[Pads_VX.2x] POE以太网供电系统原理图PCB
查看23086 | 回复102 | 2018-5-2 21:59:28 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Part Report for MAXREFDES31_A.pcb on3/10/2014 1:21:42 PM
Name
Part Type
PCB Decal
Value
Tolerance
Voltage
Position X
Position Y
Layer Name
Orientation
C1
CAP1
603
OPEN
2365
1100
Bottom
C2
CAP1
805
0.1uF
1545
680
Bottom
C3
CAP1
603
0.022uF
50V
1845.14
1221.99
Top
C4
CAP2
1206
10uF
2015
1275
Bottom
180
C5
CAP2
1206
10uF
3475
585
Top
180
C6
CAP2
1210
1uF
2625
810
Bottom
270
C7
CAP\EEVFK1J220XP
HDCAP-F80
22uF
63V
2585
1674.02
Top
270
C8
CAP1
603
0.1uF
4185
1000
Top
90
C9
CAP\6SVPE220M
HDCAP-C6
220uF
6.3V
3985
1005
Top
270
C10
CAP\6SVPE220M
HDCAP-C6
220uF
6.3V
3750
350
Top
90
C11
CAP1
805
10uF
3770
1000
Top
90
C12
CAP1
603
0.1uF
3950
375
Top
270
C13
CAP2
1210
1uF
2320
1605
Top
90
C14
CAP1
603
0.01uF
1872.5
1027.5
Top
C15
CAP1
603
0.047uF
1900
712.5
Top
270
C16
CAP1
603
100pF
2080
710
Top
90
C17
CAP2
1210
1uF
2780
810
Bottom
90
C18
CAP3
1812
2200pF
2945
1550
Bottom
180
C19
CAP1
603
OPEN
3350
435
Bottom
90
C20
CAP1
603
0.022uF
50V
3480
525
Bottom
C21
CAP1
603
0.047uF
50V
3802.5
400
Bottom
C22
CAP1
603
0.01uF
25V
3155
660
Bottom
180
C23
CAP1
603
OPEN
2490
392.5
Bottom
90
C24
CAP1
603
330pF
2205
867.5
Top
270
C25
CAP3
1812
2200pF
1470
455
Bottom
90
C26
CAP3
1812
2200pF
1690
455
Bottom
90
C27
CAP1
805
0.1uF
1930
1775
Top
90
C28
CAP1
603
OPEN
2410
1260
Top
180
C29
CAP1
0805/2
OPEN
3165
1200
Top
180
C30
CAP1
603
0.1uF
1845
1414.02
Top
C31
CAP1
603
1000pF
2142.5
1320
Top
180
C32
CAP1
603
0.1uF
2390
532.5
Bottom
270
C33
CAP1
603
OPEN
2650
1027.5
Bottom
270
C34
CAP1
603
0.1uF
2045
1170
Bottom
180
C35
CAP2
1206
OPEN
4075
1015
Bottom
90
C36
CAP2
1206
OPEN
3960
1015
Bottom
90
C37
CAP2
1206
OPEN
3935
575
Bottom
270
C38
CAP2
1206
OPEN
4045
575
Bottom
270
C39
CAP1
603
OPEN
3830
760
Top
90
C40
CAP1
603
OPEN
3280
160
Top
90
C41
CAP/CER/LG/1808
CC1808
1000pF
630
1610
Bottom
C42
CAP1
805
0.1uF
Bottom
180
C43
CAP1
805
0.1uF
690
1740
Bottom
C44
CAP1
805
0.1uF
515
1465
Bottom
180
C45
CAP1
805
0.1uF
700
1275
Bottom
CHASSIS_GND
TESTPOINT-PC5004
TESTPOINT-MINITURE
1000
2150
Top
D1
BRIDGE1
SDIP4-MINI
HD01-T
1175
885
Bottom
270
D2
BRIDGE1
SDIP4-MINI
HD01-T
1175
885
Top
270
D3
SMBJ58A
SMB
SMBJ58A
1545.98
565
Top
D4
1N4148WS
SOD-323
OPEN
3320
980
Bottom
90
D5
1N4148WS
SOD-323
OPEN
3625
994.02
Bottom
90
D6
SMAJ58A
SMA-NEW
OPEN
2835
455
Top
270
D7
US1D
SMA-NEW
OPEN
2635
455
Top
270
D8
DIO\DIODES\B270-B2100
SMB
1650
1740
Top
270
D9
1N4148WS
SOD-323
OPEN
2430
1180
Bottom
D10
1N4148WS
SOD-323
2410
1015
Bottom
D11
BZT52C18S-7-F
SOD-323
18V
2010
1380
Bottom
180
D12
1N4148WS
SOD-323
OPEN
3125
1420
Top
D13
1N4148WS
SOD-323
OPEN
2530
1355
Bottom
D14
DIO\DIODES\BZT52C16
SOD-123
OPEN
3735
775
Bottom
180
D15
DIO\DIODES\BZT52C16
SOD-123
OPEN
3735
685
Bottom
180
D16
DIO\DIODES\BZT52C16
SOD-123
OPEN
3385
200
Bottom
D17
1N4148WS
SOD-323
3635
315
Bottom
D18
DIO\DIODES\BZT52C16
SOD-123
OPEN
3380
300
Bottom
GND
MAXIMPAD
INPUT\OUTPUT
GND
4200
875
Top
J1
RJ45_GIGA_1X1
RJ45_BELFUSE_1X1
406566-2
830
1400
Top
90
J3
CON\TYCO\5520252-4
CON/TYCO/5520252-4
665
875
Top
90
L1
CM-CHOKE\SUMIDA\CPFC74NP-04251-T118
CPFC74NP-04251-T118
1540
875
Top
270
L2
IND\SD53-3R3-R
IND-SD53
3.3uH
2910
1655
Top
270
L3
CM-CHOKE\TDK\ZJYS51R5-2PLT-01
ZJYS51R5-2PLT-01
1540
1380
Top
90
N1
FET-N-S-IRLML0030TRPBF
SOT23
IRLML0030TRPbF
3425
435
Top
90
N2
SOT23
IRLML0030TRPbF
3425
250
Top
90
N3
SOT23
IRLML0030TRPbF
3515
825
Top
N4
SOT23
IRLML0030TRPbF
3700
810
Top
N5
FDS86242
SO8/POWERPAK
FDS86242
2400
730
Top
270
OUT1
MAXIMPAD
INPUT\OUTPUT
3.3V/2A
4150
425
Top
OUT2
MAXIMPAD
INPUT\OUTPUT
5V/3A
4200
1125
Top
Q1
MMBTA06
SOT-23
OPEN
2670
1280
Bottom
90
Q2
MMBTA06
SOT-23
OPEN
2670
1140
Bottom
90
R1
RES1
603
24.9k
1%
2070
1720
Top
R2
RES1
603
1%
2222.5
1180
Bottom
R3
RES1
603
OPEN
1992.5
1075
Bottom
R4
RES1
805
30.9
1%
2165
1560
Top
90
R5
RES1
805
1140
Bottom
180
R6
RES1
603
16.9k
1%
1872.5
1122.5
Top
180
R7
RES1
603
34k
1%
1845
1320
Top
180
R8
RES1
603
1.5M
2010
1335
Top
270
R9
RES1
603
100k
1%
2077.5
1220
Top
R10
RES1
603
2k
1%
1990
712.5
Top
270
R11
RES1
603
OPEN
1992.5
980
Bottom
R12
RES1
0805/2
1034.02
Bottom
270
R13
RES1
0805/2
1034.02
Bottom
270
R14
RES1
603
30.1k
1%
2190
1347.5
Bottom
90
R15
RES1
603
30.1k
1%
1872.5
850
Top
180
R16
RES1
603
865
Top
270
R17
RES1
603
Open
1872.5
932.5
Top
R18
RES1
603
4.02k
1%
2177.5
875
Bottom
R19
RES1
805
1015
Top
180
R20
RES1
805
880
Bottom
270
R21
RES2
1206
0.15
1%
2455
785
Bottom
270
R22
RES1
805
OPEN
2300
1140
Top
R23
RES1
805
880
Bottom
270
R24
RES1
805
1380
Bottom
270
R25
RES2
1206
0.15
1%
2325
785
Bottom
270
R26
RES1
603
499
1%
2197.5
975
Bottom
R27
RES1
603
169k
1%
1845
1620
Top
180
R28
RES1
603
49.9k
1%
1845
1514.02
Top
R29
RES1
603
200k
2095
845
Top
270
R30
RES1
603
121k
1%
2190
710
Top
90
R31
RES1
603
520
Bottom
180
R32
RES1
603
510
1%
2590
392.5
Bottom
90
R33
RES1
603
510
1%
3155
560
Bottom
180
R34
RES1
603
1k
3480
615
Bottom
180
R35
RES1
603
4.12k
1%
3637.5
500
Bottom
180
R36
RES1
603
2.49k
1%
3480
400
Bottom
180
R37
RES1
603
1M
1%
3637.5
400
Bottom
180
R38
RES1
603
OPEN
2197.5
1075
Bottom
R39
RES1
603
500
Bottom
R40
RES1
805
1380
Bottom
270
R41
RES1
603
OPEN
2510
1100
Bottom
180
R42
RES1
603
2k
1%
3370
575
Bottom
90
R43
RES1
603
OPEN
2542.5
1260
Bottom
R44
RES1
603
OPEN
2285
1347.5
Bottom
90
R45
RES1
603
OPEN
2750
1027.5
Bottom
90
R46
RES1
603
OPEN
2380
1347.5
Bottom
270
R47
RES1
603
Bottom
90
R48
RES1
805
OPEN
3120
1320
Top
R49
RES1
603
OPEN
3275
630
Bottom
270
R50
RES1
805
OPEN
3800
645
Top
180
R51
RES1
805
OPEN
3425
100
Top
R52
RES\SMD\SM
CC0805
75
700
1840
Bottom
R53
RES\SMD\SM
CC0805
75
700
1475
Bottom
R54
RES\SMD\SM
CC0805
75
700
1375
Bottom
R55
RES\SMD\SM
CC0805
75
Bottom
T1
XFR\SUMIDA\CEP1311F\13324-T040
XFR\SUMIDA\CEP1311F
CEP1331F
2955
870
Top
90
T3
XFR\PULSE\PE-68386NL
OPEN
2800
1300
Top
U1
MAX5969B
TDFN-10-3X3
MAX5969B
2025
1570
Top
270
U2
MAX5974A
16-TQFN-3X3
MAX5974A
2075
1047.5
Top
U3
FOD817ASD
OPTO_4
FOD817ASD
2855
490
Bottom
U4
TLV431
SOT-23-5
TLV431AIDBVT-1.24V
3180
440
Bottom
180
V+
TESTPOINT-PC5000
TESTPOINT-MINITURE
RED
1350
650
Top
V-
TESTPOINT-PC5001
TESTPOINT-MINITURE
BLACK
1350
950
Top
WAD+
MAXIMPAD
INPUT\OUTPUT
EBUSS20W
1500
2075
Top
90
WAD-
MAXIMPAD
INPUT\OUTPUT
EBUSS20W
1300
2075
Top
90
X1
LOGO_MAXIM_INTEGRATED_ALL
LOGO_MAXIM_INTEGRATED_MED
3125
1650
Top
X2
MTHOLE
MTHOLE
125
125
Top
X3
MTHOLE
MTHOLE
125
2165
Top
X4
MTHOLE
MTHOLE
4255
125
Top
X5
MTHOLE
MTHOLE
4255
2165
Top
X10
MAXIMPAD
INPUT\OUTPUT
GND
4150
625
Top
重要提示:PCB作品文件展下载说明
mini | 2018-5-2 22:08:31 | 显示全部楼层
用PADS导入即可, MAXREFDES31_SCH_RA.rar (40 KB, 下载次数: 44)
mini | 2018-5-2 22:10:53 | 显示全部楼层
[hide=2,money]其他文件 实物图.rar (250 KB, 下载次数: 2)
wcjcn | 2018-5-3 00:51:52 | 显示全部楼层
o桃花岛主o | 2018-5-3 07:22:14 | 显示全部楼层
summer稳 | 2018-5-3 07:58:08 | 显示全部楼层
似水流年 | 2018-5-3 08:02:18 | 显示全部楼层
ct991218620 | 2018-5-3 08:03:09 | 显示全部楼层
yfchen1003 | 2018-5-3 08:14:00 | 显示全部楼层
fengxz | 2018-5-3 08:16:58 | 显示全部楼层
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
