查看: 3499|回复: 20
[Pads_VX.2x] IMX6 挂8个DDR3 正面背面各 4个-14层 PCB文件共享
    长期免费代管18-28岁小
    发表于 2018-2-16 16:58:02 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NamePCB DecalPart Type
    B1BATT_MSLICELL_BATT_MS_2.8MM_670-00010_
    D10603LEDLED_0603LED_IC_1.1MM_370-75143_
    D20603LEDLED_0603LED_IC_1.1MM_370-75145_
    D30603LEDLED_0603LED_IC_1.1MM_370-75143_
    D4SOD323DIODE_SCHTKY_SOD323_1.1MM_480-7
    D50603LEDLED_0603LED_IC_1.1MM_370-75143_
    D60603LEDLED_0603LED_IC_1.1MM_370-75143_
    D70603LEDLED_0603LED_IC_1.1MM_370-75144_
    D8DO_VMN2DIODE_DO_VMN2_IC_0.4MM_480-7793
    D90603LEDLED_0603LED_IC_1.1MM_370-75143_
    D100603LEDLED_0603LED_IC_1.1MM_370-75144_
    D11SOD123DIODE_SCHTKY_SOD123_1.0_MM_480-
    D120603LEDLED_0603LED_IC_1.1MM_370-75143_
    D130603LEDLED_0603LED_IC_1.1MM_370-75143_
    D140603LEDLED_0603LED_IC_0.65MM_370-75905
    D150603LEDLED_0603LED_IC_0.65MM_370-75905
    D31SOD123DIODE_ZENER21_SOD123_IC_1.35MM_
    D32SOD123DIODE_SCHTKY_SOD123_1.0_MM_480-
    D33DO_VMN2DIODE_DO_VMN2_IC_0.4MM_480-7793
    D1000DO_VMN2DIODE_DO_VMN2_IC_0.4MM_480-7793
    F1FUSE_2P2X1P5FUSE_RESETTABLE_FUSE_2P2X1P5_1.
    F2FUSE_2P2X1P5FUSE_RESETTABLE_FUSE_2P2X1P5_1.
    J1CON19_SDCARD_28X16_SMCONN_SDC013_19P_CON19_SDCARD_28
    J2CON_60S_QSH_SM_AQSH030_CON_60S_QSH_SM_A_IO_3.25
    J3HDR102_100MILHDR_1X2_TH_HDR102_100MIL_IO_11.
    J4MMCX_SMTMMCX_SMT_MMCX_SMT_5.15MM_211-77
    J5CON19_0P5_15X6P7MMHDMI_TYPE_A_VERT_CONNECTOR_CON1
    J6CON52_0P8_SMT_FULL-HALF_CUSTMINI_PCI_LATCH_52P_CON52_0P8_SM
    J7MMCX_SMTMMCX_SMT_MMCX_SMT_5.15MM_211-77
    J8CON_LCD_32F_1_SM_RACON_RCPT_1X32_F_CON_LCD_32F_1_S
    J9CON9_MICROAB_USB_SHELL_THMICRO_USB_CONN_9PIN_CON9_MICROA
    J10CON_SKT_44_0P5_SMTCONN_SKT_44P_CON_SKT_44_0P5_SMT
    J11MMCX_SMTMMCX_SMT_MMCX_SMT_5.15MM_211-77
    J12MMCX_SMTMMCX_SMT_MMCX_SMT_5.15MM_211-77
    J13MMCX_SMTMMCX_SMT_MMCX_SMT_5.15MM_211-77
    J14CON_SATA_22F_50_SMCONN_RCPT_1X22_F_CON_SATA_22F_5
    J15MMCX_SMTMMCX_SMT_MMCX_SMT_5.15MM_211-77
    J16MMCX_SMTMMCX_SMT_MMCX_SMT_5.15MM_211-77
    J17HDR210_HTST_SMHTST-110-01-S-DV_HDR210_HTST_SM
    J18CON_DB_9F_108_THCONN_DB9F_MTGTABS_CON_DB_9F_108
    J19CON_120S_QSH_SM_05PITCHQSH060_CON_120S_QSH_SM_05PITCH_
    J20CON19_SDCARD_28X16_SMCONN_SDC013_19P_CON19_SDCARD_28
    J21CON8_SIMS15_15P7X16P4CON_SIMS15_CON8_SIMS15_15P7X16P
    J22CON_DF_30F_1MM_SM_RACON30_CON_DF_30F_1MM_SM_RA_IO_1
    J23CON_120S_QTH_0P5_SMQTH060_CON_120S_QTH_0P5_SM_10.2
    J24CON_180S_QTH_0P5_SMQTH-090-01-L-D-A_CON_180S_QTH_0
    J25CON_DF_30F_1MM_SM_RACON30_CON_DF_30F_1MM_SM_RA_IO_1
    J26CON_180S_QTH_0P5_SMQTH-090-01-L-D-A_CON_180S_QTH_0
    J27CON_120S_QTH_0P5_SMQTH060_CON_120S_QTH_0P5_SM_10.2
    JP1100MIL_THJUMPER1X2_100MIL_TH_4MM_210-300
    L10603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_
    L2IND_IHLPINDUCTOR_IND_IHLP_DISCRETE_3_MM
    L30603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_
    L4IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCRET
    L5IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCRET
    L6CHOKE_0805DLW43_CHOKE_0805_1MM_180-76336_
    L70603_CCBEAD_0603_CC_0.95MM_180-30008_1
    L8CHOKE_0805DLW43_CHOKE_0805_1MM_180-76336_
    L90603_CCBEAD_0603_CC_0.95MM_180-30008_1
    L10IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCRET
    L11IND_IHLPINDUCTOR_IND_IHLP_DISCRETE_3.0
    L12IND_1812FS_5X4MMINDUCTOR_IND_1812FS_5X4MM_DISCR
    L13IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCR_1
    L140603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_
    L15IND_IHLPINDUCTOR_IND_IHLP_DISCRETE_3.0
    L16IND_IHLPINDUCTOR_IND_IHLP_DISCRETE_3.0
    L17IND_IHLPINDUCTOR_IND_IHLP_DISCRETE_3.0
    L18IND2_4X4MMINDUCTOR_IND2_4X4MM_DISCRETE_1.
    L19IND_0603BEAD_IND_0603_0.95MM_180-30008_
    L20IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCRET
    L210603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_
    L22IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCRET
    L230603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_
    L24IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCRET
    L250603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_
    L26IND_IHLPINDUCTOR_IND_IHLP_DISCRETE_3.0
    L270603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_
    L28IND_IHLPINDUCTOR_IND_IHLP_DISCRETE_3.0
    L29IND2_4X4MMINDUCTOR_IND2_4X4MM_DISCRETE_1.
    L10000603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_
    P1CON_MIC38P_AMP_SMMICTOR_38_767004_CON_MIC38P_AMP
    P2RAPC722DC_POWER_JACK_3_RAPC722_IO_11.0
    Q1SOT-23MOSFET_EN_SOT-23_IC_1.11_MM_480
    Q2SOT23NPN_SOT23_1.12_MM_480-75173_MMB
    Q3SOT-23MOSFET_P_SOT-23_1.11MM_480-7687
    Q4SO8_PAKFDMS6681Z_SO8_PAK_IC_1.10MM_480
    Q5SOT23NPN_SOT23_1.12_MM_480-75173_MMB
    Q6SOT23NPN_SOT23_1.12_MM_480-75173_MMB
    Q7SOT-23MOSFET_P_SOT-23_1.11MM_480-7687
    Q8SOT363PNP_DUAL_SOT363_IC_1.1MM_480-77
    RN1RCA_8_10NETW_B8_10P_RCA_8_10_470-75833_
    RN2RCA_8_10NETW_B8_10P_RCA_8_10_470-75833_
    RN3RCA_8_10NETW_B8_10P_RCA_8_10_470-75833_
    RN4RCA_8_10NETW_B8_10P_RCA_8_10_470-75833_
    SW1SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_2.36M
    SW2SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_2.36M
    SW3SW4_STJW_SMTACT_SWITCH_SW4_STJW_SM_4.1MM_5
    SW4SW_DIP8_4POS_SMSW_DIP4_SW_DIP8_4POS_SM_IC_2.32
    SW5SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_2.36M
    SW6SW_6P_10X6_THSW6_DPDT_SW_6P_10X6_TH_IC_7.7MM
    SW7SW4_STJW_SMTACT_SWITCH_SW4_STJW_SM_4.1MM_5
    SW8SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_2.36M
    U1SOT3531G125_SOT353_IC_1.1MM_312-75305
    U2QFN24_0P5_3X5MMLTC3614E_QFN24_QFN24_0P5_3X5MM_
    U3SSOT6_1P7X3FDC6331L_SSOT6_1P7X3_IC_1.1MM_3
    U4SSOT6_1P7X3FDC6331L_SSOT6_1P7X3_IC_1.1MM_3
    U5SSOT6_1P7X3FDC6331L_SSOT6_1P7X3_IC_1.1MM_3
    U6TSOT-23_0P95LTC3406ES5_TSOT-23_0P95_IC_1MM_
    U7BGA96_OPTIONAL2G_DDR3_SDRAM_128MX16_96P_BGA96
    U8XSON10_0P5_1P1X2P6MMIP4283CZ10_10P_XSON10_0P5_1P1X2
    U9XSON10_0P5_1P1X2P6MMIP4283CZ10_10P_XSON10_0P5_1P1X2
    U10HXSON12_0P4_2P6X2P2MM_CUSTIP4791CZ12_12P_HXSON12_0P4_2P6X
    U11TSOT-23_0P95LTC3406ES5_TSOT-23_0P95_IC_1MM_
    U12SSOT6_1P7X3FDC6331L_SSOT6_1P7X3_IC_1.1MM_3
    U13BGA96_OPTIONAL2G_DDR3_SDRAM_128MX16_96P_BGA96
    U14SOT3531G125_SOT353_IC_1.1MM_312-75305
    U15SC70-51G126_SC70-5_IC_1.1MM_312-79761
    U16BGA96_OPTIONAL2G_DDR3_SDRAM_128MX16_96P_BGA96
    U17SKT_BGA625_0P8_22X22IMX61_TO1_9_SKT_BGA625_0P8_22X2
    U18TSOT-23_0P95LTC3406ES5_TSOT-23_0P95_IC_1MM_
    U19TSSOP16MAX7310_TSSOP_16_TSSOP16_IC_1.1
    U20QFN26_0P5_5X5MC34716_A_QFN26_0P5_5X5_1MM_330
    U21BGA96_OPTIONAL2G_DDR3_SDRAM_128MX16_96P_BGA96
    U22SSOT6_1P7X3FDC6331L_SSOT6_1P7X3_IC_1.1MM_3
    U23SOIC8PI90LV179-8P_SOIC8_IC_1.75MM_31
    U24LFCSP16_0P65_4X4ADP2118_LFCSP_16P_LFCSP16_0P65_
    U25SOT3531G125_SOT353_IC_1.1MM_312-75305
    U26QFN48_0P4_6X6MM_EPADAR8031_QFN48_QFN48_0P4_6X6MM_EP
    U27SOT3531G07_SOT353_1.1MM_312-75421_NL1
    U28LFCSP16_0P65_4X4ADP2118_LFCSP_16P_LFCSP16_0P65_
    U29LFCSP16_0P65_4X4ADP2118_LFCSP_16P_LFCSP16_0P65_
    U30SC70_6LEADFDG6316P_SC70_6LEAD_1MM_480-779
    U31TSOP48_SKT980020-48-P2_TSOP48_SKT_5.33MM_
    U32RJ45_10_2LED_2SHLRJ45_GETH_VER_RJ45_10_2LED_2SHL
    U33TSOT-23_0P95LX1995_TSOT-23_0P95_1MM_312-794
    U34SC-70100201_SO-1_SC-70_1.1_MM_312-30
    U35QFN12MAX11801_TQFN_12P_QFN12_IC_0.8M
    U36TSOT-23_0P95LTC3406ES5_TSOT-23_0P95_IC_1MM_
    U37QFN24_4X4MM_SLUGLAN8720A-QFN24_QFN24_4X4MM_SLUG
    U38DFN6_2X2MMLTC3025_DFN6_2X2MM_IC_0.80_MM_3
    U39DFN6_2X2MMLTC3025_DFN6_2X2MM_IC_0.80_MM_3
    U40BGA96_OPTIONAL2G_DDR3_SDRAM_128MX16_96P_BGA96
    U41TSOT-23_0P95LTC3406ES5_TSOT-23_0P95_IC_1MM_
    U42DFN6_2X2MMLTC3025_DFN6_2X2MM_IC_0.80_MM_3
    U43SLP1616P6RCCLAMP_SLP1616P6_0.65MM_312-76
    U44SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4
    U45SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4
    U46SC70-6ADG849_SC70_6P_SC70-6_IC_1.10MM
    U47BGA96_OPTIONAL2G_DDR3_SDRAM_128MX16_96P_BGA96
    U48TSSOP16MAX7310_TSSOP_16_TSSOP16_IC_1.1
    U49SOT3531G125_SOT353_IC_1.1MM_312-75305
    U50US8_2P4X2P1MMNC7WZ123_US8_2P4X2P1MM_0.9MM_31
    U51PSOP8TXB0102_PSOP8_0.9MM_315-78892_T
    U52SC70-6ADG849_SC70_6P_SC70-6_IC_1.10MM
    U53BGA96_OPTIONAL2G_DDR3_SDRAM_128MX16_96P_BGA96
    U54TSOT-23_0P95LTC3406ES5_TSOT-23_0P95_IC_1MM_
    U55SSOT6_1P7X3FDC6331L_SSOT6_1P7X3_IC_1.1MM_3
    U56BGA96_OPTIONAL2G_DDR3_SDRAM_128MX16_96P_BGA96
    U57LFCSP16_0P65_4X4ADP2118_LFCSP_16P_LFCSP16_0P65_
    U58SSOT6_1P7X3FDC6331L_SSOT6_1P7X3_IC_1.1MM_3
    U59TSSOP8AT24CXX_TSSOP8_IC_1.2MM_334-760
    U60TSOP56_SKS-TSO-SM-056-C1_TSOP56_SK_5.33M
    U61SOT323_3PBAT54SW_SOT323_3P_1.1MM_480-779
    U62US8_2P4X2P1MMNC7WZ123_US8_2P4X2P1MM_0.9MM_31
    U63SOT323_3PBAT54SW_SOT323_3P_1.1MM_480-779
    U64SC70_6LEADNC7WP14_SC70_6LEAD_1.1MM_312-79
    U65TSSOP20MAX3380_TSSOP20_IC_1.1MM_312-75
    U66SC70_6LEADFDG6316P_SC70_6LEAD_1MM_480-779
    U67US8_2P4X2P1MMNC7WZ123_US8_2P4X2P1MM_0.9MM_31
    U68SOT323_3PBAT54SW_SOT323_3P_1.1MM_480-779
    U69PSOP8TXB0102_PSOP8_0.9MM_315-78892_T
    U70SOT-23-5MIC2774_SOT-23-5_IC_1.45MM_315-
    U71SOT3531G125_SOT353_IC_1.1MM_312-75305
    U72LFCSP16_0P65_4X4ADP2118_LFCSP_16P_LFCSP16_0P65_
    U73TSOT-23_0P95LX1995_TSOT-23_0P95_1MM_312-794
    U74SC-70100201_SO-1_SC-70_1.1_MM_312-30
    U75SOT3531G07_SOT353_1.1MM_312-75421_NL1
    U76SOT3531G07_SOT353_1.1MM_312-75421_NL1
    U77SOT3531G07_SOT353_1.1MM_312-75421_NL1
    U78SO8WSTM25P32_SO8WST_IC_2.5MM_334-7733
    U79SOT3531G07_SOT353_1.1MM_312-75421_NL1
    XP1MX61_SKT_HEATSINKMARLEY_PCB_2_MX61_SKT_HEATSINK_
    Y1XO6_2P54_7X5MMXO_6P_XO6_2P54_7X5MM_IC_2.0MM_2
    Y2XTAL4_SX_3225XTAL_13Y_A_XTAL4_SX_3225_0.7MM_
    Y31P8X3P5CRYSTAL_1P8X3P5_0.9_MM_230-3002
    Y4XTLOSC4_JXS75_SMXTAL_13Y_A_XTLOSC4_JXS75_SM_1.0
    Y57X5MMO4-0_7X5MM_1.9MM_230-76593_24.5
    Y1000OSC4_7P5X5MMOSC4_SM_OSC4_7P5X5MM_IC_1.75MM_
    重要提示:PCB作品文件展下载说明
    暑假期间,免费代管18-28岁小孩,限女性。
    长期免费代管18-28岁小
     楼主| 发表于 2018-2-16 16:58:45 | 显示全部楼层
    PCB是第三方软件转换过来的。
    MX6X.7z
    1.49 MB, 下载次数: 10, 下载积分: 金币 -5 枚
    终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
    发表于 2018-2-16 18:04:07 | 显示全部楼层
    发表于 2018-2-16 20:28:49 | 显示全部楼层
    这个板子看着好复杂啊
    PADS-2021国庆特训班
    发表于 2018-2-17 08:59:01 | 显示全部楼层
    终身成就奖社区居民
    发表于 2018-2-17 09:20:57 | 显示全部楼层
    11 小时前
  • 签到天数: 162 天
    终身成就奖优秀斑竹奖特殊贡献奖
    发表于 2018-2-17 09:23:36 | 显示全部楼层
    板子很漂亮,,打开看看
    前天 09:37
  • 签到天数: 53 天
    1元学习Allegro(1期)
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模优秀斑竹奖最爱沙发社区明星宣传大使奖
    发表于 2018-2-17 11:01:55 | 显示全部楼层
    8 小时前
  • 签到天数: 217 天
    发表于 2018-2-17 11:56:40 | 显示全部楼层
    发表于 2018-3-22 14:31:25 | 显示全部楼层
