瑞芯微的资料基本上都是PADS格式。阿里狗的很少。发一个TVBOX 。
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | ANT1 | ANT_JACK | ANT | ANT_JACK | ANT2 | ANT_JACK | ANT | ANT_JACK | CM2 | MTM-C | NC/100uF/16V | MTM-C | CM3 | MTM-C | 100uF/16V | MTM-C | CN1 | CON6_2_54MM_DIP | NC | CON6_2_54MM_DIP | CN2 | 3P-2_54 | NC | 3P-2_54 | CN3 | 3P-2_54 | NC | 3P-2_54 | D1 | SOT23 | NC/BAT54C | SOT23 | D2 | SOD123 | 1N5819 | SOD123 | D3 | SOT23 | BAT54S | SOT23 | DJ1 | DQT-003 | DQT-003 | DQT-003 | ED1 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | ED2 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | ED20 | E0402N | NC/ESD9B5V | E0402N | ED21 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | ED22 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | ED23 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | ED24 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | F1 | R1210 | 3A | R1210 | F2 | R0805 | NC | R0805 | F3 | R0805 | 0R | R0805 | FB1 | L0603D | NC/SDCW2012-2-900 | L0603D | FB2 | L0603D | NC/SDCW2012-2-900 | L0603D | H1 | H3_8MM | H3.8MM | H3_8MM | H2 | H3_8MM | H3.8MM | H3_8MM | H3 | H3_8MM | H3.8MM | H3_8MM | H4 | H3_8MM | H3.8MM | H3_8MM | IR1 | TO92ECB | FT-009 | TO92ECB | J1 | DC-413 | DC-413 | DC-413 | J2 | SD_F03_655_0008 | TF_SD_SOCKET | SD_F03_655_0008 | J3 | HDMI_A | HDMI_A | HDMI_A | J4 | PHONE-4C | PHONEJACK | PHONE-4C | J6 | OV9650FSL_0222A | OV2659 | OV9650FSL_0222A | JP1 | RJ45-NOLED | RJ45S | RJ45-NOLED | L1 | IND-3X3 | SWPA3015S3R3NT/1A | IND-3X3 | L2 | IND-3X3 | SWPA3015S1R0NT/2A | IND-3X3 | L3 | IND-4X4 | SWPA4030S1R0NT/5A | IND-4X4 | L4 | IND-4X4 | SWPA4030S1R0NT/5A | IND-4X4 | L5 | IND-3X3 | SWPA3015S1R0NT/2A | IND-3X3 | L8 | L0603 | 1.8uH | L0603 | L9 | IND-3X3 | 2.2uH/1A | IND-3X3 | L10 | IND-3X3 | SWPA3015S3R3NT/1A | IND-3X3 | L11 | L0603 | BLM18PG181SN1 | L0603 | L13 | R0402 | NC | R0402 | L14 | R0402 | NC | R0402 | LED1 | LED2_5 | Red | LED2_5 | MIC1 | MIC-4020 | MIC | MIC-4020 | Q1 | SOT23 | WNM2021/2SK3018 | SOT23 | Q2 | SOT23 | WNM2021/2SK3018 | SOT23 | Q3 | SOT23 | 8550 | SOT23 | Q4 | SOT23 | 8050 | SOT23 | Q5 | SOT23 | NC/8050 | SOT23 | Q6 | SOT23 | NC/8050 | SOT23 | Q7 | SOT23 | NC/8050 | SOT23 | Q8 | SOT23 | NC/8550 | SOT23 | Q22 | SOT23 | WPM2015 | SOT23 | Q28 | SOT23 | NC/8050 | SOT23 | RP9 | R0402S4 | NC/10K | R0402S4 | SW1 | SW8 | RECOVER | SW8 | T1 | MARK | MARK | MARK | T27 | T-1 | TEST | T-1 | U1 | BGA636_1 | MCU_RK3288 | BGA636_1 | U2 | FBGA96-10X14 | DDR3_128MX16BIT | FBGA96-10X14 | U3 | FBGA96-10X14 | DDR3_128MX16BIT | FBGA96-10X14 | U4 | FBGA96-10X14 | DDR3_128MX16BIT | FBGA96-10X14 | U5 | FBGA96-10X14 | DDR3_128MX16BIT | FBGA96-10X14 | U6 | TSOP1-48 | NAND_FLASH | TSOP1-48 | U7 | INAND_169_A | INAND | INAND_169_A | U8 | TSOP1-48 | tSD_Flash | TSOP1-48 | U9 | QFN68-7X7 | RK808 | QFN68-7X7 | U10 | ZEN056 | NC/ZEN056 | ZEN056 | U12 | SOP8 | NC/ZQ2996 | SOP8 | U13 | SOT25 | SY8089 | SOT25 | U14 | SOT25 | SY6280AAC/WS4601 | SOT25 | U15 | SOT25 | NC/PT5108E23E-33 | SOT25 | U16 | SLP2510P8 | NC/RClamp0524J/ESDA6V8UD | SLP2510P8 | U17 | SLP2510P8 | NC/RClamp0524J/ESDA6V8UD | SLP2510P8 | U18 | RK1000QUAD64 | RK1000-S | RK1000QUAD64 | U19 | SOIC24 | H5007(Pulse) | SOIC24 | U20 | QFN48-6X6 | RTL8211E-VB-CG | QFN48-6X6 | U22 | SC70_6 | NC/NL27WZU04 | SC70_6 | U23 | AP6XXX | AP6335 | AP6XXX | U24 | SOT25 | NC/PT5108E23E-15 | SOT25 | U25 | RL-UM12BS | NC/RL-UM12BS-8188EUS | RL-UM12BS | U27 | SOT25 | NC/SY6280AAC/WS4601 | SOT25 | USB1 | USB-AF90 | USB-AF90 | USB-AF90 | USB2 | USB-AF90 | USB-AF90 | USB-AF90 | Y1 | CRY-MC146 | 32.768K | CRY-MC146 | Y2 | CRY-D3225 | 24M-20ppm | CRY-D3225 | Y3 | CRY-D3225 | 25MHz-30ppm | CRY-D3225 | Y4 | CRY-D3225 | 37.4MHz-10ppm | CRY-D3225 |
