3P1 | NX3DV221TK_10P_B_TDFN10_0P5_3P1 | NX3DV221TK | | IC | U188 |
TDFN10_0P5_3P1X3P1 | NX3DV221TK_10P_B_TDFN10_0P5_3P1 | NX3DV221TK | | IC | U189 |
SC70-5 | 74AUP1T34GW_SC70-5_IC_1.1MM_312 | 74AUP1T34GW | | IC | U196 |
TSSOP8_A | NTB0102_8P_TSSOP8_A_IC_1.1MM_31 | NTS0102 | | IC | U201 |
AQFN138_0P65_12X12_EP | VSC8514_QFN_138P_A_AQFN138_0P65 | VSC8514_QFN | | IC | U205 |
BGA256_1MM_17X17 | EPM2210F256C5N_256BGA_BGA256_1M | EPM2210F256C5N | | IC | U207 |
SOT23-5_A | 74AUP1G04GV_SOT23-5_A_IC_1.1MM_ | 74AUP1G04GV | | IC | U209 |
SOT23-5_A | 74AUP1G04GV_SOT23-5_A_IC_1.1MM_ | 74AUP1G04GV | | IC | U212 |
QFN24_4X4MM_SLUG | MC34712_QFN24_4X4MM_SLUG_IC_1MM | MC34712EP | | IC | U213 |
QFN26_0P5_5X5_EP_3P75 | MC34717_C_QFN26_0P5_5X5_EP_3P75 | MC34717EP | | IC | U214 |
QFN26_0P5_5X5_EP_3P75 | MC34717_C_QFN26_0P5_5X5_EP_3P75 | MC34717EP | | IC | U215 |
QFN26_0P5_5X5_EP_3P75 | MC34717_C_QFN26_0P5_5X5_EP_3P75 | MC34717EP | | IC | U216 |
QFN26_0P5_5X5_EP_3P75 | MC34717_C_QFN26_0P5_5X5_EP_3P75 | MC34717EP | | IC | U217 |
QFN40_0P4_5P1X5P1 | 9FGV0641AK_40P_EP_A_QFN40_0P4_5 | 9FGV0641AKLF | | IC | U220 |
QFN26_0P5_5X5_EP_3P75 | MC34717_C_QFN26_0P5_5X5_EP_3P75 | MC34717EP | | IC | U221 |
QFN10_0P5_3X3_A | NX3L4684TK_QFN10_0P5_3X3_A_IC_1 | NX3L4684TK | | IC | U224 |
TBGA100_1MM_14X18 | MTFC32GJDDQ_LBGA_100P_TBGA100_1 | MTFC4GACAANA-4M IT | | IC | U225 |
SOT23-5 | SN74CBTLV1G125_SOT23-5_IC_1.45M | SN74CBTLV1G125DBVR | | IC | U226 |
QFN28_3X6_0P5 | LT8612_28P_QFN_EP_QFN28_3X6_0P5 | LT8612 | | IC | U227 |
SOT-363_0P65_SMT | 74LVC2G17_SOT-363_0P65_SMT_IC_1 | 74LVC2G17 | | IC | U228 |
XSON8_0P5_3P1X2P1 | NTSX2102GD_XSON8_0P5_3P1X2P1_IC | NTSX2102GD | | IC | U229 |
TSSOP8_A | NTB0102_8P_TSSOP8_A_IC_1.1MM_31 | NTS0102 | | IC | U230 |
SOT23-5 | SN74CBTLV1G125_SOT23-5_IC_1.45M | SN74CBTLV1G125DBVR | | IC | U231 |
QFN28_3X6_0P5 | LT8612_28P_QFN_EP_QFN28_3X6_0P5 | LT8612 | | IC | U232 |
SOT-363_0P65_SMT | 74LVC2G17_SOT-363_0P65_SMT_IC_1 | 74LVC2G17 | | IC | U233 |
XTAL_4_3P3X2P6MM | XTAL_13Y_XTAL_4_3P3X2P6MM_IC_0. | 7M48072002 | | IC | X1 |
XTAL_3P4X1P7_SM | OSC4_VIO_XTAL_3P4X1P7_SM_IC_1.0 | 32.768KHz | | IC | Y5 |
XTAL_4P_6P2X3P9 | XTAL_13Y_XTAL_4P_6P2X3P9_IC_1_1 | 50MHz | | IC | Y7 |
XTAL_4P_6P2X3P9 | XTAL_13Y_XTAL_4P_6P2X3P9_IC_1.2 | 25 MHz | | IC | Y10 |
OSC4_2P6X2P1_SM | O4-0_OSC4_2P6X2P1_SM_IC_0.8MM_2 | 25MHz | | IC | Y11 |
XTAL_3P4X1P7_SM | OSC4_VIO_XTAL_3P4X1P7_SM_IC_1.0 | 32.768KHz | | IC | Y12 |
