REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | ACR1 | ACR120A | ACR_(ITEX_AMR_2.0) | ACR120A | AGP1 | AGPSLOT66 | UAGP30_CON | AGPSLOT66 | ATXPWR1 | CON10X2_165A2 | ATX_PWR_CON | CON10X2_165A2 | ATXPWR2 | CON2X2_165 | ATX_PWR_CON4A | CON2X2_165 | B1 | PUSH_SWITCH | BUTTON | PUSH_SWITCH | B2 | PUSH_SWITCH | BUTTON | PUSH_SWITCH | BAT1 | CR2032 | Lithium | CR2032 | CHOKE1 | CHOKE_0805 | COMM_CHOKE | CHOKE_0805 | CHOKE2 | CHOKE_0805 | COMM_CHOKE | CHOKE_0805 | CLK1 | SSOP48_L | CLOCK_GEN_(648) | SSOP48_L | CLK2 | SSOP48_L | CLOCK_BUFFER_(DDR48) | SSOP48_L | CT1 | TANC | 33uF_SMD_20% | TANC | CT2 | TANC | 33uF_SMD_20% | TANC | D4 | ET1206DC | 1N4148 | ET1206DC | D5 | 1N5817A | 5817 | 1N5817A | D6 | 1N5817A | 5817 | 1N5817A | D7 | LED_AC | LED | LED_AC | D8 | LED_AC | LED | LED_AC | D9 | SMDDIO_214AB | MBRS340 | SMDDIO_214AB | D10 | ET1206DC | 1N4148 | ET1206DC | D11 | ET1206DC | 1N4148 | ET1206DC | D12 | ET1206DC | 1N4148 | ET1206DC | D13 | ET1206DC | 1N4148 | ET1206DC | D14 | ET1206DC | 1N60 | ET1206DC | DIMM1 | DIMM184 | DDR_SDRAM_DIMM | DIMM184 | DIMM2 | DIMM184 | DDR_SDRAM_DIMM | DIMM184 | DIMM3 | DIMM184 | DDR_SDRAM_DIMM | DIMM184 | EEROM1 | SOIC8 | 93C46 | SOIC8 | F1 | FUSE_SMD | FUSE_SMD | FUSE_SMD | F2 | FUSE_SMD | FUSE_SMD | FUSE_SMD | F3 | FUSE_SMD | FUSE_SMD | FUSE_SMD | F4 | FUSE_SMD | FUSE_SMD | FUSE_SMD | F5 | FUSE_SMD | FUSE_SMD | FUSE_SMD | F6 | FUSE_SMD | FUSE_SMD | FUSE_SMD | F7 | FUSE_SMD | FUSE_SMD | FUSE_SMD | F8 | GCSMFUSE | SMD150-2 | GCSMFUSE | FLOPPY1 | CON17X2 | FDC_CON | CON17X2 | H1 | HOLE | HOLE | HOLE | IDE1 | CON20X2 | HEADER_20X2 | CON20X2 | IDE2 | CON20X2 | HEADER_20X2 | CON20X2 | J1 | ITP25_FCI | ITP | ITP25_FCI | J2 | DCON9M | DCON9M | DCON9M | J3 | H4X1HDR | AUX_IN | H4X1HDR | J4 | H4X1HDR | VIDEO_IN | H4X1HDR | J5 | H4X1HDR | CD_INPUT_1 | H4X1HDR | J6 | CON4_A | CD_INPUT_2 | CON4_A | J7 | SISCONT1394 | 1394_CON | SISCONT1394 | J8 | SISCONT1394 | 1394_CON | SISCONT1394 | J9 | CON5X2 | HEADER_5X2 | CON5X2 | J10 | ETPHONEJACK | 3_IO_AUDIO_CON | ETPHONEJACK | JOY1 | DCON15F | J/M_CON | DCON15F | JP1 | SHORT0402 | SHORT | SHORT0402 | JP11 | SHORT0402 | SHORT | SHORT0402 | JP12 | SIP5 | HEADER_5 | SIP5 | JP13 | SIP2G | FAN_2 | SIP2G | JP14 | SHORT0402 | SHORT | SHORT0402 | KBMS1 | KB_MS | PS/2_KB/MS | KB_MS | L52 | CHOKE11X17A | 1uH | CHOKE11X17A | L53 | CHOKE11X17A | 1.1uH | CHOKE11X17A | L54 | CHOKE11X17A | 1.1uH | CHOKE11X17A | L55 | CHOKE11X17A | 1.1uH | CHOKE11X17A | L56 | CHOKESMD_10D16 | 1.5uH_10A | CHOKESMD_10D16 | L57 | CHOKE11X17A | 2.2uH_20A | CHOKE11X17A | L58 | CHOKESMD_10D16 | 3.3uH_5A | CHOKESMD_10D16 | LDO1 | SOT-223A | AIC1086_SOT223 | SOT-223A | LDO2 | SMDTO_252C | AIC1084_TO252 | SMDTO_252C | LS1 | BZ_250 | SPEAKER | BZ_250 | M1 | 2N7002B | FDN340P | 2N7002B | M2 | SOIC8 | SI4410DY | SOIC8 | M3 | 2N7002B | FDN340P | 2N7002B | M4 | SOIC8 | SI4410DY | SOIC8 | M5 | 2N7002B | FDN340P | 2N7002B | M6 | SOIC8 | SI4410DY | SOIC8 | P1 | ET_DSUB25F | DB25 | ET_DSUB25F | PCI1 | SLOT_PCI120A | PCI_CON_2.2 | SLOT_PCI120A | PCI2 | SLOT_PCI120A | PCI_CON_2.2 | SLOT_PCI120A | PCI3 | SLOT_PCI120A | PCI_CON_2.2 | SLOT_PCI120A | PCI4 | SLOT_PCI120A | PCI_CON_2.2 | SLOT_PCI120A | PCI5 | SLOT_PCI120A | PCI_CON_2.2 | SLOT_PCI120A | PCI6 | SLOT_PCI120A | PCI_CON_2.2 | SLOT_PCI120A | Q1 | SOT23_QA | MMBT3904 | SOT23_QA | Q2 | SOT23_QA | MMBT3904 | SOT23_QA | Q4 | SOT23_QA | MMBT3904 | SOT23_QA | Q5 | SOT23_QA | MMBT3904 | SOT23_QA | Q6 | SOT23_QA | MMBT3906 | SOT23_QA | Q7 | 2N7002B | 2N7002 | 2N7002B | Q8 | SOT23_QA | MMBT3906 | SOT23_QA | Q9 | 2N7002B | 2N7002 | 2N7002B | Q10 | SOT23_QA | MMBT3904 | SOT23_QA | Q11 | SOT23_QA | OPEN/MMBT3906 | SOT23_QA | Q12 | SOT23_QA | MMBT3904 | SOT23_QA | Q13 | TO-252C | HUF76107D3S | TO-252C | Q14 | SOT23_LM431 | LM431ACM3 | SOT23_LM431 | Q15 | TO-252C | HUF76107D3S | TO-252C | Q16 | 2N7002B | 2N7002 | 2N7002B | Q17 | MA05ASMD | RC431A | MA05ASMD | Q18 | 2N7002B | 2N7002 | 2N7002B | Q19 | TO_263 | FDB7030BL | TO_263 | Q20 | TO_263 | GFB70N03 | TO_263 | Q21 | 2N7002B | 2N7002 | 2N7002B | Q22 | TO_263 | FDB7030BL | TO_263 | Q23 | TO_263 | GFB70N03 | TO_263 | Q24 | TO_263 | FDB7030BL | TO_263 | Q25 | TO_263 | GFB70N03 | TO_263 | Q26 | SOT23_QA | MMBT3904 | SOT23_QA | Q27 | SOT23_QA | MMBT3904 | SOT23_QA | Q28 | LT1084SMD_A | MTD20N03HDL | LT1084SMD_A | Q29 | LT1084SMD_A | MTD20N03HDL | LT1084SMD_A | Q30 | SOT23_QA | MMBT3904 | SOT23_QA | Q31 | SOT23_QA | MMBT3904 | SOT23_QA | Q32 | 2N7002B | 2N7002 | 2N7002B | Q33 | SOT23_QA | MMBT3904 | SOT23_QA | Q34 | SOT23_QA | MMBT3904 | SOT23_QA | Q35 | 2N7002B | 2N7002 | 2N7002B | Q37 | 2N7002B | 2N7002 | 2N7002B | Q38 | SOT23_QA | MMBT3904 | SOT23_QA | RT1 | ET0603R | 10K_1% | ET0603R | S1 | DIPSW10_A | SW_DIP-5 | DIPSW10_A | S2 | SIP2 | CASEOPEN_SW | SIP2 | SD1 | 1N5817A | 1N5817 | 1N5817A | SD2 | 1N5817A | 1N5817 | 1N5817A | SD3 | 1N5817A | 1N5817 | 1N5817A | T1 | SOIC16_336 | LF8505 | SOIC16_336 | TP1 | TP30T | TP | TP30T | TP2 | TP30T | TP | TP30T | U1 | P4_PGA478 | 478CPU | P4_PGA478 | U2 | BGA839_AT36_SIS648 | 648 | BGA839_AT36_SIS648 | U3 | BGA371_SIS96XA | 963 | BGA371_SIS96XA | U4 | QFP128_D5 | W83697HF | QFP128_D5 | U5 | SOIC20 | W83778/DS14185/GS75232 | SOIC20 | U6 | SOIC20 | W83778/DS14185/GS75232 | SOIC20 | U7 | TQFP48_D5M | ALC201 | TQFP48_D5M | U8 | SOIC8 | LM4880 | SOIC8 | U9 | QFP64S_D5M | RTL8801 | QFP64S_D5M | U10 | QFP64S_D5M | ICS1893 | QFP64S_D5M | U11 | DIP32_600 | FLASH_ROM | DIP32_600 | U12 | SOIC14 | LM324M | SOIC14 | U13 | SOIC20 | HIP6301 | SOIC20 | U14 | SOIC8 | HIP6601A | SOIC8 | U15 | SOIC8 | HIP6601A | SOIC8 | U16 | SOIC8 | HIP6601A | SOIC8 | U17 | SOIC8 | LTC1530CS8-ADJ | SOIC8 | U18 | SOIC16 | ML6554 | SOIC16 | USB1 | SSUSB | 2_USB_1_RJ45_CON | SSUSB | X1 | OSC8A | OSC/OPEN | OSC8A | Y1 | CRYSTAL | 25M | CRYSTAL | Y2 | ETXTALS | 32.768K | ETXTALS | Y3 | CRYSTAL | 12M | CRYSTAL | Y4 | CRYSTAL | 14.318MHz | CRYSTAL | Y5 | CRYSTAL | 24.576M | CRYSTAL | Y6 | CRYSTAL | 24.576M | CRYSTAL | Y7 | CRYSTAL | 25M | CRYSTAL |
