REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | LED_0805_LED | LED | 805 |
D2 | LED_0805_LED | LED | 805 |
D3 | DIODE PIN_0805_DIODEPIN | DIODE PIN | 805 |
D4 | DIODE PIN_0805_DIODEPIN | DIODE PIN | 805 |
D5 | LED_0805_LED | LED | 805 |
D6 | LED_0805_LED | LED | 805 |
D7 | LED_0805_LED | LED | 805 |
D8 | LED_0805_LED | LED | 805 |
D9 | DIODEZENER_MBRST340T3_DIODE ZE | DIODE ZENER | MBRST340T3 |
D10 | DIODEZENER_MBRST340T3_DIODE ZE | DIODE ZENER | MBRST340T3 |
J1 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J2 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J3 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J4 | CON5_SMAKWE_RCA | RCA | SMAKWE |
J5 | CON5_SMAKWE_RCA | RCA | SMAKWE |
J6 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J7 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J8 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J9 | CON5_SMAKWE_RCA | RCA | SMAKWE |
J10 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J11 | CON5_SMAKWE_RCA | RCA | SMAKWE |
J12 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J13 | DIM_LJQ200_DIM | DIM | LJQ200 |
J14 | USBC_USBF_USBC | USBC | USBF |
J18 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J19 | HEADER 5X2_JTAG_JTAG1 | JTAG1 | JTAG |
J20 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J21 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J22 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J23 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J24 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J25 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J26 | CON3_POWERJECT_POWER_IN | POWER_IN | POWERJECT |
J27 | SEL_DOUBLE0603_SEL | SEL | DOUBLE0603 |
J28 | SDC009_SDC009_SDC009 | SDC009 | SDC009 |
J30 | CONN FLEX42_FPC-40A_CONN FLEX | CONN FLEX 42 | FPC-40A |
L1 | INDUCTOR_1210_22UH | 22uH | 1210 |
L2 | INDUCTOR_1210_22UH | 22uH | 1210 |
L3 | INDUCTOR_1210_22UH | 22uH | 1210 |
L4 | INDUCTOR_1210_22UH | 22uH | 1210 |
L5 | INDUCTOR_1210_22UH | 22uH | 1210 |
L6 | INDUCTOR_0603_0 | 0 | 603 |
L7 | INDUCTOR_L2-A_10UH 6A | 10uH 6A | L2-A |
L8 | INDUCTOR_L2-A_10UH 6A | 10uH 6A | L2-A |
L9 | INDUCTOR_0603_INDUCTOR | INDUCTOR | 603 |
L10 | INDUCTOR_1210_22UH | 22uH | 1210 |
L11 | INDUCTOR_1210_22UH | 22uH | 1210 |
SW1 | SW DIP-6_SW6_SW6 | SW6 | SW6 |
SW2 | SWPUSHBUTTON-DPST_SWT_SW PUSHB | SW PUSHBUTTON-DPST | SWT |
U1 | AD9244_AD9244_AD9244 | AD9244 | AD9244 |
U2 | MC10EL16_MC10EL16_MC10EL16 | MC10EL16 | MC10EL16 |
U3 | AD8138_AD8138_AD8138 | AD8138 | AD8138 |
U4 | 74VHC04_74VHC04_74VHC04 | 74VHC04 | 74VHC04 |
U5 | MC10EL16_MC10EL16_MC10EL16 | MC10EL16 | MC10EL16 |
U6 | AD9244_AD9244_AD9244 | AD9244 | AD9244 |
U7 | AD8138_AD8138_AD8138 | AD8138 | AD8138 |
U8 | 74VHC04_74VHC04_74VHC04 | 74VHC04 | 74VHC04 |
U9 | HR911105A_HR911105A_HR911105A | HR911105A | HR911105A |
U10 | CP2102_CP2102_CP2102 | CP2102 | CP2102 |
U11 | ALTERA EP3C25Q240 | EP3C25Q240 | EP3C25Q240 |
U12 | ACF451832_ACF451832_ACF451832 | ACF451832 | ACF451832 |
U13 | ACF451832_ACF451832_ACF451832 | ACF451832 | ACF451832 |
U14 | ACF451832_ACF451832_ACF451832 | ACF451832 | ACF451832 |
U15 | EPCS64SI16N_EPCS64SI16N_EPCS64S | EPCS64SI16N | EPCS64SI16N |
U16 | CY2305_CY2305_CY2305 | CY2305 | CY2305 |
U17 | ACF451832_ACF451832_ACF451832 | ACF451832 | ACF451832 |
U18 | OSC2_CRYSTAL_40M | 40M | CRYSTAL |
U20 | LM1117-2.5V_LM1117_LM1117-2.5V | LM1117-2.5v | LM1117 |
U21 | TPS54350_TPS54350_TPS54350 | TPS54350 | TPS54350 |
U22 | TPS54350_TPS54350_TPS54350 | TPS54350 | TPS54350 |
U23 | 74VHC04_74VHC04_74VHC04 | 74VHC04 | 74VHC04 |
U24 | TPS3705_TPS3705_TPS3705_3.3V | TPS3705_3.3V | TPS3705 |
U25 | LTC4413_LTC4413_LTC4413 | LTC4413 | LTC4413 |
U26 | USB_USB2_USB | USB | USB2 |
U27 | ESD_SRV05-4_ESD_SRV05-4_ESD_SRV | ESD_SRV05-4 | ESD_SRV05-4 |
U28 | TSC2046EIPW_TSC2046EIPW_TSC2046 | TSC2046EIPW | TSC2046EIPW |
