REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BH1 | MOUNT_HOLE_MH256P130_IC_0.1MM_2 | MOUNTING HOLE | MH256P130 |
D1 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
D2 | DIODE_SMA_IC_2.41MM_480-30051_M | MBRA340T3G | SMA |
D3 | DIODE_SMA_IC_2.41MM_480-30051_M | MBRA340T3G | SMA |
D4 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
D5 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | LED_0603 |
D6 | LED_LED_0603_IC_0.9MM_370-75079 | RED | LED_0603 |
D7 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
D8 | ZDIODE_SOD123_IC_1.35MM_480-768 | MMSZ5231BT1G | SOD123 |
D9 | LED_LED_0603_IC_0.8MM_370-75078 | BLUE | LED_0603 |
D10 | DIODE_SMA_IC_2.41MM_480-30051_M | MBRA340T3G | SMA |
D11 | DIODE_SCHTKY_SOD123LF_IC_1.0MM | MBR140SFT | SOD123LF |
D12 | DIODE_SMA_IC_2.41MM_480-30051_M | MBRA340T3G | SMA |
D13 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
D14 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
D15 | DIODE_TVS_SMB_4P57X3P94MM_IC_2. | 1SMB24AT3G | SMB_4P57X3P94MM |
D16 | DIODE_SOD323_IC_1.15MM_480-3003 | BAT54HT1 | SOD323 |
D17 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
D18 | DIODE_SCHTKY_SOD123LF_IC_1.0MM | MBR140SFT | SOD123LF |
D19 | DIODE_SCHTKY_SOD123LF_IC_1.0MM | MBR140SFT | SOD123LF |
D20 | LED_LED_0603_IC_0.8MM_370-75078 | BLUE | LED_0603 |
D500 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
D501 | DIODE_SCHTKY_SOD123_IC_1.0MM_4 | MBR140SFT | SOD123 |
D502 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
D503 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
D504 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
J1 | CONN_HDR_2X1_HDR102_IO_8.39MM_2 | HDR 1X2 | HDR102 |
J3 | CONN_HDR_3X1_HDR103_78MIL_IO_7. | HDR_1X3 | HDR103_78MIL |
J4 | CONN_HDR_3X1_HDR103_78MIL_IO_7. | HDR_1X3 | HDR103_78MIL |
J5 | CONN_HDR_3X1_HDR103_78MIL_IO_7. | HDR_1X3 | HDR103_78MIL |
J6 | SATA_PLUG7_CON7_SATA_TH_17X5MM_ | CON 7 SATA | CON7_SATA_TH_17X5MM |
J7 | QSH030_CON_60S_QSH_SM_A_IO_3.25 | QSH-030-01-L-D-A-K-TR | CON_60S_QSH_SM_A |
J8 | DC POWERJACK_PJ-202B_IO_11.2MM | CONN PWR 1 | PJ-202B |
J9 | HDMI_TYPE_A_VERT_CONNECTOR_CON1 | HDMI TYPE A 19 | CON19_0P5_15X6P7MM |
J10 | MICRO_USB_CONN_9PIN_CON9_MICROA | USB AB 5 | CON9_MICROAB_USB_SHELL_TH |
J11 | USB_A_USB_A_TH_SAMTEC_IO_6.95M | USB_TYPE_A_FEMALE | USB_A_TH_SAMTEC |
J13 | CON30_DF19G-30P-1H_CON_DF_30F_1 | CON 30 | CON_DF_30F_1MM_SM_RA |
J14 | CONN_SDC013_19P_CON19_SDCARD_28 | CONN CRD 19 | CON19_SDCARD_28X16_SM |
J16 | CON40_CON_FPC_40F_0P5_SM_RA_IO_ | CON_1X40 | CON_FPC_40F_0P5_SM_RA |
J17 | CONN_HDR_5X2_HDR205_10M_50_SM_K | FTSH-105-01-L-DV-K | HDR205_10M_50_SM_K |
J18 | CONN_DB9F_MTGTABS_CON_DB_9F_2P7 | DB9 | CON_DB_9F_2P74_TH |
J21 | QSH030_CON_60S_QSH_SM_A_IO_3.25 | QSH-030-01-L-D-A-K-TR | CON_60S_QSH_SM_A |
J22 | MPCI_EXPRESS_CON52_0P8_SMT_FULL | CONN PCI EXP 52 | CON52_0P8_SMT_FULL-HALF_NSP |
L1 | INDUCTOR_FERRITE_A_IND_SRP4020_ | 1uH | IND_SRP4020 |
L2 | INDUCTOR_FERRITE_A_IND_SRP4020_ | 1uH | IND_SRP4020 |
L3 | INDUCTOR_IND_5015_DISCRETE_1.5M | 1uH | IND_5015 |
L4 | INDUCTOR_IND_VLS252010_DISCRETE | 1UH | IND_VLS252010 |
L5 | INDUCTOR_IND_5015_DISCRETE_1.5M | 1uH | IND_5015 |
L6 | INDUCTOR_IND_5015_DISCRETE_1.5M | 1uH | IND_5015 |
L7 | INDUCTOR_IND_5015_DISCRETE_1.5M | 1uH | IND_5015 |
L8 | INDUCTOR_FERRITE_A_IND_LPS4018_ | 2.2uH | IND_LPS4018 |
L9 | BEAD_0_0603_CC_DISCRETE_0.95MM_ | 120OHM | 0603_CC |
L10 | BEAD_0_0603_CC_DISCRETE_0.95MM_ | 120OHM | 0603_CC |
L500 | BEAD_0_0603_CC_DISCRETE_0.95MM_ | 120OHM | 0603_CC |
L501 | BEAD_0_0603_CC_DISCRETE_0.95MM_ | 120OHM | 0603_CC |
L502 | BEAD_IND_0805_DISCRETE_1.05MM_1 | 330OHM | IND_0805 |
P1 | CON_EDGE_281P_CUSTOM_CON_EDGE_2 | EDGE 281 | CON_EDGE_270F_0P5 |
Q1 | PNP_DUAL_SOT363_IC_1.1MM_480-77 | MBT3906DW1T1 | SOT363 |
Q2 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | SC70_3 |
Q3 | MOSFET_P_SOT-23_IC_1.12MM_480-7 | IRLML6401 | SOT-23 |
Q500 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | SC70_3 |
Q501 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | SC70_3 |
Q502 | FDMS6681Z_SO8_PAK_IC_1.10MM_480 | FDMS6681Z | SO8_PAK |
Q503 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | SC70_3 |
Q504 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | SC70_3 |
Q505 | FDMS6681Z_SO8_PAK_IC_1.10MM_480 | FDMS6681Z | SO8_PAK |
Q506 | FDG332PZ_SSOT6_1P7X3_IC_1.1MM_4 | FDC642P | SSOT6_1P7X3 |
Q507 | DUAL_NFET_SC70_6LEAD_IC_1.1MM_4 | FDG6301N | SC70_6LEAD |
Q508 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | SC70_3 |
Q510 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | SC70_3 |
S1 | SW_DIP-10_SW_DIP20_10POS_SM_IC_ | SW_DIP-10/SM | SW_DIP20_10POS_SM |
S2 | SW_DIP4_SW_DIP8_4POS_SM_IC_2.32 | SW DIP-4 | SW_DIP8_4POS_SM |
S3 | SW_DIP4_SW_DIP8_4POS_SM_IC_2.32 | SW DIP-4 | SW_DIP8_4POS_SM |
SH2 | RES_SHORT-2_SH0603_DISCRETE_0.1 | 0 | SH0603 |
SH3 | RES_SHORT-2_SH0402_CC_DISCRETE_ | 0 | SH0402_CC |
SW1 | SW_TC_SPST_4P_SW4_SKRP_IC_2.5MM | SKRPABE010 | SW4_SKRP |
SW2 | SW_TC_SPST_4P_SW4_SKRP_IC_2.5MM | SKRPABE010 | SW4_SKRP |
SW3 | SW_DIP-2_SMT_SW_DIP2_SM_IC_1.5M | 97C02ST | SW_DIP2_SM |
TP_GND1 | TESTLOOP_TP_TH_063_IO_8.13MM_21 | TESTLOOP_BLACK | TP_TH_063 |
TP_GND2 | TESTLOOP_TP_TH_063_IO_8.13MM_21 | TESTLOOP_BLACK | TP_TH_063 |
TVS500 | DIODE_TVS_BIDIR_SOD-923_NP_IC_0 | ESD9B5.0ST5G | SOD-923_NP |
U1 | PCIMX6Q6VV1A_BGA624_0P8_21X21_I | MCIMX6Q6AVT10AC | BGA624_0P8_21X21 |
U2 | 4G_DDR3_SDRAM_256MX16_96P_BGA96 | MT41K256M16HA-125:E | BGA96_0P8_9P15X14P15 |
U3 | 4G_DDR3_SDRAM_256MX16_96P_BGA96 | MT41K256M16HA-125:E | BGA96_0P8_9P15X14P15 |
U4 | 4G_DDR3_SDRAM_256MX16_96P_BGA96 | MT41K256M16HA-125:E | BGA96_0P8_9P15X14P15 |
U5 | 4G_DDR3_SDRAM_256MX16_96P_BGA96 | MT41K256M16HA-125:E | BGA96_0P8_9P15X14P15 |
U6 | 1G125_SOT353_IC_1.1MM_312-75305 | NL17SZ125 | SOT353 |
U7 | ML145170-7P_16P_TSSOP16_IC_1.2M | MLE145170 | TSSOP16 |
U8 | LT3680_MSOP_10P_MSOP10_0P5_3P1X | LT3680H | MSOP10_0P5_3P1X3P1 |
U9 | LT3680_MSOP_10P_MSOP10_0P5_3P1X | LT3680H | MSOP10_0P5_3P1X3P1 |
U10 | NLAS3158_WDFN12_0P5_3X1MM_IC_0. | NLAS3158 | WDFN12_0P5_3X1MM |
U11 | MMPF0100NPZES_56P_QFN56_0P5_8X8 | MMPF0100NPZES | QFN56_0P5_8X8_EP4P1X4P4 |
U12 | PI90LV179-8P_SOIC8_IC_1.75MM_31 | PI90LV179 | SOIC8 |
U13 | MAX7310_TSSOP_16_TSSOP16_IC_1.1 | MAX7310 | TSSOP16 |
U14 | MAX7310_TSSOP_16_TSSOP16_IC_1.1 | MAX7310 | TSSOP16 |
U15 | MAX7310_TSSOP_16_TSSOP16_IC_1.1 | MAX7310 | TSSOP16 |
U16 | M25P32_SO8WST_IC_2.5MM_334-7741 | M25P32-VMW3TGB | SO8WST |
U17 | NLAS3158_WDFN12_0P5_3X1MM_IC_0. | NLAS3158 | WDFN12_0P5_3X1MM |
U18 | SP3232E_SSOP16_IC_1.99MM_312-77 | SP3232 | SSOP16 |
U19 | 980020-48-P2_TSOP48_SKT_IC_5.33 | 980020-48-P2 | TSOP48_SKT |
U21 | 1G125_SC70-5_A_IC_1.1MM_312-301 | NC7SP125P5X | SC70-5_A |
U22 | 1G125_SC70-5_A_IC_1.1MM_312-301 | NC7SP125P5X | SC70-5_A |
U23 | ADG849_SC70_6P_SC70-6_IC_1.10MM | ADG849 | SC70-6 |
U500 | LT3012_16P_TSSOP16_116X141EP_IC | LT3012HFE | TSSOP16_116X141EP |
U501 | 1G125_SC70-5_A_IC_1.1MM_312-301 | NC7SP125P5X | SC70-5_A |
U502 | NLAS3158_WDFN12_0P5_3X1MM_IC_0. | NLAS3158 | WDFN12_0P5_3X1MM |
U503 | NLAS3158_WDFN12_0P5_3X1MM_IC_0. | NLAS3158 | WDFN12_0P5_3X1MM |
U504 | CM2020_TSSOP_38P_TSSOP38_0P5_4P | CM2020 | TSSOP38_0P5_4P5X9P8 |
U505 | CS2000CP_10P_MSOP10_0P5_3P1X3P1 | CS2000CP | MSOP10_0P5_3P1X3P1_IPC |
U506 | NLAS3158_WDFN12_0P5_3X1MM_IC_0. | NLAS3158 | WDFN12_0P5_3X1MM |
U507 | SRV05-4_SOT23_S6_IC_1.45MM_480- | SRV05-4 | SOT23_S6 |
U508 | ADG849_SC70_6P_SC70-6_IC_1.10MM | ADG849 | SC70-6 |
U509 | NLAS3158_WDFN12_0P5_3X1MM_IC_0. | NLAS3158 | WDFN12_0P5_3X1MM |
U510 | 256M_FLASH_TSOP_56P_TSOP56_0P5_ | M29W256GL7AN6E | TSOP56_0P5_14X18 |
U511 | NLAS3158_WDFN12_0P5_3X1MM_IC_0. | NLAS3158 | WDFN12_0P5_3X1MM |
U512 | 74-125_14P_TSSOP14_IC_1.2MM_312 | 74LCX125 | TSSOP14 |
U513 | STM6315RDW13F_SOT143-25X60_IC_1 | STM6315RA | SOT143-25X60 |
U514 | 74-125_14P_TSSOP14_IC_1.2MM_312 | 74LCX125 | TSSOP14 |
U515 | STM6315RDW13F_SOT143-25X60_IC_2 | STM6315RDW13F | SOT143-25X60 |
U516 | 1G126_SC70-5_IC_1.1MM_312-79761 | NC7SP126 | SC70-5 |
U517 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | SO8 |
U518 | ONE_AND_SC70-5_IC_1.1MM_312-303 | NC7SZ08P5 | SC70-5 |
U519 | 1G126_SC70-5_IC_1.1MM_312-79761 | NC7SP126 | SC70-5 |
U521 | NC7SZ125_6P_MICROPAK_6P_IC_0.55 | NC7SZ125L6X | MICROPAK_6P |
U522 | SN74LVC1G123_SSOP8_DCU_IC_0.90M | SN74LVC1G123 | SSOP8_DCU |
U523 | NC7SZ125_6P_MICROPAK_6P_IC_0.55 | NC7SZ125L6X | MICROPAK_6P |
Y1 | OSC4_OSC4_5X3_IC_1.4MM_230-7783 | 24.576MHZ | OSC4_5X3 |
Y2 | XTAL_XTAL2-3P2X1P5-SM_IC_0.65MM | 32.768kHz | XTAL2-3P2X1P5-SM |
Y3 | XTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I | 24MHZ | XTLOSC4_3P2X2P5MM_SM |
