TA的每日心情 | 开心 2024-6-20 15:58 |
签到天数: 1 天 [LV.1]初来乍到
长期免费代管18-28岁小
- 8256
Comment | Pattern | Quantity | Components | 600R/100MHz | 0805L | 3 | L1, L2, L3 | 74HCT245 | SOJ-20 | 1 | U44 | 74LVC14 | SO-14 | 2 | U6, U11 | 8MHz | Y | 1 | Y2 | 9013 | 9013SOT-23 | 1 | Q1 | AIC1117A-1.2 | SOT-223 | 1 | U12 | AIC1117A-2.5 | SOT-223 | 1 | U43 | AIC1117A-3.3 | SOT-223 | 2 | U5, U14 | ASP | KEY-2 | 1 | S1 | AT24C64N | SO-8 | 1 | U1 | C | 3.96PIN2 | 1 | J15 | CY7C68013A-100AXC | TQFP-14X20-100P | 1 | U3 | DB9 | DB9 | 1 | J41 | DS28e01 | 2.80E+02 | 1 | U23 | ECK-TBC472MF | C7163 | 1 | C145 | EP4CE15F23C8 | FBGA484 | 1 | U7 | EX_ctr | JST2X2.0MM/28P -F | 1 | JP2 | FP_OUT2 | JST2.0MM/2P | 6 | J31, J32, J38, J39, J49, J50 | FPGA_Jtag | HDR2X5 | 1 | J4 | FR30-800B | FUSE5.08MM | 1 | F3 | FR60-800B | FUSE5.08MM | 1 | F1 | I2C ADDR | SIP2 | 1 | J1 | IN4148 | 1206D | 1 | D2 | INK1 | JST2.0MM/2P | 1 | J8 | INK2 | JST2.0MM/2P | 1 | J17 | INK3 | JST2.0MM/2P | 1 | J208 | INK4 | JST2.0MM/2P | 1 | J209 | IRF7342 | SO-8 | 8 | U30, U36, U39, U40, U41, U42, U47, U48 | IRFR5505 | D-PAK | 5 | Q12, Q13, Q14, Q15, Q16 | ISP | SIP3 | 1 | J27 | K | 3.96PIN2 | 1 | J5 | KeyPad | FKV24SN | 1 | J16 | LED | 0805D | 1 | D20 | LM2576-5V | TO-263(S) | 1 | U4 | LM358 | SO-8 | 2 | U37, U38 | M_HV | 0805D | 1 | D21 | M | 3.96PIN2 | 1 | J7 | M25P16 | SOIC8W | 1 | U8 | MAX3232CSE+ | SO-16 | 2 | U2, U21 | MC3487 | SO-16 | 3 | U9, U18, U22 | MT48LC32M16A2 | TSOP54 | 2 | U13, U35 | NC | r0603 | 1 | R160 | Origin_select | SIP3 | 1 | J22 | POWER1 | 3.81PIN6 | 1 | J24 | PS2801-1 | SOJ-4 | 1 | U25 | PS2801-4 | SOJ-16 | 5 | U20, U24, U28, U29, U46 | Qi | 3.96PIN2 | 1 | J20 | Raster | JST2.0MM/4P | 1 | J3 | RESET | KEY-2 | 1 | S2 | RF30-185B | FUSE5.08MM | 1 | F2 | SCRAPE_MOTOR | JST2.0MM/4P | 1 | J9 | Scrape_org | SIP3P | 1 | J35 | Sensor_IN | JST2X2.0MM/30P -F | 1 | JP3 | SFP | SFP | 1 | U17 | Sleep | JST2.0MM/5P | 1 | J25 | ss36 | 1812D | 4 | D7, D8, D22, D23 | stm32f103_2 | TQFP12X12-100P | 1 | U19 | SW DIP-2 | DIP4 | 1 | S3 | SW_BUG | SIP4P | 1 | J19 | Temprature_ctr | JST2X2.0MM/14P -F | 1 | JP1 | THB6128 | SO-30-1MM | 2 | U201, U202 | TL431 | TO-92A | 1 | Q38 | TLK1221 | S-PQFP-N40 | 1 | U10 | TLP2530 | DIP8 | 2 | U203, U204 | UD_MOTOR | JST2.0MM/4P | 1 | J6 | UD_org | SIP3P | 1 | J36 | UL26 | SOIC6 | 1 | U51 | USART2 | SIP3P | 1 | J21 | USB_B_SQUARE | USB_B | 1 | J2 | Usb_COM | SIP3 | 1 | J29 | UV_ctr | JST2.0MM/4P | 1 | J26 | VCC_sel | SIP2 | 1 | J30 | W25Q64BVSIG | SOIC127P790X265 | 1 | U45 | X_LIMIT | SIP3P | 1 | J33 | X_MOTOR | JST2.0MM/4P | 1 | J10 | X_ORG | SIP3P | 1 | J34 | Y_LIMIT | SIP3P | 1 | J23 | Y_MOTOR | JST2.0MM/4P | 1 | J12 | Y_ORG | SIP3P | 1 | J14 | Y | 3.96PIN2 | 1 | J18 | Z_LIMIT | SIP3P | 1 | J13 | Z_MOTOR | JST2.0MM/4P | 1 | J28 | Z_ORG | SIP3P | 1 | J11 |
