Name | Part Type | PCB Decal | Value | ANT1 | ACA-5036 | ANT_WIFI_5036 | ACA-5036 | CN1 | CONNECTOR_A64_P166B | CONNECTOR_A64_P166B | CONNECTOR_A64_P166B | CN2 | POWERJACK5_0 | JACK_POWER_DC-030 | PowerJACK5 | CN3 | CON3 | HEADER_PIN_SIP3_2MM54 | CN_UART | CN4 | HEADER_2 | WAFER_2MM_SMD_90D_2P | CN_BAT | CN5 | MICPHONE_0 | MIC_CZ034AP462 | CZ034AP462 | CN6 | CON4 | CON_SIP4BOX_2MM | CN_UART | CN7 | CON4 | CON_SIP4BOX_2MM | CN_UART | CN8 | USB_WIFI_0 | JACK_EARPHONE_PJ-327F | EAR_JACK | CN9 | CON2 | WAFER_1MM_SMD_90D_2P | CN_MIC2 | CN10 | ~WB_3 | WAFER_1MM_SMD_90D_2P | DNP | CN11 | SD_MMC_CARD2_0 | SOCKET_TF_SK10056619 | Micro_SD_CARD | CN12 | CON3 | HEADER_PIN_SIP3_2MM54 | CN_UART | CN13 | MODULE_CAM_PA0505 | CON_FPC24_OV9653 | MODULE_CAM_GS5604 | CN15 | CON26 | CON_FPC24_OV9653 | CN_MIPI | CN16 | CON40 | CON_FPC40_0MM5_UT | CN_GPIO | CN17 | HDMI19_PLUG | CON_HDMI_MOLEX_19 | HDMI_19P_TYPE_A | CN18 | PLAUSB-AF5P-WSMT_0 | CON_MICROUSB_JS-MR1-4036 | USB_DEVICE | CN19 | USBPORT2_0 | CON_USB_A1_FEMALE | USBPORT2 | CN40 | CON40_1 | CON_FPC40_0MM5_UT | CN_LCD | D1 | LED | LED0603 | LED_RED | D2 | LED | LED0603 | LED_RED | D3 | DIODE_SCHOTTKY | 1N5819HW_SOD123 | DNP | D4 | LED | LED0603 | LED_RED | D5 | SCHOTTKY | 1N5819HW_SOD123 | 1N5819HW | D6 | DIODE_SCHOTTKY | 1N5819HW_SOD123 | 1N5819HW | D7 | DIODE_SCHOTTKY | 1N5819HW_SOD123 | 1N5819HW | F1 | FUSEHOLDER_0 | FUSE1812 | SMD1812P200TF | FB1 | BEAD | FB0603 | DNP | FB2 | BEAD | FB0603 | WLB1608-181T15 | FB3 | BEAD | FB0603 | WLB1608-181T15 | FB4 | INDUCTOR_5 | FB0603 | WLB1608-181T15 | FB5 | BEAD | FB0603 | DNP | FB6 | BEAD | FB0603 | WLB1608-181T15 | FB7 | BEAD | FB0603 | DNP | H1 | CON9 | FULCRUM_2MM5_6MM | DNP | H2 | CON9 | FULCRUM_2MM5_6MM | DNP | H3 | CON9 | FULCRUM_2MM5_6MM | DNP | H4 | CON9 | FULCRUM_2MM5_6MM | DNP | L1 | INDUCTOR_POWER | PL_SWPA4020 | SWPA4020S100MT | L2 | INDUCTOR_POWER | PL_SWPA4020 | SWPA4020S100MT | L3 | INDUCTOR | PL_SWPA4020 | SWPA4020S100MT | MK1 | TESTPOINT_3 | MARK | MARK | MK2 | TESTPOINT_3 | MARK | MARK | MK3 | TESTPOINT_3 | MARK | MARK | MK4 | TESTPOINT_3 | MARK | MARK | Q1 | S9013SMD | SOT-23 | S9013 | Q2 | 2N7002 | SOT-23B | AO3422 | R91 | R_GENERIC | R0603 | DNP | R92 | R_GENERIC | R0603 | 0R | R93 | R_GENERIC | R0402 | 0R | R94 | R_GENERIC | R0402 | DNP | R95 | R_GENERIC | R0402 | 4K7 | RV34 | RESISTOR_V | R0402 | KRMV0402E5R5N0R3T | RV35 | RESISTOR_V | R0402 | KRMV0402E5R5N0R3T | SW1 | SWPB2X1B | SWITCH_1188E | KEY_VOL- | SW2 | SWPB2X1B | SWITCH_1188E | KEY_VOL+ | SW3 | SWPB2X1B | SWITCH_1188E | KEY_HOME | SW4 | SWPB2X1B | SWITCH_1188E | KEY_RST | SW5 | SWPB2X1B | SWITCH_1188E | KEY_PWR | SW6 | SWPB2X1B | SWITCH_1188E | KEY_FEL | TVS1 | DIODE | SMA | 1SMA6.0AT3G | U1 | MMA8452Q_0 | MMA8452Q | DNP | U2 | L3GD20 | L3GD20_LGA16_4X4MM | DNP | U3 | APDS-9301_0 | LTR-501ALS_8P_2MM65X2MM | DNP | U4 | ALSLED | LTE-C216R-14 | DNP | U5 | BAKELIGHT_IC_2 | SOT-23-6 | LP3382B6F | U6 | AT24C16 | SO8W | DNP | U7 | AT88SC0104C | SO8 | DNP | U8 | LP3985IM5-3_2.3 | SOT-23-5 | DNP | U9 | RRCLAMP0524P | RCLAMP0524PA_SLP2510P8 | rRClamp0524P | U10 | RRCLAMP0524P | RCLAMP0524PA_SLP2510P8 | rRClamp0524P | U11 | M93C46_0 | SOT-23-5 | AP2191WG-7 | U12 | M93C46_0 | SOT-23-5 | DNP | U14 | AP6493_4 | AP6210_SOP44_AP6S21 | AP6212 | X1 | CRYSTAL_0 | CRYSTAL_S3225B | 26MHz |
原理图和PCB图.7z
(668 KB, 下载次数: 32)
